Question about Kenmore Elite 45986 Front Load Washer
Flashing F 2
Oh man, what have I done? I was washing throw rugs. Big mess, water not draining and this F2 light
  • babalou Nov 04, 2007
    I have a Kenmore Elite HE3t.
    Yesterday during the wash cycle the pump made a drinding noise, the machine went into drain mode but the barrel would not turn.
    It flashed F2.
    My husband took it apart and we found coins in the catch basin part of the pump. Cleaned it out but the pump still makes a noise and is unable to pump the water completely to the top of the hose to drain. We ordered a new pump. Any other suggestions and can the pump failing to work properly really have a drastic effect on how the cycle works?
  • 146 Answers
Your drain pump is definitely blocked/jammed. Remove drum to pump hose from pump, after unplugging the machine from the wall socket, and clear any obstruction within the hose and/or pump chamber. Also clean out front filter.
Posted on Nov 03, 2007
Kenmore he2t
fluff may have blocked the filter or jammed the drain pump. you need to check these
May 07, 2014 | Washing Machines
Washing machine won't drain. I had washed an old throw rug and there is still water in the tub.
There is a coin trap in the pump most likely is pluged // u have one machine that is very hard to write down how to take apart as you have to remove the door lift top remove front panal .. pump is on the lower right ..I would leave that one to a pro if you never done one before......good luck
Feb 01, 2011 | Maytag Neptune MAH5500B Front Load Washer
Hi..we washed a rubber backed rug and the rubber came off and the water will not fully drain. we washed several empty cycles since with no results
You will have to take the hoses off between the tub and pump, and the pump and weall drain. They are packed with rubber. Oh, don't forget to clean the inside of the pump too. Run clean water through all hoses and the pump before reinstalling and you should be fine. Don't wash rubber backed rugs in washers unless you go to the laundry mat. This should be put in the maintenance guide of your washer book, but I've yet to see it.
Feb 03, 2010 | Malber P21 Front Load Washer
How do you wash one rug? I can't get the machine
You dont say how big this rug is, but I am guessing its not big enough to spreadevenly around the machine. The machine senses an imbalance and willo not spin or failos to spin at a rate that would rekove the water. Try adding some balance to the drum with another object that will evenly spread the load to see if that helops to get rid of the sopping water.
BTW any pictures of you whipping the rug around in the backyard? That should make for Utube fame!
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer does not spin a lot of water out of rugs.
does it even spin? check for broken coupler by checking for tub movment when opening lid when you hear motor in spin. if good check that machine advances to spin from neutral drain automatically. let it enter spin from rinse on its own. first it will drain without spin. after 2-3 min of drain motor will pause (with clank) then restart in spin. This pause can be accomplished by opening lid and closing as well but the timer should do it on its own. if bad replace timer.
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Kenmore@Heavy Duty Washer - 70 Series
ck lid switch ..rug may have gotten off balance first spin and broken lid switch
Aug 28, 2008 | Washing Machines
Front load washer
You need to clean out your outlet filter; this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain if the outlet is clogged.
Nov 02, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
106 people viewed this question
Sal De
 Brian Main
Brian Main
