Question about Epson Stylus D92 InkJet Photo Printer
My D92 stopped working after a paper jam
Evan after clearing the paper jam it still wont work and is telling me there is still a paper jam
  • 1,800 Answers
Well try unplug it and unistall drivers and install an see
Posted on Jun 20, 2009
Epson gts50 wont stop scanning until paper jam occurs
I just started having the same issue. However, I don't think the problems was understood. You can one sheet of paper; that's all you need to scan. The scanner will not stop until it has cycled through 8 scans and which point it will then prompt that a e1: Paper Jam has occured. You can hit ok and still safe the document, but it is annoying have to go through the cycles or hit cancel to stop the cycling (at which point you can then still save the scan). I believe Alan and I are both looking for a solution to resolve the issue.
Mine started after a serious paper jam. I am in a rather unique situation as I have to requested elevated priveledges to down load/update any drivers. So personnally I am trying to find a way to work around the issue.
Thoughts would be greatly appreciated.
Jan 13, 2014 | Epson Office Equipment & Supplies
Omnitech shredder model ot--exc10a , shredder runs but when insert paper to shred it stops, pull out paper and it runs non stop!
Sounds like there's blockage between rollers and it also jams the sensor so auto function stops working. You will need to clear out as much jammed paper as you can using tweezers. Inspect the centre of the feed opening, there should be sensor which must be clear of blockages and moving freely. So clear any stuck paper with tweezers, in addition you can soak any jammed paper with WD-40 and unit should be good as new. Although if sensor arm is damaged then replacement of such sensor is unavoidable.
Nov 04, 2013 | Omnitech 18-Sheet Cross-Cut Shredder
Saying clear paper jam, I have done, there is no paper jam
Clearing a paper jam in a Lexmark laser printer is an easy thing to do. Laser printers produce high-quality products and are fairly complex machines, but paper jams (in most cases) can be solved mechanically with a little know-how and time. Follow these steps to learn how to clear a paper jam in a Lexmark laser printer.
  1. ep 1 Take the paper out of the paper trays. This will prevent any more paper from being drawn into the printer to further the jam.
  2. Step 2 Remove the cover from the housing of your Lexmark laser printer. This will expose the inner workings of the printer, and you also should be able to see the jammed paper.
  3. Step 3 Pull gently on the jammed paper. In many cases this is all that is required; the paper jam should move out slowly and smoothly.
  4. Step 4 Press the flashing paper jam button. This will allow the rotors to turn freely, which will facilitate the easy removal of the jam.
  5. Step 5 Unplug your Lexmark laser printer if the jam persists. This will allow you to pull more firmly without the gears working against you.
  6. Step 6 Examine the inner workings and confirm that all paper and shreds of paper have been removed. If the paper tore during the clearing, make sure none remains or it will inhibit normal printer function.
  7. Step 7 Plug the printer back in, refill the paper tray and try to print again.
    • Make sure to use a printer and paper type that are compatible. Consult your owner’s manual and the manufacturer’s Web site.
    • To deal with a large jam, it might be necessary to pull sheets from the middle of the jam in order to loosen the whole thing.
    • Always pull the paper “with the grain” of the mechanism, if possible. Pull it through the printer the way paper normally travels so that you don’t go against the gears.
    • For more serious repairs, contact an electronic store or professional repair person.
Nov 24, 2009 | Lexmark X4580 InkJet Printer
E4 comes up on panel saying clear paper jam
With out knowing which stylus you have there error either refers to a paper jam or ink cartridge error. If it takes the beging of the paper but then stops it could be a matter of worn rollers that are not able to grip and move the whole page.
Nov 19, 2008 | Epson Stylus Multifunction Inkjet Printer/...
HP Photosmart 2610 - Paper Jam
I cleared the paper jam but i am still getting a paper jam message. I checked thoroughly and dont see any pieces of paper anywhere. I press ok and still get paper jam message. I turned the priner off and on serveral times and that did not work. Same message. I am feeling very frustrated. Its been a week today. Help!
Sep 16, 2008 | HP Photosmart 2610 All-In-One InkJet...
Paper jam and now printer wont work since all paper has been cleared out of printer
paper pick-up rollers may be warn out.replace rollers.tell me the company &model no.
Aug 04, 2008 | Office Equipment & Supplies
Paper jammed alarm won't clear. No paper or obstructions seen in feed or internal sections. Tried shutting off and back on, no help. Double checked for scraps or pieces of paper at both ends, none seen....
I found that if you tell it to do a roller cleaning then without using to much pressure put your hand down the paper feeder and push it through.I found with mine where the paper goes through there was dust and dry ink and it stopped the paper going through
Jul 10, 2008 | Office Equipment & Supplies
Epson stylus photo rx520
If you have the manual, check the instructions for clearing paper jams.
Otherwise, look on epson's web site for support on clearing jams
Mar 10, 2008 | Epson Printer
Clear paper jam
does the printer have a cancel botton if it does push it
Feb 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
Epson Stylus D92 InkJet Photo Printer Logo
155 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
