Question about Uniden DXAI4288-2 Cordless Phone
Can't hear caller or answer phone on extra handset
I can make calls on my extra handset but not answer. I switched the two phones and it works fine on the base, but then the other phone didn't work on the charger. These are relatively new phones and it was working up until a few weeks ago. The charger is plugged in and light is lit but not blinking. Do I need a new charger, a new battery? Thank you for any help.
  • richardwk Nov 13, 2007
    uniden DXAI4288-2
  • Anonymous Dec 28, 2007
    All three handsets give the error message "searching". The phone rings, but when I answer it make a weird dying blip. Everything seems to be plugged in and secure. The 3 handset system is about 5 months old.
  • 277 Answers
SOURCE: caller can't hear my vocie when I use hand set
probly it fell or something the speaker needs replacing
Posted on Jan 31, 2006
SOURCE: Uniden cordless phones
This sounds like the register-deregister problem elsewhere on this page. Try holding down the "end" and "#" buttons for about 6 seconds to deregister the phones and then reregister them. I had this problem too and it worked for me.
Posted on Jan 21, 2007
SOURCE: 5.8 ghz mulit-handset cordless phone
How do you get the ringer on this phone to work?
Posted on Dec 14, 2007
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
I was using this site while trouble shooting this in the US...
If the customer has DSL with filters in the same system go back to the NID and Isolate the DSL,
test the caller id and call waiting caller id. If this works you have Data Bleed coming from the DSL.
Make sure there are not two sets of filters on the line. Tjis customer had a filter with the DSL modem.
Doing this we just fixed an on going problem for a field tech who was the second callout on a customer issue.
Posted on May 11, 2009
People can not hear the caller on Cisco 7945G
Could be a bad hook switch on the phone if you plug a different phone in does it work as it should?
May 07, 2014 | Cisco 7945G IP Phone
Phone rings once, but then stops ringing and I can't answer the call
If you have a landline, most likely you have a short in it. Not enough to kill line, but, when the 90 volts a.c. comes in to ring it jumps short. The short answers the phone.. It doesn't stop out going but can cause static. Check the line at the box outside. if bad there call your phone company, if good there, trouble is in house
Oct 03, 2017 | Uniden DECT 6.0 Cordless Telephone...
Hi, I tried to configure my phone in below steps,
Maybe a mute button is on...volume setting all the way down....? Try calling you number from another phone..See if anything lights up. Bent connection pin in phone base.Try another cord. Trying to help.
Aug 11, 2013 | AT&T 5840 5.8GHz...
Hi, how do i answer call waiting on the kx-tg1311. The flash button is not working neither is it working by pressing the call button.
If you subscribe to both Caller ID and Call Waiting with Caller ID
services, the 2nd caller's information is displayed after you hear the call
waiting tone on the handset.
1 Press {R} to answer the 2nd call.
2 To switch between calls, press {R}.
Thanks for using Fixya!
Jun 18, 2011 | Panasonic KXTG1311 Cordless Phone
I can hear the caller but caller cannot hear me on 29870GE1-A digital answering machine
Hi, Please check whether the mic has gone bad in your handset.
the connectivity is just fine as your are able to hear the caller. but if you think there must be something wrong with the caller's phone, try calling someone else and check.
please let me know if you need more help. Thank you:)
Oct 23, 2010 | GE 29870GE1 Corded Phone
I can hear caller on handset but they cannot hear me?
We just had the same problem with our AT&T 2462 hand sets. They simultaneously stopped transmitting, and though we could hear the caller, no one could hear us on the other end of the line. We unplugged the base from the power source, took the batteries out of the hand sets, waited 20 seconds, then plugged everything back in and they worked just fine. Hope this helps.
May 03, 2009 | AT&T E2562 Cordless Phone
Handset problem
It sounds like you have a defective handset cord or handset. First, at your phone, switch your handset with another phones handset that you know for sure works. From your phone make a test call. If the caller can now hear you, the original handset from your phone is defective. If the caller still can not hear you, switch your handset cord with another handset cord from another phone that you know works. From your phone make another test call. If the caller can hear you, then your original handset cord is defective. You can purchase another handset cord from your local office supply store. Your phone uses a standard handset cord. It may be difficult to match the original color of your handset cord. Be sure to take your defective handset cord with you, so you can try to match the color. If the caller still does not hear you. Put your original handset and original handset cord back on your phone. Then plug your phone in to another wall jack, that you know works with another phone. The other phone needs to be an identical phone to yours (same number of buttons and same model number. The model number can be found under the phone). Wait approximately 90 seconds, sometimes longer, after you plug your phone into the other wall jack. Now, make another test call from your phone. If the caller can now hear you from your phone with it plugged into another working jack, then you have a defective station port or jack where your phone was originally plugged in at. If the caller still can not hear then you have a defective phone.
Nov 19, 2008 | NorStar M7208 Corded Phone
AT&T phone model E5634B
SOLUTION to AT&T Cordless Telephone/Answering System 4 phone set Model E5634B - Cannot answer incoming calls nor does caller ID work on phones.
Unplug the base for a few minutes, plug base back in, remove and reinsert the battery on each phone that does not work, then place each handset in the base for few minutes. Worked for me...all 4 phones can be answered and caller ID works!!! Hope this works for you... :o)
Jan 12, 2008 | AT&T E5634B Phone System w/ Caller ID
Uniden DXAI4288-2 Cordless Phone Logo
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
