Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman mower LT.1000 17.5
Mower runs for a little while then starts cutting off,i push in the clutch and it try,s to run ,but still cuts off,HEIP
  • 10,865 Answers
Check the air filter and replace it if it is dirty. Also, get a product at an auto parts store called seafoam, a carbeurator cleaner, and add it to your fuel at the rate of one ounce per gallon of fuel.
Posted on Jun 20, 2009
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Mower starts and runs, blades turn but will not move, what could be the problem?
the blades and the trans use 2 different belts also is it a automatic drive and the release lever that you pull out to push it?
Apr 05, 2012 | Craftsman Garden
I have a 42in cut 19.5hp automatic trans craftsman when i press the clutch/brake to start then release to drive it cuts off also if i try to engage the blades it cuts off but if i lock the clutch/brake it...
The problem is in the seat safety switch or associated wiring. Lift the seat, find the switch, and take a look for a connector that is off, a broken wire, or a loose or broken mounting for the switch. If all that seems ok, remove the switch and put tape across the plunger so it is activated. Run the mower and see if the problem is solved. If not, replace the switch - it's not expensive. Parts are available from Sears online or at their stores. You'll need the model number of your tractor. Good luck! Please rate my solution if helpful.
Aug 01, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Cuts out when I let out the clutch
try and find a relay, near the engine, which is connected to the safety switches attached to the seat and clutch/brake pedal. you may find that relay to be bad, or you need to replace or short the safety switches. If you short them, might be a safety issue as the engine and blades will run unattended. Seems to be a very common problem with craftsman lawn tractors.
Jun 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Apr 18, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
I have a Kraftsman 91.5 42 inch cut model #
Safety switch at seat or reverse. Mower will cut of when blades are engaged if you get off the seat or put into reverse. Check these switches for stuck on, damaged, disconnected, or just plain broke. Good luck.
Mar 19, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Push mower runs then quits!!
My toro mower starts and will run for ablut 15 minutes and starts to cut out and eventually stop running. What could be the problem
Apr 01, 2009 | Craftsman Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
769 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
