Question about Whirlpool Duet GHW9150P Front Load Washer
F 02 Error Message
My washer is not draining. I keep getting error F 02?
    Brigadier General:
  • 8,619 Answers
Hi!
If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F/02 error code will be displayed.
Potential Causes
Check the drain hose and make sure it is not plugged or kinked.
Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects.
If still the problem persists then you need to replace the pump.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 20, 2009
Whirlpool duet washer error code f-02
Error F-02 is a slow drain problem. Remove lower front panel. You will see a circular door. Be prepared for a lot of water and junk, maybe keep some old towels ready. Open, clean out, check pump which comes right behind it - see that blades rotate freely; refit carefully. You are done, for the next six months or so, depending on usage.
Click if helped
Apr 14, 2013 | Whirlpool Washing Machines
My Kenmore HE 3 washer keeps stopping mid cycle and beeping showing an F 02 message. We cleaned out the hose but it is still doing it. If I unplug it and do the spin/drain cycle again it will work...
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Kenmore HE3T Washer
It keeps stopping and then we get a F 02 code
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Here's the Handy Hippy's guide to HE Bliss
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F02 Error message
57f1973.jpgUse a nutdriver (1/4th in) to get that bottom panel off.001354b.jpgaab6887.jpg
Jul 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting an F 02 error on my washer. what do I need to do?
Hi,“F02” is a Long Drain error.If the drain time exceeds 8 minutes this error code will be displayed.In addition, a “SUDS” error may also be generated as a secondary error.This is an indication of a drain pump problem and/or clog in the drain line.You will need to check the following:
  1. Check the drain hose to make sure it is not kinked or clogged.
  2. Check the electrical connections to the pump and ensure the pump is running.
  3. Remove the drain pump filter and check for foreign objects and/or debris.
Thanks and take care
May 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite error message F 02
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 10, 2010 | Kenmore Elite 45986 Front Load Washer
Got an f 02 message, now the door is locked and will not open. Have unplugged and then plugged in again, still locked and cannot unlock and need to get clothes out. What is an F 02 error?
F01 refers to Long Drain Error.
Reason -
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
What Needs to be Done -
* Check the drain hose
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 13, 2009 | Kenmore Elite 45986 Front Load Washer
My washer show error(f-02
F-02 means that it had a long drain. if the drain exceeds 8 minutes the water valves tuen off. sheck to see if there is a sud error. some of the cuases would be drain pump might be clogged, the drian hose might be kinked, there are foreign objects in the pump.
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
182 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
