Question about Bose Lifestyle 28 System
Bose LS 28 - No sound at all
My Bose Lifestyle 28 doesn't play any sound. Tried checking all cables, checked powersupply for Subwoofer. No luck.
5 Suggested Answers
SOURCE: HDMI cable between TV and Lifestyle 28
Did you set up your bravia TV to receive pictures throuh HDMI ?
Posted on Dec 28, 2008
cjackHD
  • 71 Answers
SOURCE: Bose lifestyle 28 no power
There's no easy way to put this. This media center will need a repair. If you know the outlet works, and the power supply works. It couldn't be anything that's easily fixable. Make sure you don't have a dual-voltage power supply (red switch for 120v/230-240v). If so, change to 120v for us power. Otherwise this is pretty straight forward. You can call bose for a repair- 800-367-4008. $165 + tax flat rate. New 1 year warranty.
Posted on Jun 21, 2009
SOURCE: PS3 to Bose Lifestyle 28
hey, this is how i have mine set up.
Bose to PS3 via Digital Audio Optical
PS3 to TV via HDMI
This way you can get Full 5.1 surround sound, and good picture quality, also, go to the bose menu and set the optical source to your PS3.
Posted on Mar 31, 2010
SOURCE: Bose Lifestyle 28 Sound Problem
I also get this problem sometimes with mine. Usually when you call Bose they suggest that you do a "hard" reset meaning you unplug the power cord from the wall and wait about one min. Then plug the unit back in and it should work.
The other thing that you can try if the system still isn't working is to check that all the wires running into and out of the sub-woofer are all plugged in and aren't loose.
If either of these two solutions don't work you can alway call Bose tech support @ 1-877-210-3782 (they are open Monday Friday: 8:30 AM 8:00 PM ET)
Posted on Apr 08, 2010
Testimonial: "Thanks for your support. Unfortunately i had to send the system to Bose for repairs. Thanks anyways. "
Bose lsps speaker system
First, please check that you have everything switched correctly. If you still have no audio, any functions, but the unit turns on, you may have DC Offset, meaning a damaged amplifier. For more information, please contact me at audioserviceclinic.com. Thank you.
Oct 31, 2013 | Bose Lifestyle 28 System
Hello, We have Bose Lifestyle 12 system. It has been working great until now for 10 years. We moved homes locally with in town. Now when I tried to hook up my system, there is no sound coming out of the...
Please check if the AC cord of Acoustimass module has a good connection to AC outlet, also check all the connections specially the cable that goes to the system control unit jack, for your reference in the link below you can see and download the manual of your Bose system:
http://www.bose.co.uk/GB/en/images/Lifestyle%2012%20Series%20II%20Home%20Theater%20System_tcm6-4071.pdf
Mar 04, 2011 | Bose Lifestyle 12 System
Mar 31, 2010 | Bose Lifestyle 28 System
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Can I connect my pc to a lifestyle 28 system
If you want to connect your PC's audio output to the Bose Lifestyle system, simply get a cable with 3.5mm stereo male plug on one end, and dual RCA male plugs on the other end. The 3.5mm side will plug in to your PC's LINE OUT jack. The two RCA male connectors will plug in to the Bose AUX IN jacks. On the Bose console (or the remote control) select AUX as the audio source. Your PC's sound will play through the Bose Lifestyle system.
For persons having a large library of MP3 music files on their PC, this is a great way to listen to the music on your hard disk.
Nov 28, 2009 | Bose Lifestyle 38 System
Bose lifestile 5 sound from the right speaker exit only
may be problem in the main unit change the IC or check the cable inside the main unit
Jul 11, 2009 | Bose Lifestyle 28 System
Can not get any sound to work on my bose 28 life style system first time using it. and got a new tv
If you have no sound from any source (CDs and radio included) then check the Audio Input cable at the back of the media center. Make sure it's plugged into the top portion of the 'speakers' section into where it says "main" and not "BoseLink"
If this is fully connected, but still no audio- check to make sure your Acoustimass module (subwoofer on the floor) is plugged into a working power outlet. If that fails, try unplugging both power cords for the system for about 30 seconds.
May 31, 2009 | Bose Lifestyle 28 System
Dec 28, 2008 | Bose Lifestyle 28 System
Will not play rented DVD's
This may sound silly, but have you tried a DVD lens cleaner?
Oct 18, 2008 | Bose Lifestyle 28 System
Bose Lifestyle 28 System Logo
379 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
