Question about Garden
Lawnmower has trouble starting, but runs
Re: Craftsman 7.0 self propelled lawnmower
Starts, but takes several pulls. Engine backfires sometimes and will puff black smoke when that happens. Once it starts, runs fine. Any suggestions? Thanks.
p.s. Recently replaced spark plug with E3 Diamondfire brand.
  • Anonymous Mar 25, 2014
    One side is loose but other will not depress.
  • 10,865 Answers
Hello. Did you replace the air filter? If not check it and replace it if it is dirty. Finally get a carbeurator cleaner such as seafoam which you add to the fuel at the rate of one ounce per gallon. This will get the inside of your carbeurator cleaned up. Do these things and you should be back in business.
Posted on Jun 20, 2009
Craftsman 6.0 eager-1 self propelled lawnmower starts then stalla after 3 seconds
there is a fuel problem somewhere. more likely the carburetor bowl has water or debris in it. clean it real good.
Apr 30, 2017 | Craftsman Garden
Lawnmower Makes Squealing Sound when Self-Propell is Used
if you take it apart there will be no warranty . take it to where purchased and get it repaired
Jul 21, 2015 | Troy Bilt 5.5hp Self Propelled Mower
How do I install part no.183281 ( engine zone control cable ) onto a craftsman rotary lawn mower model no. 944.366362 ?
Hi Robert,
I'm not usually a Lawn Mower Expert, but I think I may have an answer for you. Assuming your craftsman rotary lawn mower is similar to this self propelled craftsman mower (they should have the same basic parts), this video should help!
Self-Propelled Craftsman Lawnmower Drive Cable Repair
Sep 05, 2013 | Garden
Lawnmower wont start after running then stopped for short period
It should be. The fuel line is under the tank and runs to the carburetor. Make sure you use the fuel shut off, if you have one, or drain gas before you play with the line. Once you find the line disconnect it from the carb and drain any remaining fuel. Then clean with a pipe cleaner and reattach. That should help.
Apr 17, 2013 | Craftsman 190cc 22" Rear Drive...
Self propelled lawnmower starts and then stops after two minutes mowing lawn
clean the carburetor jets out thoroughly with carburetor cleaner and a strand of wire through all openings. this is a common problem with the engine dies a minute or so after it starts up
Jul 03, 2011 | Craftsman Garden
I have a Craftsman self-propelled lawnmower that will not start.
first remove air filter and spray starting fluid in the carb? if it starts the fuel is the problem carbs are easily removed and cleaned make sure needel is not stuck? if it dosnt start chexk for spark pull rope hold screwdriver over wire touch it too plug end see if you see spark if not? then you must test zone conrol cable and grounds? did you hit something hard with the blade if so you could have a sheered flywheel key it will trow egine out of time ?
Aug 27, 2009 | Garden
Craftsman 6.75hp self propelled mower starts and turns off
I think that this is a 4stroke engine and runs on neat petrol.Have you been putting oil in with the petrol like a 2 stroke engine needs because this would account for the smoking.If not the check that you havn't overfilled the gearbox oil.
Jun 12, 2009 | Craftsman Garden
Starts, runs, and dies...starts, runs and dies...starts, runs, an
Sounds like a common fuel problem you need to remove carb & fuel tank and unless you can get a compressor they need a good blast out you may even take carb apart & check diaghram they have very small jets in fact most lawnmower shops have a sonic bath for this
Apr 25, 2009 | Poulan Pro " Pro" Self Propelled Mower
Under load the engine sputters and backfires.
I had the same problem; The first 2 years the engine ran fine and then the third year it started backfiring, so I put a new carburetor on my engine and the same thing happened. The real problem was the valves needed adjusted. Yes I know, this is very rare, but it did happen. I decided not to try this adjustment myself and opted for a mower shop to do it. It cost about $50.00 and the engine has been fine ever since.
Mar 21, 2009 | THQ The Lawnmower Man
Garden Logo
226 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
