Question about HP iPAQ rx5935 Travel Companion Pocket PC
Hp ipaq rx5935 hangs at the end of the HP booting sequence
Hp ipaq rx5935 hangs at the end of the HP soft reset booting sequence with the HP blue screen. I have to take the battery out to switch off. The hardware was working fine and the software also worked when the HP initial error messages were concelled. When battery replaced or USB power applied, the unit starts soft reset sequence again with subsequent hang.
Remove battery for 6 hr and reinstal and then hard reset.
bob.
Posted on Aug 26, 2009
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
How can i install the latest version Windows Mobile on my HP IPAQ rx 5935 Travel Companion?
Simple answer: you can't, sorry.
All Windows Mobile versions are customised by the supplier to suit the specific device that they're sold with, that's also why Microsoft do not provide the end-user with any support at all for WinMo and refer all such matters to the vendor instead.
HP never released an update even to WinMo 6 for your device, so you are stuck with the original WinMo 5.
Jul 01, 2011 | HP iPAQ® rx5935
Im download app into my hp ipaq,then it hang/jam...it not running like usual..
For hanging/Jam problem, few factors can be involved, First of all you have to check, how much space is being left in phone memory after installing particular applications, To check the settings, Go to settings, Memory,
Solutions:
1. Soft Reset,
Try resetting the device while hold down the End Key for few seconds, when the phone is switched off take off battery for few minutes, then try putting the battery again, It will clear the memory used by the softwares,
CAUTION: Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.
2. Hard Reset
Hard reset will restore your Ipaq to factory default settings, Perform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.
settings.
NOTE: The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center). bilalseham_6.jpg
if you require more assistance feel free to reply to this post
Thanks for using FixYa
Regards-BA
Jan 27, 2011 | HP iPAQ 510 Voice Messenger Smartphone
Won't get through blue HP startup screen.
try taking battery out for 6hours then reinstall and hard rest.
this works on mine. bob
Jul 07, 2009 | HP iPAQ rx5935 Travel Companion Pocket PC
Hp pocket pc.Travel companion,turns on,but can't view anything
I don't know how long you've had that unit. So the question is have you done any updates on it since you've had it.
An update most likely will fix most problems.
Follow this link to get to your devices' support page. It would be a good idea to bookmark it and register so they can send you any needed update alerts for your iPaq.
Dec 02, 2008 | HP iPAQ rx5935 Travel Companion Pocket PC
HP Ipaq 2910 wont finish the boot
Hey :), I'd be happy to help. I honestly don't think that you've physcially damaged your Ipaq, so you should probally hard reset your Ipaq. To do this you must hold down the reset button and the power button at the same time for like 5 seconds. This will get rid of data on your pocket pc, but It might solve your Ipaq's problem. Thanks! and I hope this helps, if it doesn't I'd recommend for you call Hp where they will repair it or give you a new one :)
Sep 01, 2008 | HP iPAQ H2210 Pocket PC
Ipaq 2490 hangs on booting
Try this:
4. Make clean reset (hold callendar + itask, then press and hold reset), after about two seconds you will hear knack. Now unhold these buttons. The screen will be black.
5. After that make hard reset (hold callendar + messaging + power and then press and hold reset) after about two seconds unhold reset button first and after about one seconds remaining buttons. You will see on screen PS FORMAT.
6. Now is you iPAQ ready.
Nov 24, 2007 | Computers & Internet
Soft Reset
Just loaded a safe mode program to my iPAQ, and now it seems to reset without any problems, even when not connected to the sync cable.
Sep 12, 2005 | HP iPAQ RX3115 Pocket PC
Hanging
Do you think you could provoke a hard reset by leaving the battery out overnight?
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ rx5935 Travel Companion Pocket PC Logo
1,398 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
