Question about ASUS Computers & Internet
Nonitor wont Turn on
My monitor wont start after power on the CPU.
I have checked the power cables.
    Sergeant:
  • 220 Answers
Thats an hardware issue preventing the computer to boot up.
Please refer to your vendor for faulty hardware, or comment this question for further support
Posted on Jun 20, 2009
I just bought Logitech Clearchat Premium PC, how do I get it to work?
Assemble it: connect the data cable from the monitor to the CPU, Connect the mouse and keyboard to the CPU, connect the power cables for the CPU and for the monitor, press the CPU power button, and the monitor power button. If the computer doesn't work, then it came without an operating system.Get the operating system disk and insert it into the DVD or CD ROM/RW drive. Turn the computer off, and turn it on again. Check the monitor carefully and when it prompts for pressing any key to boot from the cd, do so very fast. The process of operating system installation will start. Follow the procedures and instructions it gives you till the end. If you are not sure of any step, ask or consult any person who can assist.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | Computers & Internet
Wont start up
Check physical connections first, check monitor cable if securely plugged in and then check power light of monitor. If power light on monitor is amber or yellow it means that monitor is not getting a signal from cpu/ tower. Try to do a power drain on the computer, remove power cable at the back of the computer and then press and hold the power button for 10 secs, after that plug in power cable again and restart the computer.Check if there is any connection if not then try to use another monitor, a known good one. If you get a video from another monitor it means monitor is already defective.
May 15, 2010 | HP Pavilion a1610n PC Desktop
Cpu will not turn off with the button. Screen
check whether the power cable for the monitor is ok or not....
and for the power button .. go to start | control panel | power options
when i press the power button
select shut down
ok...
Dec 19, 2009 | Gateway GT5016E (RBGT5016E) PC Desktop
My monitor wont come on it says it has no signal i turn onpc but monitor is blank
First open cpu cabinet then REFIX RAM memory.
Pull cmos cell for 10 minutes then all settings are defaults.
Then reconnect vga cable from your monitor to cpu vga port.
Then when you power up press continue F8 key so you can see safe mode and other menu then enter in enable vga mode then go to control panel then dispaly property then settings then change screen resolution to 1024*768 then apply and ok.
Then restart and check .
Aug 18, 2009 | Gateway 507GR PC Desktop
My computer cant turn on and its making noises
Did you your CPU Fan inside, that's the one who make some noises inside.
If your computer is failing to start then check CPU inside, all the peripherals double check on it. From VGA Card, Memory and other devices, maybe its not properly connected inside. Good luck!
Jul 29, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
Emachine T6520 Wont Start Up
Check your num lock key status press it on and off if hum lock led is on and off when u pressing then your cpu working fine. so check connectiopn of vga cable cpu to monitor.
Also some times display screeen resolution issue so when u power up press F8 key then enter in enable vga mode then you can chang escreen resolution to 1024*768.
but if num lock key is not on and offf then open the cabinet of cpu then find cmos cell on mother bord and pull it for 14 minutes then check .
Jul 04, 2009 | E-Machines eMachines Desktop PC
Mobo giving startup problem!
you have to narrow down the issue.. is it with the pc? or monitor? if you think the cpu... is the power supply fan working? is the cpu overheating? if you think its the monitor...be sure the card is seated properly and check all cables
May 30, 2009 | Intel D845GVSR Motherboard
I have a pavillon a6421 uk hp computer when i turn it on the monitor comes up with no vga signal (i have changed the graphics card and it is still the same) have done all the trouble shooting options...
Hi
First Check the power cable of ur monitor whether power is coming or not..
Then remove signal cable (which is connect the cpu) and then switch one the power, check whether any msg is coming in screen.(like no signal or no connection) if it comes means u want to check the cpu or else their is problem in ur monitor..
Connect the another monitor with ur cpu.Whether ur cpu is working properly..
Sep 19, 2008 | Computers & Internet
Starting problem
check the processor fan is working or not. check its connector. Also check if there is any beep sound.
if processor fan is ok then disconnect all the cables, data and poewer cables. plug the power connector to motherboad only and listen if there is any beep sound there.
tell me after doing this, if problem doesnt solve.
regards,
Jul 27, 2008 | Computers & Internet
EMachine won't turn on
unplug the power cords and let it sit for about 5 to 10 min. just like the cable box sometimes the brains have to be reset than make sure all plugs a lined up and tight .
Hope this gets ya back on line.
Dec 01, 2007 | E-Machines eMachines Desktop PC
Computers & Internet Logo
46 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
