Question about Dell Dimension E510 PC Desktop
I installed internet exlprrer 8 virsion & restart my pc my net connection stop to work. ihave a window xp proffessional2000
5 Suggested Answers
  • 131 Answers
SOURCE: dvds wont play on pc
You can install another DVD player software.
there are plenty of free players on the internet that you can download, or you can buy one at your local software dealer. Once you install this, the newer video codecs should be installed
Posted on Mar 12, 2009
Blu3Demon
  • 76 Answers
SOURCE: Windows Installation on Dell GX150 PC it took more than 10 hrs.
by the sounds of it your processor which is the brain of your computers is damaged you can either replace the motherboard of purchase a new computer because 8hrs is a long time for a installation
Posted on Mar 13, 2009
ODCaloney
  • 260 Answers
SOURCE: internet wont connect on dell pc
Give this a try, read the information first.
Winsock XP Fix download here.
Posted on Mar 20, 2009
ravynnsloft
  • 93 Answers
SOURCE: Hello, I've a Dell with
You need to not only set the sata option to ata but you need to use the F6 optioin and use the raid/sata driver provided by dell. it is a pain but this should fix your problem....after a successful install go into device manager and reinstall the driver using the ahci driver and all should be good. also try not to use a USB keyboard as the usb drivers are not that stable. Hope this helps.
Posted on Nov 04, 2010
How can I fix windows 10 installation error c1900101?
  • Disable (preferably uninstall) your Antivirus utility before attempting the upgrade.
  • Restart a few times and try again.
  • Disable General USB Devices (example - Smart Card Reader).
  • If you are using a SCSI hard disk, make sure you have drivers available for your storage device on a thumb drive and it is connected. During Windows 10 setup, click the Custom Advanced Option and use the Load Driver command to load the appropriate driver for the SCSI drive. If this does not work and setup still fails, consider switching to a IDE based hard disk.
  • Do a clean boot and try again.
  • If you are upgrading using the .ISO file, disconnect from the Internet during setup, if you are connected by LAN (Ethernet) or Wi-Fi, disable both and attempt setup again.
  • If you are updating through Windows Update, when the download reaches 100% disconnect from the Internet LAN (Ethernet) or Wi-Fi and proceed with the installation.
  • If that does not work, try using the .ISO file to upgrade if possible.
  • If you are connected to a domain, switch to a local account
  • If you have any external devices attached to the machine, disconnect them (example, gaming controllers, USB keys, external hard disc, printers, non-essential devices). If you are installing Windows 10 using Windows Update, try the following:
    1. Press Windows Key + X on the keyboard and then select "Command Prompt (Admin)" from the menu.
    2. Stop the BITS, Cryptographic, MSI Installer and the Windows Update Services. To do this, type the following commands at a command prompt. Press the "ENTER" key after you type each command.
    net stop wuauserv
    net stop cryptSvc
    net stop bits
    net stop msiserver
    3. Now rename the SoftwareDistribution and Catroot2 folder. You can do this by typing the following commands in the Command Prompt. Press the "ENTER" key after you type each command.
    ren C:\Windows\SoftwareDistribution SoftwareDistribution.old
    ren C:\Windows\System32\catroot2 Catroot2.old
    4. Now, let's restart the BITS, Cryptographic, MSI Installer and the Windows Update Services. Typethe following commands in the Command Prompt for this. Press the ENTER key after you type each command.
