Question about Insignia Digital-to-Analog Converter for Analog TVs
I bought the magnavox and all my channels are
I bought the magnavox and all my channels are great but ive tryed to go through the steps in the pamplet for my sound and cant get it to work you can just bearly hear it with the box on please help
I have the same problem, and there is no volume control on the remote for the converter box. i have tryed every thing i can, and nothing is working. so i am going to buy a converter box that is not a magnavox. i do not like this box. hope i help.
Posted on Aug 20, 2009
  • 30 Answers
Check the converter box. Many have a volume setting that is usually set very low at the factory. On the remote control for the converter check to see if there are volume buttons. If so, change the converter box volume higher, to a level that makes the TV audio level "normal", then use the volume control on the TV for adjustment as you watch. If you set the volume on the converter box too high, you may get some distortion in the audio from your TV. So adjust the converter box to find the proper output from your TV without distortion.
Posted on Jun 21, 2009
I need programing codes for magnavox tv
Hello
Three digit universal remote codes for Magnavox TV are:
004/ 008/ 009/ 062/ 068/ 069/ 074/ 075/ 076/ 077/ 089/ 133/ 163/ 165
For Philips Magnavox are:
183/ 184/ 208/ 213
Four digit universal remote codes for Magnavox are:
0062 0004 0009 0456 0183 0226 0288 0008 0068 0075 0141
0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Jul 23, 2011 | Televison & Video
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
HDTV unable to get HD Channels w/ Antenna
The problem could be your antenna. Many people will buy small indoor tv antennas and wonder why they're not getting the signal that they want or the channels that they expect. Its not your fault. Digital signal is in two formats: UHF AND VHF. Some antennas only receive UHF. But many of the low band channels are VHF, so 1) you need an antenna that will receive those signals and 2) you need to know how and where to install that antenna and 3) you need to know if you need a signal amplifier depending on your coaxial cable length and number of connections. I recommend visiting dennys antenna service (no I don't work there and I have never purchased anything from that website. He just has an excellent informational article with a great deal of "how to" on his pages.). http://www.dennysantennaservice.com/2029710.html This should be of great help to you. Happy viewing =)
Dec 26, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
Silver Charter Communications Remote Control
1174,0062,0004,0009,0183,1133,0226,0288,0456,0008,0068,0075,0141
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 28, 2009 | Philips PM3S Remote Control
Ive got a magnavox 00M146SB-AA01 big screen tv vcr remote control
Didn't solve it, but it's not that important to have to pay for it. Thanks anyway.
Jun 18, 2009 | Philips Magnavox Learning Universal Remote
I cant record tv through my vcr.
set the vcr up so that you change the chanels through the vcr,,,check the vcr setup menu
May 16, 2009 | Philips Televison & Video
Tv preset
uh...it's a stolen TV. that's the problem
Oct 05, 2008 | Philips Magnavox 27MS343S 27" TV
Cannot get the television to get out of fuzzy screen
  • hit the channel return button on the remote
  • hit the tv/video button on the remote
  • perform a channel scan through the remote menu
  • unplug unit for over an hour and plug back in, complete initial setup by following instruction on the tv.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Best Picture Quality
The set may not be at fault. If you are on cable some channels are still in anolog and some are digital. if you are on a nolog channel the picture will look preaty bad compared to the digital ones.
May 09, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
GE: 13" Model13GP341 vchip parental control locked
magnavoxes and phillips tv's uses overide codes .those of you who have either of the two tv sets try this code 0711 hope it works.
Nov 05, 2007 | Philips Magnavox 27MS343S 27" TV
Insignia Digital-to-Analog Converter for Analog TVs Logo
375 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
