Intel Pentium 4 2.8Ghz System PC Desktop
Problem for Intel Pentium 4 2.8Ghz System PC Desktop
Sytem wont boot
By lucky_aijaz on Jun 20, 2009
Hi I have an Intel based mother board (D101GGC) with a pentium4 processor and a 512mb DDR RAM. It was working fine until recently, when I tried switching the system on it wont boot. Actually as soon as I plug the cable and power it on, the CPU fan starts running even without me pushing the power on switch on the CPU.
Although the fan is running and the CD drive also working during this, my system wont read the hard drive nor boot. The monitor doesnt show any signs of the system booting. The HD LED on front panel which would usually glow perfectly when booting, lights up very faintly. I am confused what this problem could be. Really looking for some help from some one.
Thanks in advance.
Comments:
Jun 20, 2009
- @yboyandrei Thanks for the response. I have already tried changing the CMOS battery with a working one, it didnt help. About the power supply, u mean change the whole SMPS? Ok will try doing that. Just to let u know I have used the hard drive on another board and its reading fine. Please let me know if anything else I could try that may help.
and @niwrehs.. my monitor is working just fine, i am using it with another CPU now :P
thanks u guys anyways.
Jun 20, 2009
- Hi Dave, ur diagnosis sounds really good, thanks. Yes the lights on the keyboard flash for one as soon as I switch the power on. I hear no beeps whatsoever at all, unlike earlier when there used to be one beep while the system booted. And yeah I do remember how to get to my BIOS screen (F2 optn on my PC), I am not sure if that will help coz I tried Ctrl+Alt+Del few times and still it didnt return any results.
Jun 20, 2009
- tried that too unplugging and re-plugging. Also cleaned the golden edges of memory card with soft eraser for any static. No help, still stuck :?
Best Solution
posted on Jun 20, 2009
Helpful)
yboyandrei
Rank: Guru
Rating: 86%, 834 votes
This time your system is very ok... theres a possible reason why its automatically on without pressing the button and cannot see a device even hard disk...
Here is a tip:
1. Check the CMOS Battery maybe its weak, or try to change it a new one, and
2. Change also your power supply it might the current flow of electricity are not normal... i know its ridiculous but i experience just like yours...
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
Helpful)
davef1953
Rank: Wiz
Rating: 85%, 33 votes
I will need more information, but we can get this back up. A fan starting running is a good sign.
Do you see the keyboard lights flash on as soon as you turn on the system? You say you have nothing to the screen? Do you hear any beeps like long short short long? This would really help if you got beeps if you have no monitor. Do you remember how to get BIOS setup screen to change Date/Time or other things. Give me more extensive feedback and we'll do our best.
DaveF1953
Comments:
Jun 20, 2009
- OK, I have put on my debug hat and hope it fits right in to this problem. You have erased your CMOS and changed your battery? correct. I don't want to sound down, but could you have 2 VGA connectors on the back? This might solve no video, If plugged into the wrong one. I doubt it, but it got me before, I've seen it all. So, Keyboard lights flash on in very beginning but no numlock light stays on. We should be getting a beep code by now telling us either there is no RAM or No Video. Did you ever hear a single beep when starting the machineto working state? OK the speaker works.
Open the Machine and remove Your Ram (DDR DDR2), start your machine and you should get a sequence of beeps stating that you have no Ram. Take an alcohal swab and clean off the gold fingers before putting back ONE strip. Now power up again and there is no beep, did the monitor come on?
probably not, do the same to the second stick. Still no monitor?Hoping you have an external Video Card, remove it from the system. Turn on the system and another different sequence of beeps should have come up. Yes? If you are using onboard video, you must go into the manual and findout how to shut it off by jumpers. same test - beep code? Is your CPU getting plenty of airflow? yes. Is there a lot of clutter around the HD/CDROM area? With a multimeter, check voltages coming off extra CD or HD connector, the leads fit nicely in here. Do you have good voltages? yes. Are you running a socket 775 Processor? If you could try another, at this point you may want to. I've run out of what to do. I hope she comes back for no apparent reason and works for a couple more years.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
Helpful)
eryder
Rank: Apprentice
Rating: 88%, 2 votes
it sounds to me like its locked up...unplug all the power supply"s connection to the motherboard and hdd,disk drive ...ect... wait about 15 minutes and then hook all the connections for power up again...I hope that this works for you, Skip
P.S.
also tak out the memory and clean the connectors on the edge with an erasure soft one...sometimes the memory can mess up the boot cycle...
Was this helpful?
Yes
No
Solution #4
posted on Oct 11, 2009
Not Rated)
Vaio Tech
Rank: Wiz  Computer Hardware  Expert
Rating: 80%, 39 votes
whell i see this problem a bit triky but there we go look seen you post a diagnose really very expert and very clear see one last steep if you have a modem plug in in your motherboard unpluget please maibe is bad and keep all the system from boot up or even post bios beeps if no help post back a i will keep a eye on this ok thanks
Was this helpful?
Yes
No
Solution #5
Not Rated)
niwrehs
Rank: Guide  Computer Hardware  Expert
Rating: 88%, 4 votes
you said that there is no reaction with your monitor.May be your monitor have the deffect
Was this helpful?
Yes
No
Popular Solutions for Intel Pentium 4 2.8Ghz System
Questions and Unsolved Problems for Intel Pentium 4 2.8Ghz System
Do you recommend Intel Pentium 4 2.8Ghz System PC Desktop?
Answer
Answer
trying to connect to Gnutella network using Bearshare 5.2.5
Answer
Full screen programs keep getting minimized
Answer
connecting to the Gnutella network with Bearshare 5.2.5
Answer
i am having intel(R)celeron(R) cpu 240 audio drive is not working if sigma tel audio drive will set... (More)
Answer
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Intel Pentium 4 2.8Ghz System...:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
