Question about Nokia N79 Cellular Phone
I have virus in my phone memory so i want to know that what is the formate code of phone memory of nokia N79
    Sergeant:
    Champion:
  • 214 Answers
The default code is 12345. if this not works than you need to pull out the memory card and connect it wilth card reader, after that format it mannually
Posted on Jun 20, 2009
Press*#7370# it vil ask for lock code press 12345 it vil automatically formate the set
Posted on Dec 20, 2010
  • Nokia Master
  • 1,800 Answers
Its 12345!!
good luck thank you for using fixya
3 Suggested Answers
Johannesen
  • 3 Answers
SOURCE: Nokia N79 Phone format
An alternate method for wiping the N79:
Go here: Menu >> Settings >> General >> Factory settings and follow instructions.
Posted on Jun 14, 2009
uxair shah
  • 812 Answers
SOURCE: Sir, I have a Nokia
Hello thanks for using fixya
Type *#7780# or *#7370# to reset set to factory settings
You can also format your set by this procedure:
First of all Switch off your phone then press and hold 3 keys combined
  • Green dial key
  • Star key no *
  • No 3 key on keypad
then press the power on to switch on the phone.
  • In the process don't leave the 3 press and hold keys, After some time the phone 'll format completely
Note: Remember one things this will deletes all your messages, all contacts, photos, notes etc in the phone memory.Your phone is like a new phone. So better is first save all your data and then restore it.
Default security code for nokia is 12345
I hope this solution will helpful 4 u
Please keep thumbs up in do Rating if it is helpful
THANKS & Keep Using fixya
Posted on Jan 02, 2011
Format phone memory without lock code
Hi.Even if you do not remember the lock code you can generate it by using a tiny software, so if you want to generate the current code follow this link.How to Generate Your Phone Security code..Only for Nokia bb5 Or if you do not wish to do generate and format it directly follow this link Formating tips of Nokia Mobile phone.Good luck
Feb 14, 2012 | Nokia N79 Cellular Phone
N79 hanging problem
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Jul 05, 2011 | Nokia N79 Cellular Phone
How to format nokia N79 phone?
1) Factory defaults-
Type *#7780# on your standby screen.
This will reset all your setting to default factory settings. User data wont be affected. (Default Lock code is 12345)
2) Soft reset-
Type *#7370#
This will reset the phone as well delete user data. Use when want to format the phone.
Jun 03, 2011 | Nokia N79 Cellular Phone
I have formatted my N79 and also formatted the memory card but still while running music player the previous songs are showing but can't able to to play.while trying to delete it ,saying system error.and...
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card using the PC. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation.
Check this link for formatting.
http://www.blogsdna.com/2278/how-to-format-nokia-n72-n73-n81-n95-nseries-mobile-phones.htm
Feb 24, 2011 | Nokia N79 Cellular Phone
I wan to format my n79 phone
There are three ways you can format your Nokia N79
  1. To only remove settings and leave your applications and user data intact.
    Dial *#7780#
  2. To delete contacts, messages, calendar events, applications installed to the phone's memory and all settings. Please note that you will need to format your memory using a computer to make sure that everything is deleted.
    Dial *#7370#
  3. Bring it to Nokia Service Center to have it re-flash or reprogram.
Feb 15, 2011 | Nokia N79 Cellular Phone
How to format nokia n79 phone memory
Hi komal_74452.
Please follow the steps mentioned below to format the Phone Memory.
1) Please take a backup of all the Data before you format. 2) Performing the format will delete the Data in the Phone Memory. 3) To reset some of the settings to their original values, select (depending on your device): 4) Menu > Tools > Settings > General > Factory settings. 5) Menu > Settings > Phone > Phone mgmt. > Factory settings. 6) To do this, you need the lock code. 7) The default lock code is 12345. 8) After resetting, the device may take a longer time to power on. 9) Documents and files are unaffected.
Hope this helps.
Please feel free to contact for further information and assistance.
Sep 12, 2010 | Nokia N79 Cellular Phone
How can i format my mobile? i think its a virus attack my mobile visual affect are not coming. what is the security code of my mobile?
first back up your phone memory on your memory card by going to Memory card->options->backup phone memory.then dial *#7370# and enter the lock/security code when prompted.this will wipe off every data on your phone memory.you can then restore your backup after the format is over.best of luck.you can rate me cos this will definitely work.cheers
Jun 16, 2010 | Nokia N79 Cellular Phone
Jun 13, 2009 | Nokia N79 Cellular Phone
Nokia N79 Cellular Phone Logo
634 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
