Question about Philips 42PF5521D 42 in. HD-Ready Plasma Television
Hi. My Philips flat TV will not show any picture
Hi. My Philips flat TV (model no 42PF5521D/10 )will not show any picture or sound. The red light comes on to show it is on standby and the click sound that says its switching on but nothing else. Ive tried turning it off completely and leaving it for a couple of days but still nothing. Any advice would be greatly appreciated. Thanks
    Scholar:
  • 44 Answers
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
Philip tv no picture no sound
I have the model Philips 37PF7320A/37 won't turn on and MOST articles on the Internet say it's the Capacitors capictors capictors..I checked all of them. My tv just blinked red lights, had the clicking sound at first power on, but then goes black. No sound. No picture. Nothing. Just blinking red lights.
MINE WAS RESISTOR no. 3318 , a 100 OHM RESISTOR ON POWER SUPPLY BOARD.
I BOUGHT REPLACEMENT FOR .99 CENTS SOLDER IT, AND EVERYTHING WORKED!!!
THAT WAS ALL IT TOOK.
JUST A SUGGESTION..
1. CHECK FOR BULGING CAPACITORS (90 PERCENT OF THE PROBLEM)
2. THEN CHECK FOR RESISTORS WITH MULTIMETER ( FALLS INTO THE OTHER 10 PERCENT OF THE PROBLEM.)
TELL ME IF THAT HELPS..normanw1@yahoo.com
Oct 30, 2011 | Philips 52PFL7422D/37 TV
Tv wont come on , and green light keeps flashing, tv model 42pf5521d/hd
Hallo! You might have a power trouble. Open the rear cover and take a look over the power board- that's the board where goes the alimentation cord. Look if there are not inflated the electrolytic capacitors, if yes, you must change them with the same type. Be careful with the polarity of the capacitors- you must solder them the same way as the old ones were.
May 13, 2011 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Philips Model 50PL9126D\37 Turn TV on and after a
Ur LCD inverter board is dead,must change to get ur picture back.It usally a long board.
Jan 21, 2010 | Televison & Video
42PF9966/10 - PHILIPS - UNIT NOT WORKING, NO PICTURE, PWR OK
This sounds like the power supply. I had the same thing happen to mine just before xmas. It was an $800 repair! Now my Y sustain board is gone and can't get parts. This tv is a dud!
Apr 12, 2009 | Philips 42PF9966 42 in. HD-Ready Plasma...
Flashing green ligt----------intermittent
Many problems with philips can be solved by doing a software update which is done with a flash drive in the USB port. The only problem is your model number dosen't show up on philips web site. You may want to try to email them from their site to ask why your's dosent exist.
http://www.p4c.philips.com/cgi-bin/dcbint/cpproduct_selector.pl?slg=AEN&scy=US
Mar 13, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF5521D 42 in. HD-Ready Plasma Television Logo
1,310 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