    net start wuauserv
    net start cryptSvc
    net start bits
    net start msiserver
    5. Type Exit in the Command Prompt to close it and then restart the computer.
May 14, 2018 | Computers & Internet
Tip
Removing IE 8
<p>If you have problems with Internet Explorer 8, you might want to try <a href="http://support.microsoft.com/kb/956197/LN/">Compatibility View</a> or our <a href="http://support.microsoft.com/gp/pc_ie_v8intro">guided help</a> <span> </span>to see whether you can fix the problem. However, if you just want to uninstall, or remove, Internet Explorer 8, this article helps you do that.<br /><br />When you remove Internet Explorer 8, your earlier version of Internet Explorer is restored with your customizations (such as add-ins, Favorites, and your home page).<br /> <p><b>Resolution:</b><br /> <p>To uninstall Internet Explorer 8, follow the instructions for your version of Windows. To follow these steps, you must be logged on to Windows as an administrator<br /> <p><b>Important:</b> You cannot uninstall Internet Explorer 8 if it is set as not removable. This occurs if you install Internet Explorer 8 before you install Service Pack 3 (SP3) for Windows XP. If this scenario applies to you, then you must uninstall SP3 before you can uninstall Internet Explorer 8. For more information about this issue, click the following article number to view the article in the Microsoft Knowledge Base: <br /> <p><a href="http://support.microsoft.com/kb/950719/">950719</a> You cannot uninstall Internet Explorer 7 or Internet Explorer 8 after you install Windows XP Service Pack 3<br /> <p>To uninstall Internet Explorer 8, follow the instructions for your version of Windows. To follow these steps, you must be logged on to Windows as an administrator. <br /> <p><b>Steps for Windows 7</b><br /> <p>To uninstall Internet Explorer 8, follow these steps: <br /> <p>1. Close all programs. <br />2. Click StartCollapse this imageExpand this image, and then click Control Panel.<br />3. Click Programs and Feature.<br />4. In the tasks pane, click Turn Windows features on or off.<br />5. In the list of windows features, clear the check box next to Internet Explorer 8.<br />6. You receive a warning message in a pop-up window. Click Yes.<br /> <p>Internet Explorer 8 will now be uninstalled. The system will restart after the installation. <br /> <p><b>Steps for Windows Vista or for Windows Server 2008</b><br /> <p> loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> Close all programs. <li> Click Start</b>, and then click Control Panel</b>. <li> Click Uninstall a Program</b> under the Programs</b> category <li> In the Tasks pane, click View installed updates</b>. <li> In the list of installed updates, double-click Windows Internet Explorer 8</b>. <br /><br /><b>Note:</b> If Windows Internet Explorer 8 does not appear in the list of installed updates, try the <span><b>alternative steps for Windows Vista or for Windows Server 2008</b></span>. <li> In the Uninstall an update</b> dialog box, click Yes</b>.<br /><br /><b>Note:</b> If you are prompted for an administrator password or for confirmation, type the password, or click Continue</b>. <li> Follow the instructions to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer. </li></ol> <p><b>Steps for Windows XP or for Windows Server 2003</b><br /> <p> loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> Close all programs. <li> Click Start</b>, and then click Control Panel</b>. <li> Click Add or Remove Programs</b>. <li> In the list of currently installed programs, click Windows Internet Explorer 8</b>, and then click Remove</b>.<br /><br /><b>Note:</b> If Windows Internet Explorer 8 does not appear in the list of installed updates, try the <span><b>alternative steps for Windows XP or for Windows Server 2003</b></span>. <li> Follow the instructions to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer. </li></ol> <p><b>Alternative steps</b><br /> <p><b>Alternative steps for Windows Vista or for Windows Server 2008</b><br /> <p> loadTOCNode(3, 'moreinformation'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> <p>Carefully select and then copy the following command: <br /> <p><b>FORFILES /P %WINDIR%\servicing\Packages /M Microsoft-Windows-InternetExplorer-8*.mum /c "cmd /c echo Uninstalling package @fname && start /w pkgmgr /up:@fname /norestart"</b><br /> <li> Click Start</b>, and then type <span>Cmd.exe</span> in the Start Search</b> box. <li> In the list of programs, right-click Cmd.exe</b>, and then click Run as administrator</b>.<br /></li></ol> <li> Right-click inside the Administrator: Command Prompt window, and then click Paste</b> to paste the command that you copied in step 1. <li> Press ENTER to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer.</li> <p><b>Alternative steps for Windows XP or for Windows Server 2003</b><br /> <p> loadTOCNode(3, 'moreinformation'); To uninstall Internet Explorer 8, follow these steps: <br /> <ol> <li> <p>Carefully select and then copy the following command: <br /> <p><b>%windir%\ie8\spuninst\spuninst.exe</b><br /> <li> Click Start</b>, and then click Run</b>. <li> In the <span>Open</span> box, type <span>Cmd.exe</span>, and then press ENTER. <li> Right-click inside the Cmd.exe</b> window, and then click Paste</b> to paste the command that you copied in step 1. <li> Press ENTER to uninstall Internet Explorer 8. <li> When the uninstall program is finished, restart your computer.</li> <li> <b>More Information:</b></li> <li> After you uninstall Internet Explorer 8, you may notice Application event log errors after each reboot. To resolve this problem, delete the following Internet Explorer User Accelerators and Internet Explorer Machine Accelerators registry keys in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\GPExtensions: </li> <li> {7B849a69-220F-451E-B3FE-2CB811AF94AE} {CF7639F3-ABA2-41DB-97F2-81E2C5DBFC5D}</li> <li> <b>The information in this article applies to:</b></li> <li> Windows Internet Explorer 8</li></ol>
on Mar 15, 2011 | Computers & Internet
Tip
How to increase your internet by 20% ?
