Question about Nokia 7610
Memory stuck? i can't do anything on my phone. Once i press any button, d phone tells me 'not enough memory to perform this please delete some data. but it just doesn't allow do that because dat message shows once you touch any button. i can only send and answer calls but not even my contacts are displayed.
  • 83 Answers
Take your battery out as well as your mem stick and let sit for 1- 2 hrs the seat everything correctly and try again if problem continues send to manufacturer
Posted on Nov 02, 2007
Keeps saying low storage need to do an update on phone as i havent anything stored opn it an i have 4gb sd card
It seems all your applications are stored in the Phone Memory and/or your application data is taking up lot of memory. Consider performing the following steps:
  1. Go to Settings --> Applications --> Manage Applications. In this Menu you'll be shown a list of applications. Use the Menu Button to "Sort by Size" and get a list of the applications sorted from high memory usage to low (phone memory). Once this is done, you'll be able to view the memory being used by each of the applications. Click on the applications which you see are consuming more memory and then use the "Clear Data" button to clean up the data being stored by the applications to free up memory. This clears up any cache, cookie, temp files associated with the applications. Depending on your android version, you may also see an additional button "Move to SD Card". The best option to get more space would be to use this button and move the application to the 4 GB SD Card storage.
  2. Optional Step if you do not have "Move to Phone/SD Card" option available - From the Android Market, download and install "App 2 SD Free". Once done, this application should help you free up a lot of space by moving applications from your phone memory to the SD card.
Hope this was helpful. If so, please consider rating this solution.
Mar 08, 2011 | HTC Desire Cell Phone
I have a Dell axim x5 and it is stuck on a blue screen with the Dell logo. I have tried a maste reset like hold the power botton and the reset for 2 sec but after that i get a screen with the option clear...
Perform a Reset
Soft Reset
When you perform a soft reset, the device deletes any data that has not
been saved but saves any data that has been stored in memory. Try
performing a soft reset if the device does not respond when you tap the
display or press a button.
To perform a soft reset, use the stylus to press the reset button.
Hard Reset
NOTICE: When you perform a hard reset, you lose all the data stored on
your device.
Perform a hard reset if:
• You want to delete all the data stored on your device.
• You forget your password and need to clear it.
• Your device is experiencing severe operational problems and you have
already attempted a soft reset.
NOTICE: It is strongly recommended that you back up your data before you
perform a hard reset. See ActiveSync Help on your computer for more
To perform a hard reset:
1 Press and hold the power button.
2 With the stylus, hold the reset button for about 2 seconds.
3 Follow the instructions on the screen.
Feb 12, 2011 | Computers & Internet
General:not enough memory to perform operation.delete some data first in nokia 3230
Its software problem.To fix it press*#7370# by code 12345.Your phone will be back to factory setting but may be some data in your phone would be loose. good luck..
May 20, 2010 | Nokia 3230
I have nokia 3230.. when i play any vedio or mp3 or 3gp... its give me this error.... "GAllery: No enough memory o perform operation. Delete some data first..."
Well as the message suggests. delete some data to free up some memory and try again. if that doesnot help maybe you MMC card is corrupted.
Mar 03, 2010 | Nokia 3230
It tells me that I don't have enough memory and should delete data files App 8004 and App 8002. I don't know what I can remove without damaging the performance. What can I move to the extra card I have
To start you can delete safely any music or video file.
If that is not enough to fix the problem, then the best thing to do is resetting the PDA to factory settings after backing up all your personal data.
After backing up your data with HotSync, perform a hard reset, this will erase all applications and returns your device to its factory default settings.
1. Hold down the power button on the front panel of the PDA.
2. While holding down the power button, use a paper clip to press the reset button.
3. Release the power button.
4. You will get a message warning that you are about to erase all the data stored on the PDA, do the following:
Press the top scroll button on the front panel
to complete the hard reset and display the startup screen.
If you press any other button you will do a soft reset, that will not fix the problem. In that case restart the procedure.
5. After doing hard reset the unit will return to the initial factory state. All third party installed applications will be deleted, and setting will be reported to factor default.
Mar 02, 2010 | Handspring Visor Deluxe Handheld
Nokia N70.sms sned and recv problem showing delete some data
try to reformat your phone first turn off your phone and press hold * 3 call sign and turn on your phone you must hold press those key until your phone is reformatted
May 25, 2009 | Nokia N70 Cellular Phone
My N73 phone has problem.Its memory always states "NOT ENOUGH MEMORY TO PERFORM OPERATION DELETE SOME DATA FIRST.I already deleted many datas like pictures and music..but it is still the same. please help...
My N73 phone has problem.Its memory always states "NOT ENOUGH MEMORY TO PERFORM OPERATION DELETE SOME DATA FIRST.I already deleted many datas like pictures and music..but it is still the same. please help me.
Jan 05, 2009 | Cell Phones
Music memorynot enough memory to perform delete some data
i have problem with nokia n72 plz solve the problem
Jan 01, 2009 | Nokia N72 Cellular Phone
Nokia 7610 Logo
57 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
