BOSCH MAXX AUTO WASHER. FILLING AND EMPTYING OK,. BUT DRUM NOT TURNING TO WASH OR SPIN. WHEN I TAP MOTOR WITH RUBBER MALLET, DRUM WILL TURN AND MACHINE WILL DO A WASH. IS IT NEW BRUSHES REQUIRED? APPROX HOW MUCH?
  • 31 Answers
Sounds like your brushes have worn down hey are not that much only 20 min job
Posted on Jun 22, 2009
I have a bosch washing machine Maxx WF1200.The machines fills with water than stops. Nothing happens. Also does not spin to release the water. What is the problem?
If the machine heats the water and finishes the cycle without the drum turning it is most likely your motor or what controls it.
Sep 30, 2014 | Bosch Washing Machines
Bosch Maxx wfl 1300 washing machine - drum making loud squeaking noise.
sounds like bearing have failed or the stainless steel drum has detached from its carrier open the door and try to move the drum up and down there should be no movement at all if there is machine will need to stripped down
Mar 03, 2014 | Washing Machines
We have a bosch maxx it will fill up with water
motor or drive problem this can be a couple different situations depending on if your unit is belt driven which would be a easy fix you have to be able rto take off the upper cover to inspect the motor drive area
Apr 28, 2010 | Washing Machines
Bosch Classixx 1200 - Drum not turning
It could be the motor itself (is there any overheating smell from the motor) or it could be the capacitor which controls the motor. I had a similar problem and it turned out to be the motor brushes. I replaced the brushes and all was OK.
The only other thing that could be wrong especially if it overfills with water is the water level switch (this is a pressure switch on the side of the washer) You can easily check this by removing the hosepipe to the switch and blow gently into it, you should hear a clicking sound) This might be the clicking that you heard so it is probably Ok.
Aug 08, 2017 | Bosch Washing Machines
Bosch Maxx WFL 2061 motor starts running and then stops
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace pkurdnirund@hotmail.com , peacepattaya@gmail.com
Nov 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machine fills and emptys but does nothing else.....
sounds like the drum belt has come off the pully or at worse broken.quite simple to mend.good luck.
May 05, 2007 | Bosch Exxcel WFO 2465 Front Load Washer
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Washing Machines Logo
245 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
