Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Kenmore freezer upright frost build up on door
Kenmore has frost build up on door top section and on the door flap that is in front of the light, Ice also builds up at the bottom of the freezer. Freezer is only 1.5yrs old and has been doing this for the past 6 mths
First just take it out and clean that one carefully .And then set correctly and observe it,s working condition.then also it's not working means show it to ur near by worker those who repairs it
Posted on Jun 20, 2009
Kenmore upright freezer not freezing
Kenmore & Whirlpool refrigerator frost build up in freezer not ...
? 7:02
www.youtube.com/watch?v=gVXT7pZyk_o
Sep 12, 2013 - Uploaded by ApplianceVideo.com Service a Kenmore Upright Freezer which has the following problems: Not Cooling Properly At: http ...
Freezer Troubleshooting - What to Check Before You Call a ...
www.realestate.com > Realestate.com Blog > Articles
Aug 12, 2012 - Alternatively, if the freezer is in a defrost cycle, it will not kick on immediately, the temperature ... Refrigerant circulates through coils, spreading coldthrough the unit interior before .... We have a kenmore upright deep freezer.
Sep 19, 2015 | Kenmore Freezers
I have an old side by side we notice water on the floor every couple of days when we looked inside there is a ice build up and I guess when the fridge defrost ice bilds up and freezes and then water comes...
Hello, The drain behind the back panel in the freezer is frozen or blocked up. Remove the back panel remove as much ice as possible and pour boiling water in the bottom section under the evaporator. be careful not to touch the aluminum it will cut you or break. you will see the drain hole sometimes it takes a while to thaw all the ice. Hope this helps and please rate me Thank You.
Jun 07, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Drain plug freezes up and ice builds up in freezer then leaks into frig. How do you keep the drain free from building up?
Use a turkey baster filled with very hot water and flush it several times. That should resolve the problem. Also check the door gasket, if it is leaking, excessive frost would be visible causing more water then the system was designed to handle.
Good Luck,
Gil
Feb 28, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frost forming on top of inside door by hinge
you probably have an air leak. if the gasket is bad it needs to be replaced. Air could also be coming in through the door flap if you have water and ice dispensor on door
Sep 17, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frost build up on 1 shelf then 2 shelf and so on - hard freeze on top soft freeze on bottom upright 7.5 freezer
door gasket sealing properly kids hanging with door open? condenser clean? if its a forced air condenser if it is a static freon problem. Tom
Jun 16, 2009 | Kenmore 7.5 cu. ft. Upright Freezer 28702
Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Mar 27, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
427 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
