Question about Karcher 2500 PSI Pressure Washer
PRESSURE WASHER PETROL 3600 PSI 13HP GENERIC HONDA with intermittment jet spray help?
freetek
  • 5568 Answers
SOURCE: not enough pressure
Speed regulation on small engines is notriously fussy.
Check the linkage to the carburetor and look for a small, light spring.
If there are several holes for one end of it, you may have to try more than one to find the spring tension that lets the engine run steadier than it now does.
If not, then either replacing it or changing the length by shortening or lengthening it will probably be needed.
Posted on Aug 09, 2008
  • 83 Answers
SOURCE: honda pressure washer cuts out when lance trigger released.
You most likely need to set your valve clearances. If it is hard to pull over or the recoil snaps back after starting your valves need to be set for sure. This may not be the entire problem but it is a good start. Also change the spark plug, a bad plug will cause odd problems and is too cheap not to eliminate as a source. In addition check your fuel, pour a little out into a white container (I like spray paint can caps for this) and look at the color. If it is yellow to orange it is bad. You can pour it into you car, the car electronic sensors will compinsate for it quality but a small engine can't. Use a NGK BP6ES or BPR6ES plug.
You need:
Feeler gages
10mm open end wrench
14mm open end wrench
1 long shaft screw driver or rod
1 spark plug socket and ratchet
Remove the spark plug and the valve cover. Pull the recoil over slowly until the intake valve opens (intake is closes to the carb and it will go down when it opens). Now put your long screwdrive down the spark plug hole. Slow pull the engine over until the screwdriver handle is at it highest point, this is top dead center. It may take a few attempts. Now check your valve clearance between the rockers and the top of the valve. The intake should be .006 and the exhaust .008, both can be +/- .001. To adjust: hold the large nut with the 14mm then loosen the small one with the 10mm. Lefty loosey. Now turn your large nut until you get the correct setting and then tighten the small one the lock it in. It may take a few attempts and alway reverify your setting after you lock it down. Once done, find top dead center again and reverify. Now your valves are set.
Posted on Mar 31, 2009
  • 18 Answers
SOURCE: cleaning solution isn't siphoning to washer wand
you need to use i believe the black tip where there in least pressure it does not work with pressure
Posted on Jun 27, 2009
  • 548 Answers
SOURCE: I have a 3000 psi karcher pressure washer with
sounds like you need a seal and bladder rebuild < if you liver in a cold environmet for winters please dont forget to winterize your washres every year before winter
Posted on Sep 15, 2009
  • 623 Answers
SOURCE: excell pressure washer honda motor---have fuel
Sounds like the carb is badly clogged internally. If you can remove it yourself, you can soak it overnight in a can of carb cleaner. But keep in mind some of the internal passageways in the carb are as fine a human hair and soaking may not work, it which case go to plan B, new carb. Last resort you could try to find cleaners small enough to get in the passageways of the carb, I've heard of people using wire brush bristles for example. Today's gas is terrible, it does not take long to gum up the carb, if it sits for any time.
Posted on May 03, 2010
Testimonial: "you nailed it..........shitty fuel and clogged main jet..........lets see if it still runs today..Thanks"
Pull cord compartments have come off
With your question, I'm not sure if your looking for another or what your specific needs are but I believe this is it.
http://www.ebay.com/itm/NEW-PULL-START-RED-RECOIL-COVER-11HP-13HP-FITS-HONDA-GX340-GX390-/111147183055?pt=LH_DefaultDomain_0&hash=item19e0e36bcf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Oct 02, 2013 | Simpson WaterBlaster Commercial Gas...
BLACK MAX ACTS LIKE CARB IS CLOGGED BUT GAS AND CARB BOWL FREE..IS THIS AN AUTO SHUT OFF FEATURE? HAVE OIL IN ENGINE AND TRIED WATERPRESSURE AND THEN W/O PRESSURE. -ADVISE?
There could be gunk in other parts of the carb. Id take it off and spray out some of the ports/jets. Be careful of the carb cleaner spraying back in eyes!
Jun 09, 2011 | Honda Black Max 2600 PSI Pressure Washer
I have a gpw-3000 petrol power washer. the metal plate which is held on with 3 bolts which is on the intake side where the water goes in has cracked due to frost in a garage. where can i get a replacement...
http://www.dultmeier.com/catalog/0.901
http://www.pressurewashersupplies.com/pressure_washer_parts.htm
http://www.google.com/search?source=ig&hl=en&rlz=&q=honda+pressure+washer+parts&aq=1&aqi=g10&aql=&oq=honda+pressure+
Hope this helps!
May 09, 2011 | Honda Pressure Washer PSI 3000
Power washer stalls after spraying
Your pressure relief valve may not be working. If that happens when you shut off your spray gun, then pump is dead heading, stopping the motor. If this is the case it stops dead, not coasting. Either replace the pressure adjusting relief valve or remove it, and disassemble it and clean it.
Jul 18, 2010 | Honda Pressure Washer PSI 3000
13hp honda motor what is the right psi for it
It will depend on the pump that you have but the most common versions will be the 13HP PC4-35324 which is a direct drive unit or a PG4-35324 which is a belt drive unit. In both cases the machine would be 4GPM at 3500PSI.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
800.247.8103
503.255.6508
Jun 03, 2010 | Honda Landa PG 3500 PSI Pressure Washer
I need to buy a pressure washer for residential/commercial work
Were I to pick from one of those three, I would pick the Landa. The most reliable pumps are Hotsy and since Karcher bought Landa and Hotsy, those three brands now have Hotsy pumps, though it doesn't say it on the machines.
Jan 01, 2010 | Honda Pressure Washer PSI 3000
Honda 13hp pressure washer cant get gas to my carburator
Hi there
If you have a Honda engine there's a fuel screen filter under the tank .
To get to it you have to remove the tank and turn the tank over so you can acess the filter. There's only 3 bolts holding the tank .
Check also the shut off gas valve by the choke .
Hope this help
Aug 29, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
282 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
