Question about Maytag Atlantis MAV6000 Top Load Washer
Spin cycle dosen't work - Maytag Atlantis MAV6000 Top Load Washer
  • 10,865 Answers
Hi i can help. let me list all of the possible problems to help determine exactly what is wrong.
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jun 20, 2009
2 Suggested Answers
FitzOriginal
  • 842 Answers
SOURCE: my mastermind 708 dosen't spin
Your empty pump filter is blocked with debris. If it can't evacuate all the water then it wont allow the spin cycle to start. Locate the filter (probably behind a little door at the botton of the front of the machine). Remove, clean and remove the debris, re-fit and all will be well
Posted on Jul 01, 2011
Dosen't spin unless i open and then close the lid.
Possible there could be some loose connections on the panel board or the controller unit circuit which gets activated when the door is shut. Try to tap instead of opening the door to confirm a loose joint. If not it is related to a RESET fault within the controller , please check the door switch and connections to the controller.
Dec 31, 2012 | Washing Machines
Blade brake dosen't work right away when switch is released. Takes a couple seconds of slow spin then the brake seems to stop the brake. Suggestions?
All blade brakes take a moment to stop the blade. If it were to engage as soon as the switch were released the inertia of the blade would do damage to the saw. Look at videos of your saw on youtube to ensure it is operating the same as others.
Jun 12, 2012 | Ridgid Reconditioned 12 In. Compound Miter...
I push start button and it humm's and dosen't spin i open the top of the dryer and then push the start button and the push the drum to jump spin it and then it work's.any thought's
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Dryers
My mastermind 708 dosen't spin after wash cycle.It spins fine in the wash cycle but dosen't drain water or spin in the spin cycle.Pease help
Jul 01, 2011 | Westinghouse Washing Machines
The door dosen't open because the spin didn;t work
Hi - i have requested further details on your machine, without any luck from your end.
This is what I think you have left the machine in a pause cycle where it wont spin & dry. You may not be aware of this but you have not replied as to the model of the machine I cannot tell you how to disable it.
Find your user manual for details/informations to disable it, otherwuse open the little door in the bottom left if there is one , pull the lever to open the door and turn it back on, see if it works,,
Some feedback would be appreciated.........
Jun 18, 2011 | Miele Washing Machines
Chevy 2004 blazer ac stoped working abruptly and stops the engine if you turn on the ac could you just replace the clutch if that is what is defective? instead of the whole compressor and all the other...
I mworking on my blazer AC unit now . You have a problem with the compressor clutch or the compresser Its likely the clutch its supposed to cycle about 8 times per minute . So it goes on then off 8 times per munite this is normal . However if the clutch dosen't spin then the belt will drag on the clutch pulley this will stall the engine until the belt wares out but this will damage every part that the belt rides on . The water pump the alternator powersteering pump and belt tenisinor not to mention the belt .It sounds like your clutch is seized try not to run it until you can figure out why the clutch isn't spining
Jun 12, 2011 | 2004 Chevrolet Blazer
Fisher and paykel ecs washing machine.The agitator dosen`t turn any more so the clothes aren`t getting clean.The spin is working ok.What could the problem be??
This can a problem with the program controller unit as during the cycle there is no power to the motor so as to agitate.
You will need to check the controller , try with another program if not check the output when the wash cycle is on.
Feb 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
Kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Nov 12, 2009 | Washing Machines
Doesn't change cycles, first spin and rince cycle doesn't work at all
Sounds like you have a bad timer Does it spin on final cycle? (Spin Cycle)
May 11, 2009 | Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
222 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
