Question about NetGear RangeMax Dual-Band Wireless-N Router with 4-Port Ethernet Switch
ADSL setup problem for O2
Setting up a netgear WNDR3300 on O2 and i cannot find the setting to change the multiplexing method to LLC based so that i can change the VPI and VCI setting. Please can you help
  • ingenito
    ingenito May 11, 2010
    did you log into you router from your web browser? netgear's are usually 192.168.1.1
    default user name is admin and password is "password" usually all your setting are in there. if you already knew all this, sorry!!
  • 1,272 Answers
You need to manually configure the router.
Connect a computer directly to the router using ethernet cable and access the router page using address http://192.68.1.1
Username = admin and password = password
Click on ADSL settings in the left hand side menu. Enter the requred infor VPI= 0 VCI =101. Select the required multipexing mode.
Hope this helps.
Posted on Jun 20, 2009
  • Anand Gupta
    Anand Gupta Jun 20, 2009
    I aplogize the information provided was for ADSL router and not for cable/dsl router. The router you have is WNDR3300 and will not work with your ADSL conection form O2. You need to configure ADSL modem in place of WNDR3300.
    suggested models are DGN2000, DG834G
  • Anand Gupta
    Applogies. This router will not work with ADSL connection. you need to have ADSL router like DG834G to connect to internet throug O2 ADSL connection
I recently installed a netgear wndr3300 router at my home. I went through the setup process with no problem, and everything checked out ok. But when i clicked finished, a screen popped up saying the ip...
If this is the case, the setup wizard detected an IP conflict between the router and the modem. It means that the modems IP address is in the same range as you router so it has to be changed. If the IP address of your router was changed to 10.0.0.1 , you should be able to connect to the internet. Try accessing the routers setup page by opening a browser and type 10.0.0.1 at the address bar. It will ask you for a username or password. Type admin for the username and password for password (this is the default settings). If it does not work try to remember if you already have changed the username or password. Once you are in, enable the mac clone option. Check if it works.
Apr 18, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Tip
Configure Netgear DG834g Router
Simple :
First check the (i) or DSL light of the router if it is on the check Number light is on or not..if any one of the number light out of 4 yes there would be 4 no. lights on the router which represents port or u can say ethernet ports of the router.once that light is on then you are ready to configure your router.Default ip of the netgear router would be 192.168.0.1 by typing this in the address bar of the router u will get the access to the router page.Then click on basic settings put in your user name and password provided by ur isp. put encapsulation pppoE instead of pppoA and save then go to adsl settings and chose the multiplexing as llc based and save after that ur good to go
on Jul 13, 2010 | Computers & Internet
Trying to first-time install netgear model DG834v4 ADSL2+ in my iMAC with Mac OS X 10.4.11, so (according to manual) I cannot use Wizard and must do manually. Wiring is OK, I am connected to ADSL network...
Since the DG834v4 is a modem and router inbuilt they have mentioned ''Log into the ADSL2+ modem router'' .
The default IP to logon to the device is 192.168.0.1.
Just open your Safari web browser and type 192.168.0.1 in the address bar.
It will ask for User Name adn Password.
The Default User ID and Passwrd is "Admin" and "Password" (enter without quotes)
On the Top Left you'll find "Basic Settings".Select it and enter the desired User name and Pwd. (Make sure to choose PPPOE or PPPOA, to find out contact Internet Service Provider)
Again on the Top left select "ADSL Settings".
Select "LLC-Based" or "VC-Based" under Multiplexing Method.
Enter VPI and VCI Number (Again to findout Contact your Internet Service Provider)
Mar 10, 2010 | NetGear DG834 Router
Internet won't come up. I talked to the cable company, and we disconnected the belkin router and internet came up. I tried to reconnect it to the router, and it still won't come up.
Sounds like ADSL setings might be incorrectly configured.
RESET your Router (Remember: All your settings on the Router will be Lost)
Login to your router.
Check the Basic Settings and recheck your User ID and Pwd.
Check whether your ISP using LLC-based or VC-Based Multiplexing method.
Check VPI and VCI range.
Run diagnostics on your router and check it recieved any public IP, hope this helps
Feb 13, 2010 | Computers & Internet
How do I connect my Arris TM502G to my Netgear WNDR3300? I go through the setup and it says error cannot connect to the Internet. I need help.
