Question about Netopia 2247NWG-VGx Wireless Router (2247NWGVGX)
My router will not communicate with my laptop wirelessly. It works fine by cable just over wi fi it won't work
  • Claudio Barata
    Claudio Barata May 11, 2010
    Can you detect the router from your laptop?
    Genius:
  • 1,269 Answers
You might have missed to type your network key. Connect to the wireless network again and make sure to type in the correct wireless network key
Posted on Jun 21, 2009
Wi-fi connection gets disconnected frequently and reconnects by itself. Tried to reinstall the wi-fi drivers but no improvement. The same laptop is working perfectly at another wi-fi environment.Tried to...
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 01, 2013 | Computers & Internet
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
WIRLESS NOT WORKING
First turn on your wi fi switch on laptop.
Then go to my netowkr places proeprty and make sure your wi fi network adapter driver is installed and enabled.
Then click on view available wi fi networks then check you get signal form wi fi router.Then it works.
Let me know if you need more assistanse.
Aslo you can check in router that wireles is enabled in router?
For that connect your wi fi router to computer with ethernet cable then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
typoe user as "admin' and password as "admin" or blank or "password"
then check in wireless settings that it is enabled.
Thanks.
Sep 24, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Have a linksys router and adapter not sure how to install, my daughter wants to use her laptop but cant get the internet
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Thanks.
Aug 29, 2009 | Linksys Wireless-G WRT54GS Router...
I can not browse using wireless.what can i do .i have instailled the drivers and yet is not working. my wifi is not coming up. if i use lan i will browse. the product is acer4315. pls help
First check your wi fi network adpater driver installed and working fine also check it is enabled.
Turn on wi fi switch on your laptop.
Check that you get signal from router very good strength.
you can access your router with defaults link.
http://192.168.1.1
or http://192.168.0.1
connect your router to computer with ethenret cable then access above link
then check in router configuration that wireless is enabled .
If it ask for user enter "admin" and password as "admin" or blank or "password"
Aug 25, 2009 | Acer Aspire 5100 Notebook
Getting wireless to work on my Dell Inspiron 1000
find switch on laptop it is wi fi network adapter switch on laptop turn on it.
Then also check your wi fi drivers are installed.
if driver are not install for wi fi downlaod from here in netwrok
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_CEL_1000&os=WW1&osl=en&catid=&impid=
then install wi fi then check.
Jul 14, 2009 | Dell Inspiron 1000 Notebook
Connect Additional Computers to my network
ok
first install your wi fi network adapter driver in computer also if you have laptop then there is switch for wi fi on it.
Then go to my ntwork polaces there you see your wi fi network.
Also check your wi fi enabled in router .
Let me know
Jun 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Wireless local only
You should try to uninstall and reinstall the driver for your wi-fi adapter on your laptop. Also, you can try to connect to a different wireless network like a hot spot or coffee shop for you to determine if the router is faulty or the built-in wi-fi adapter of your laptop.
Nov 01, 2008 | Linksys Computers & Internet
Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
118 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Elise Lacoursiere
Elise Lacoursiere
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
