Question about Panasonic 50 in. Plasma TV
Bbc1 and 2 on freeview lost
Bbc1 and 2 lost after upgrade. we have the option to exit upgrade or continue.
we normally press exit,upgrade went ahead 1 and 2 gone, cannot retune back on our panasonic plasma viera, anybody help me.
    President:
  • 1,653 Answers
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Posted on Oct 03, 2009
Menu segreto hannspree hsg1113
http://translate.google.com
Secret service menu Hannspree HSG1113
https://electronicshelponline.blogspot.com/2015/03/hannspree-lcd-tv-how-to-enter-service.html
Possible menu - Quoting from link above:
SERVICE MODE [Hanspree AT06 42" LCD TV] (Horizontal Frequency 31.5KHz to 48KHz)
* In the TV mode, adjust volume to Zero and press number keys 9 > 8 > 7 > 6 to enter service mode.
* To exit, press the EXIT button on the remote control.
SERVICE MODE (Hanhspree GT02 32E - GT03-37E1)
1 Switch on the LCD TV .
2 Press 9-9-1 on the remote control to enter the internal Service menu.
3 Press MENU to switch the service mode pages.
4 Press ?? to scroll through the various menu options.
5 Press ?? to change the menu settings.
6 Press MENUto save the new settings and switch to next page and press EXITto exit from service mode to normal mode.
TV / AV / S-VIDEO / WHITE BALANCE / BRIGHTNESS & CONTRAST ADJUSTMENTS
WHITE BALANCE ADJUSTMENT
1 Press 991 on the remote control to enter the internal Service menu.
2 Press MENU to switch to the PW106 Scaler Menu page
3 Press ?? to scroll to Page 2-3 options
4 Press ??
to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings.
5 Press EXIT to save the new settings and exit. [Don't adjust others setting in page 2-3]
Click on the Pictures to Zoom In
BRIGHTNESS ADJUSTMENT
1 Repeat the above mentioned step 1 to 2
2 Press ?? to scroll to PW106 FE VDC Menu Page 2-1 options
3 Press ?? adjust the Brightness setting.
4 Press ?? to scroll to TV/AV/S Parameter=AV1 setting and pressuto run the setting. (This procedure will copy the settings of AV1 to S & TV)
ATSC DTV WHITE BALANCE / BRIGHTNESS / CONTRAST ADJUSTMENT
2 Press ?? to scroll to PW106 Scaler Menu Page 2-3 options
3 Press ?,? to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings
4 Press to save the new settings and exit. [Don't adjust others settings in page 2-3]
YCbCr & YpbPr of COMPONENT 1, 2 WHITE BALANCE/BRIGHTNESS/CONTRAST ADJUSTMENT
Getting COMPONENT-1 connect to 1080i signal. (The settings could not be saved if signals input from COMPONENT 2 or connect to other sources such as 720P, 480P, 480i,etc.
WHITE BALANCE ADJUSTMENT OF Component
1] Repeat the above mentioned step 1 to 2
2] Press ?? to scroll to PE106 FE ADC page 2-3 options
3] Press ?? to adjust the Offset Red and Off Blue settings.
4] Press ??to adjust the Offset Green setting.
5] Press ?? to adjust the Gain Green setting.
6] Press ?? to scroll to 480i/480P/720P Parameter=1080i setting and press ? to run the setting. (This procedure will copy the setting of 1080i to 480i/480P/720P)
7] Press EXIT to save the new settings and exit.
WHITE BALANCE ADJUSTMENT OF PC INPUT
1.Connecting to VGA Timing mode
2.Under service mode, Press ?? to scroll to PE106 FE ADC page 2-2 options
3.Press ?? to adjust the Offset Red, Offset Green and Off Blue settings.
4.Press ??
to adjust the Gain Red and Gain Blue settings.
5.Press EXIT to save the new settings and exit.
May 14, 2018 | Hannspree Televison & Video
Add/Remove Window components
Im not sure which file you are referring to but you could just a repair of the installation
this is fot the master boot record
if there are any other files , settings or programs during the repair process options for these should be available
Insert your Windows XP installation CD or recovery disc, and restart the computer.
Instead of attempting to boot Windows as it normally would, the computer will give you an option to boot from the CD.
Press a key when prompted, then wait for the setup program to load.
Press the "R" key on the "Welcome to Setup" screen.
This will cause the CD to launch the Recovery Console instead of attempting to install Windows XP on your computer.
If you have an administrator password on your copy of XP, then you will need to enter it in order to log in to the Recovery Console.
Choose the installation of Windows XP that you want to repair (generally the only option). Wait for the command prompt to appear, then enter "fixmbr." Press "y" when prompted to let the FixMBR utility overwrite the corrupted bootloader with a new copy.
Remove your XP disc or recovery disc, then type "exit" into the command prompt.
The exit command should cause the computer to reboot, allowing the computer to load the new bootloader file and then continue Windows XP startup as normal.
Hope this helps
Oct 30, 2012 | Microsoft Windows XP Professional
I have lost bbc1,2 , 3, from my free view help
get your freeview to do a search for an update of the channels, then it will pick up those that are missing.If it does not then check the signal reception as this may be the cause of it to lose these channels..Try somethng like high efficiency antenna with an internal booster.
Nov 12, 2009 | Televison & Video
Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Oct 03, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
SAMSUNG LE32R73BDX/XEU TV Digital TV Stuck on bbc1, no access to DTV menu to reset or retune. Sometimes picture is frozen, always it shows BBC banner and Mono. Standby - Info - menu - Mute - Power is not...
Sep 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
I want to do repair missing system file on my MSI notebook, but don't want to reinstall. How do I do a repair from the recovery cd which just seems to want to format and reinstall everything?
alternatively, use a windows cd as if you are installing a fresh copy. if it is xp you using, go until you accept the agreement by pressing f8. after that it will give you an option to press some keys to continue, press the R for recovery without formating, it will repair you windows and keep your data.
if it is vista, find a genuine copy, it will give you an option to upgrade you windows, and that too will not require you to loose your data, it will keep it.
alternatives can be found from my master: askleon.com.
thank you,
wonder
Sep 17, 2009 | MSI Wind U120-020US Netbook
Computer is not starting up in standard windows mode. dell media keeps popping up and when i exit the program my pc shuts down. i tried ctrl and f8 it brings me to a short menu. (1) continue restart...
Are you running Window XP? Is your computer set to hibernate? If so, you may have a hibernation error...
If I understand correctly, while pressing F8 during bootup you received a message that states:
"System restart has been paused:
Continue with system restart.
Delete restoration data and proceed to system boot menu"
You may wish to read this article about the error. http://support.microsoft.com/kb/294427
Then, go ahead and do that second option. What hibernate does is write a big file to the HD with the exact state of Windows. That is a "restoration" file. If hibernate doesn't work, deleting the restoration file will often allow the computer to restart normally.
Good luck! Please post back with your results.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 31, 2009 | Dell Inspiron 1420 Notebook
Constant sub-titles on bbc1,2,itv 1, only veiwing through virgin
I'll suppose you've got a digital cable receiver.
If so there's a text option witch you can change.
Hope it's works out for you,
Kind regards,
Gerard
Jan 27, 2009 | LG 42LC2D 42 in. LCD HDTV
Lost all pay channels only normal channals work i.e bbc1,2... etc
Just Put new keys 28/11/08
00 04 4D 6F 7D D5 C9 F7 9B
01 16 CF 0C A7 A7 14 D2 22
Nov 28, 2008 | StarTech.com StarView SV211K 2-port KVM...
Panasonic 50 in. Plasma TV Logo
364 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