Please let me know who is your internet service provider(ISP)
then i can give you instruction how to setup router
Happy to help
Thanks for using Fixya
Jan 17, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
How to install and will this box allow my desktops(2 of them ) to both be connected to a wireless network?
There are 2 ways to setup Netgear
1. Setup Wizard (which guides you through a setup wizard)
2. Manual Configuration (you need to put all values in router manually)
Here we are not discussing Setup Wizard as Manual configuration is far much easier then auto configuration
To configure (config) Netgear we need to get into router page
To open router config page
1. Open Internet Explorer (Start>>all prog>>Internet Explorer)
2. Type in address bar 192.168.0.1
3. In username box type admin (where it says gateway 192.168.0.1 requires username & password)
4. In password box type password (word password itself)
After this you will find Netgear ADSL Wireless Router Setup page
Here we need to select Basic Settings (as shown below)
after this you will find next page as
Here in this page (Basic Settings Page)
Does your internet connection requires login, Select Yes
Select Encapculation as PPPoE
Login is Username as provided by your ISP
Password is your password for broadband connection as provided by your ISP
Keep Idle timeout as 0
after this simply press apply without changing anything else
Now We Need to click on ADSL Settings Page
Now on ADSL Setting Page We got only 3 options
Multiplexing Method Should be LLC-Based
VPI 0
VCI 35
now just press apply again
By this time your router should be only (you can check it by opening any website on Internet Explorer or by router status option on netgear page)
To Config Wireless
Click on Wireless Option (on left hand side blue panel)
It should display next page as
Here in this page
Wireless Network Name (SSID) Alpha-Numeric name which would be displayed as your wireless network name
Region Here Select Your Region
Channel: Select whichever channel give you best sighal (9, 11, 13 are recommended)
Keep the TIck on Enable Wireless Access Point
Keep the Tick on Allow Broadcast of Name (SSID)
Can Untick Wireless Isolation
Then Jump to Security Options
Select WPA-PSK (Wi-Fi Protected Access Pre Shared Key)
then in WPA-PSK Security Encryption type in anything of your own choice but alphabets and numbers both should be there and make it between 8 to 63 characters long.
WPA-PSK Security Encryption Key is your password for wireless network
Now Press Apply and your router is ready for wireless too
After doing this you can change MTU (Maximum Transmit Unit) size to 1400 from WAN Setup Option
You can find WAN Setup Option in same blue panel on left hand side of screen
Here you just need to change MTU to 1400 and need not to change any other setting
Now its all done and router is ready to send wireless signal to your system/laptop
Nov 26, 2009 | NetGear WGR614 Wireless Router
Zyxel 660HW DSL LED keeps flashing
Try to change the Local or LAN IP Address of your Zyxel to 192.168.5.1 and do not configure the Zyxel router for PPPoE Connection. It should be configured as Obtain IP Automatically or Automtic DHCP.
Oct 21, 2009 | Zyxel Prestige 660HW Wireless Router...
NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 11, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
ADSL issues
It seems that you will have to configuer the modem manually. Cöntact ur service provider and ask for the following info: adsl username adsl password VPI AND VCI, MULTIPLEXING METHOD. Once u have these info, follow the steps below on a wired computer connected to the router. 1. Open browser and type the address as http://192.168.0.1 or http://www.routerlogin.com. 2. Login with username as admin and password as password. 3. Click on Basic settings and enter the username and password. Click on ADSL settings and enter the required info. Rate it, if it helps.
Aug 01, 2009 | NetGear DGN2000-100NAS Router
Unable to install after 81 %
If the setup CD is unable to setup your modem/router (it is also called a "gateway") you can do the router configuration via the Web User Interface of the router. you will need ADSL settings such as:
a. Encapsulation mode. (typically PPPoA or PPPoE)
b. Multiplexing: (it can be LLC or VC)
c. Virtual Circuit Range.
d. Username & Password (ADSL UN/PW)
note: All of these ADSL settings should be provided/given to you by your ISP/ADSL provider. You can call your ISP for this settings.
just notify me if you will need further assistance doing this, but first make sure you have all the settings for ADSL.
Apr 18, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
NetGear RangeMax Dual-Band Wireless-N Router with 4-Port Ethernet Switch Logo
354 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
