Question about Epson Stylus Photo 925 InkJet Printer
Photo 925 broke print and i need to replace it
Where to find printer head and how much?
  • Epson Master
  • 365 Answers
It is probably cheaper ,unfortunately,to replace the printer.Heads are roughly $60 US and it takes a tech to install plus new ink required to seal the vacuum.
Posted on Jun 20, 2009
Print head not moving
first put your printer off - look under your head of the printer you will see little white plastic move it with your pen or spoon or any other then pull your head to left
Feb 13, 2015 | Epson Stylus Photo 925 InkJet Printer
HP Photosmart C7250 lines in photos
Replace print heads.. For draft or letter work you can adjust with this print heads, but photo prints you need good healthy conditioned print heads.. as per you info you did every thing rest only thing to replace..
Jan 09, 2012 | HP Photosmart C7250 All-In-One Thermal...
I have a Canon Pixma 260 photo printer which I have not used for 2-3 years. Everything seems to be working EXCEPT when I try to print, nothing appears on the photo paper! I just bought a new ink cartridge...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 28, 2011 | Canon PIXMA mini260 InkJet Photo Printer
I have Epson stylus photo 925 and get horizontal lines on printed page. I have run the Print Head Alignment program but the printout is too light to see. Aolution?
Hi
I suggest you clean it manually by removing the print head and then rub the print head in a plain paper with isopropyl alcohol until ink flows. Return the ink cartridge into the printer and run the print nozzle for 2-3 times.
Please let me know if you need more help.
Mar 05, 2011 | Epson Stylus Photo 925 InkJet Printer
New/refurbished printers from Epson.com are cheaper than a new head.
Jun 20, 2009 | Epson Stylus Photo 925 InkJet Printer
The jets are constantly needing cleaning...
Either you're using a low grade ink to refill the cartridges or you're not using it enough to keep the head clean. If the ink is allowed to dry on the print head, simply running the "Clean print head" function doesn't always get the dried ink loose. Remove the cartridge and CAREFULLY, clean it with damp toilet paper. Only go ONE DIRECTION when cleaning. SIDE TO SIDE. When it looks clean, check carefully for any left over fuzz. You can also clean the wiper inside the printer with a damp cotton swab.
May 03, 2009 | Epson Stylus Photo 925 InkJet Printer
Printer Head cleaning
I've encountered the same situation with my 925. It requires routine cleaning. Try using name brand ink if you aren't already. Cheap ink has a tendancy to dry and clog at a quicker rate. Also, be sure to turn off the printer when you are finished with it. From what I understand, when you shut it off, it caps the ink nozzles like putting the lid on a ketchup bottle.
When doing a job with lots of ink usage, use a quality paper and do a nozzle cleaning right before hand. Hope this helps.
Jun 09, 2008 | Epson Stylus Photo 925 InkJet Printer
Roller guide came off
so what are you asking? you can get them replaced you can get some tape or super glue if it broke and if u can find all the peices otherwise it shouldnt hurt it to have the guide at the end of the printing cycle go bad
May 28, 2008 | Epson Stylus Photo R800 InkJet Printer
Photo Printer
sina, Does the photo print good using photo paper? How regular of a paper? Do all other colors have ink? What program are you printing the photo from? Have you tried printing from a different program? Some programs send varying information to printers. If all of the above has been tried...uninstall the printer and download the newest drivers from EPSON and re-install the printer. Good luck Tim
Feb 03, 2007 | Epson Stylus Photo 925 InkJet Printer
Epson Stylus Photo 925 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
