Question about Sport & Outdoor - Others
B/D CM600 LAWN MOWER. INSTALL NEW BATTERY. HOW DO I REMOVE AND REPLACE THE COVER? THERE ARE TWO CLIPS ON THE FRONT END. DO I NEED A SPECIAL TOOL TO OPEN THEM?
  • 5 more comments
  • cjhcpa Jun 23, 2009
    1) B & D CHARGES $ 50 MORE FOR THE BATTERY THAN OTHER SUPPLIERS.
    2) TRIED TO DOWN LOAD THE MANUAL, BUT MY BROWSER REPORTS "SITE UNRESPONSIVE" EACH TIME. IS THERE ANOTHER SITE? MY WIFE WANTS THE LAWN MOWED. h
    FINALLY GOT THE "USER" MANUAL TO DOWNLOAD. I NEED THE "REPAIR" MANUAL TO SOLVE MY PROBLEM. CAN YOU HELP? h
    SORRY, I NEED THE REPAIR DETAILS. I"M GOING TO USE A DIFFERENT EXPERT. h
    IF I COULD COPY THE REPAIR MANUAL, OR GET DETAIL INSTRUCTIONS ON HOW TO REMOVE AND REPLACE THE BATTERY, I BELIEVE IT WOULD SOLVE MY PROBLEM.
    I WILL TRY TOMORROW. I HAD THE COVER OPEN AS MUCH AS I COULD, REPLACED THE BATTERY, BUT WHEN I CLOSED IT, THE COVER DID NOT FIT WELL.
    IF I PULL THE COVER LOOSE FROM THE SPRING CLIP, THE OPENING IS STILL LIMITED BY THE CUFF ON THE HANDLE. IN USE, HE CUFF KEEPS THE HANDLE FROM LIFTING.
    WILL THIS INTERFERE WITH THE BATTERY REPLACEMENT PROCESS AND CLOSING?.
    THE LAWN MOWER IS AT HOME AND I USE AN OFFICE COMPUTER. h
  • cjhcpa Jun 25, 2009
    CAN YOU GIVE ME MORE ADVICE ON REPLACING THE BATTERY. I REMOVED THE OLD ONE (BEFORE CONTACTING FIXYA), BUT I CAN'T GET THE COVER TO CLOSE PROPERLY AN THE MOWER WILL NOT START. I AM IN OVER MY HEAD ON THIS. THANKS h
    I HAD OPENED THE MANUAL, BUT I DID NOT SEE ANY REFERENCE TO REPLACING THE BATTERY. h
  • 2,176 Answers
The site that you need for the repair manual is Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number to get to the page with a parts explosion. I briefly looked at it and it appears that there are 2 bolts on the back of the cover and then you would lift the back and slide the 2 flats on the front out to remove it. Also a concern is that about a 1/3 of these parts are no longer available. If you need any more help let me know and have a good day.
Posted on Jun 25, 2009
  • 296 Answers
goto this link it will help
http://www.repairfaq.org/sam/lmfaq.htm
Posted on Jun 24, 2009
  • Rakesh Kumar Jun 25, 2009
    well thats why i have provideid u the pdf link.it has the steps n diagrams which will help u.
    Top Expert:
  • 81,400 Answers
THE COVER JUST PULLS OFF. SPRING CLIPS
Posted on Jun 23, 2009
  • 13,433 Answers
Hi
Here is the user manual for your unit:
http://users.turkuai.fi/users/niohtone/cm600.pdf
You will need a pdf reader to open the file, if you don't have one or you can't open the document get one from here: http://get.adobe.com/reader/
yes you will most likely require special tools to open the safety screws , I 'm not sure about the clips.
But note that
Battery recycling
Black & decker service centers will ensure that a non-performing batteries from black and decker products will be disposed and recycled. FREE INSTALLATION IS OFFERED WITH THE PURCHASE OF A NEW BATTERY. CALL YOUR NEWRST SERVICE CENTRE FOR DETAILS
If you can't get to the battery yourself it would be best to get in touch with B&D to get the battery replaced free aslong as you buy a battery from them.
if you need anything else or if you have any questions, let me know.
Thanks,
Ekse
Posted on Jun 20, 2009
  • Ekse Jun 23, 2009
    Simply click on the link to open the document.
  • Ekse Jun 23, 2009
    probably a better, higher capacity battery or maybe you have been looking at the wrong type of battery there.
    I don't have a service or repair manual for it.
Pull cord broke of mower starter
Go buy part at Home Depot or wherever. Remove top cover. Remove pull cord housing. Install new pull cord housing. Replace cover.
Oct 09, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Trying to change u-joints front and rear on driveshaft? any advice or assistance would be appreciated..
firt you will need to remove the drive shaft by un bolting it from the rear end. U joints are held in with a small clip on some, others have a cover which is bolted on over the end of the u joint. once you remove the clips or cover drive out u joint with a hammer replace with new one insert clips or cover install driveshaft greese all fittings.
Sep 01, 2011 | 2003 Ford F150 Regular Cab
How do I change the drive belt on a 7021r mower? The drive will move the mower on pavement but not on the grass
First, you need to make sure you have the right tools for the job. You'll need a wrench, work gloves, mower blade clamp, drain pan and fresh fuel. Check your owner's manual for the correct belt to your specific lawn mower. Belts that are not specifically designed for your mower will not fit properly and may wear down prematurely. Next, remove the spark plug wire. This is a safety precaution to prevent the mower from accidentally starting.
Now you can remove the screws that secure the drive cover to the mower deck. Once you've taken off the drive cover, loosen the screw that holds the belt tension spring to the transmission. As the screw is loosened, tension on the belt is released allowing you to remove the belt off of the front transmission pulley.