If you use Windows XP Professional then it is possible to squeeze an extra 20% out of your internet connection. By default Windows XP Pro holds back 20% of your Internet speed for various services like windows update and spyware checks.<br />If you want to tap into this locked speed then make the following changes:<br /> &bull; Go to Start-&gt; Run-&gt; and type gpedit.msc<br />&bull; Expand the Administrative Templates branch<br />&bull; Expand the Network tab<br />&bull; Highlight QoS Packet Scheduler<br />&bull; Click on Limit Reservable Bandwidth and check the 'enabled' box<br />&bull; Then Change the Bandwidth limit % to 0 %<br />Once you've done this click apply and restart your PC. After rebooting you should see a noticeable improvement in your net speed.
on Jan 22, 2011 | Microsoft Internet Explorer 8
I have 2 windows 7 & 8 how can i sueich togethre without restart
Virtual setup. Use Win 7 as the host, because I like it better jk. Then Download VMWare player (free) and make a Window 8 image. MS also has a version of this, but VMWare is the sh*t.
It will look and feel like a program, but its an OS. The images can handled like file and moved around. They can even be networked. Only drawback in your case it will use some of your resources, but even these can be managed. Easy to use and setup. Have fun.
Nov 25, 2012 | Computers & Internet
Sir i have 3110c nokia how is connect pocket internet with pc
steps to be followed to connect the 3110c nokia mobile net to pc -
1 . install an antivirus, update it & scan the pc
2. install the pc suite . http://en.kioskea.net/download/download-1092-nokia-pc-suite
3. restart the pc after installation & connect the mobille to the pc , check if the mobile gets detected in the pc
4 . if the mobile is detected in the pc , u can use net by creating a new set up in internet optons .
please let me know if u mobile is detected in pc , i will gide u with further steps
Oct 14, 2010 | Computers & Internet
OK, Internet Explorer 7 or 8 will not work on my computer. It mysteriously stopped working. I use Firefox but sometimes I need IE. The page just says connecting, connecting and when it stops...nothing on...
Check your add-remove and see if Microsoft .NET Framework 2.0 service pack 2, 3.0 service pack 2, and 3.5 SP1 are installed. If not, you will have to go to windows update and get them if you want to use IE 8.
Jul 23, 2010 | Microsoft Internet Explorer 8
The new IE 8 set up can not uninstall old version of IE 8 What to do? Win XP prof 32
Click START
Open Control panel
Open Add/Remove Programs
Click on Windows components Tab
Uncheck Internet Explorer in the list
Click OK - Continue with the Instructions and Restart the PC
Try opening I.E 8 or Installing, If not follow the above steps and Put Check on I.E and Restart PC and later Start I.E 8 Installation
Jun 17, 2010 | Microsoft Internet Explorer 8
Explorer 8 removal
Steps for Windows 7 loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps:
  2. Click Start Collapse this image Expand this imagevistastartbutton.jpg, and then click Control Panel.
  3. Under Programs, click Uninstall a program.
Steps for Windows XP or for Windows Server 2003 loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps:
  2. Click Start, and then click Control Panel.
  3. Click Add or Remove Programs.
  4. In the list of currently installed programs, click Windows Internet Explorer 8, and then click Remove.
    Note If Windows Internet Explorer 8 does not appear in the list of installed updates, try the alternative steps for Windows XP or for Windows Server 2003.
  5. Follow the instructions to uninstall Internet Explorer 8.
  6. When the uninstall program is finished, restart your computer.
Please rate the answer. Thank you!
Apr 27, 2010 | Microsoft Internet Explorer 8
There's a virus in my asus eee pc 2G surf and hard to connect to the internet. is it better to reformat it? How?
Check Two Solution:
Install Antivirus - Install new Symentec Antivirus Updated copy, and scan all Internet file, folder & Computer.
If problem presists - then format your Notbook or only your Notebook 'C' Drive
To format -
Windows XP installation:
1. Restart your notebook - and immedietly click on F2 key/Del button
2. Boot your computer from CD Drive
3. save your setting
4. it Running System File.
5. Then Create partition press Enter-(Delete previous partition)-press 'L'to delete your 'C' partition, If you want delete all partition, same delete like C drive.
6. Select 'C' Drive press enter to format partition choose option NTFS or Fat32, and Enter
7. It's running automatically then enter operation system windows CD Key and press enter
8. It will take time 30 to 35 min. Depending upon your RAM speed.
9. It will complete automatically and PC restart.
Feb 01, 2010 | ASUS Eee PC 2G Surf Notebook
Remove IE 8 & Replace w/ IE 7
go to control panel from start menu and then go to programs and features. under programs and features look for windows IE 8. and click on that and uninstall.
or other wise if you don't see it there click on show all installed updates on top left corner. then under installed update lists fine windows IE 8. and uninstall them all. it will prompt to restart coimputer. restart computer you will get windows IE 7.
Dec 16, 2009 | Computers & Internet
Dell Dimension E510 PC Desktop Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