At this point you'll need to turn your mower on its side to take off the mower blade. Be sure to use a work glove to protect your hand when removing the mower blade. You can use a lawn mower blade clamp over the blade to secure it. Unscrew the bolt to remove the blade and then the engine baffle. Once the pulley unit is exposed, you can remove the entire drive belt. Insert the new drive belt and place one end on the rear pulley and re-attach the engine baffle. Then, place the mower blade back (making sure it's facing the correct way with bottom of the blade facing the ground) and tighten the bolt. Remove the clamp and return the mower to its upright position so you can place the other end of the belt to the front pulley. Remember to tighten the screw to the tension spring.
Put the front drive cover back on, tighten the screw that secures the cover to the deck and reconnect the spark plug wire. Add new fuel to your mower and you're done!
May 14, 2011 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
How to change the drive belt on a Toro 20016 SP Mower
The Toro 20016 mower is a front wheel drive mower and fairly simple to change the belt on. Start by disconnecting the spark plug to prevent start ups while working on the machine.
Remove the blade and adapter. The adapter includes the pulley for the belt.
two screws under the mower, with 3/8 heads hold the black cover over the belt. remove the cover and now you will see the transmission
The transmission, depending on the year of your machine will have a guard holding the belt on. Bend or remove the guard to remove the belt. Install you belt in reverse order.
You can get parts and special tools like the blade stop at a store like www.arcolawn.com
Feb 23, 2011 | Toro Lawnmower Lawn Mower Sp Drive Belt...
Need to replace 2003 corola front wheel bearings. need step by step instruction please
Removal & Installation To Remove:
  1. Remove the front wheel.
  2. Remove the front axle hub nut.
  3. Disconnect the front stabilizer link from the strut.
  4. Disconnect the speed sensor (with ABS).
  5. Remove the front brake caliper and rotor.
  6. Disconnect the tie rod end.
  7. Remove mounting bolts and nut and separate the lower control arm from the ball joint.
  8. Using a plastic hammer separate the front axle shaft from the hub.
  9. Remove the 2 mounting bolts from the strut. Remove the knuckle and hub assembly.
  10. Remove the lower ball joint from the knuckle.
  11. Remove the axle hub snap ring from the knuckle. toy_car_cor-02-04wheelhub2.gif
  12. Remove the axle hub from the hub bearing using special tool 09520-00031 or equivalent hub puller.
  13. Remove the inner race from the axle hub using special tool 09950-40011 or equivalent puller.
  14. Remove the dust shield from the knuckle.
  15. Remove the axle hub bearing from the knuckle using special tool 09520-00031 or equivalent and a press.
To Install:
  1. Install the axle hub bearing on the knuckle using special tool 09950-600020 or equivalent and a press.
  2. Install the dust shield on the knuckle with 3 mounting bolts.
    • Tighten 73 in-lb (90 Nm).
  3. Install the axle hub on the knuckle using special tool 09950-600010 or equivalent and a press.
  4. Install the axle hub snap ring.
  5. Install the lower ball joint on the knuckle.
    • Tighten the ball stud castle nut 76 ft-lb (103 Nm).
  6. Install a new cotter pin.
  7. Install the knuckle on the strut with the 2 nuts and bolts.
    • Tighten 162 ft-lb (220 Nm) (except '03-'04) 113 ft-lb (153 Nm) ('03-'04).
  8. Lift the knuckle and hub assembly over the axle shaft and into the hub splines.
  9. Install the lower control arm on the lower ball joint.
  10. Connect the tie rod end to the knuckle.
  11. Connect the stabilizer link to the strut.
  12. Install the front rotor and brake caliper to the knuckle.
    • Tighten the 2 caliper bolts 79 ft-lb (107 Nm).
  13. Install the ABS sensor if equipped.
  14. Install the front axle hub lock nut.
    • Tighten 159 ft-lb (216 Nm) and stake the lock nut.
  15. Check the axle hub backlash and run-out.
  16. Install the front wheel.
  17. Check the front wheel alignment and adjust if necessary.
Feb 17, 2011 | Toyota Corolla Cars & Trucks
How do you change a fuel filter
First remove fuel pump relay, start engine till it dies, that's to release fuel pressure, go under van, remove both small clips at each end of fuel filter, new filter should come with new clips, remove clamp around fuel filter, then install new one, make sure that the outlet end of the fuel filter, points the the front of the truck.
Jul 22, 2010 | 1995 Ford Aerostar
How to replace coil string
This is best done with two people. Remove cover, place down so you are viewing the rope pulley. Remove all old rope. Measure 8 foot of new rope. line up pulley rope hole with rope opening in cover. Wind rope pulley 6 turns. Push new rope thru both rope openings, one in pulley and one in cover. Pull rope thru pulley and cover. Tie knot in pulley end of rope, Slowely release rope so it rewinds onto pulley. Install hope handle, your done. was'nt that easy? You will have extra rope, this is needed to go from engine to handle support on your mower handle.
May 28, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
How to replace belt on self propelled lawn mower
There is probably a cover on the front part of the mower that goes to the front wheels. remove the cover and you should have access to the belt. Carefully remove the belt (don't pinch your fingers) push it back towards the motor. You might have to remove the blade. Place new belt in the pulley on the engine shaft then to the pulley up front. Carefully start the belt on the front pulley and slowly turn it onto the pulley.
May 23, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Lawn mower troubles
You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
May 19, 2009 | Mtd 22" Yard Machine Push Mower
Traction cable
The black cover on the front of the mower is held on by 2 screws from underneth, remove the cover and that will give you acess to where the cable connects to.then you can use a pair of pliers to squeeze the end of the cable to disconnect it from it's mounting hole.
Oct 29, 2008 | Toro Lawn Mower With Toro Power Tools
Sport & Outdoor - Others Logo
216 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
