Question about Westinghouse LVM-47w1 47 in. HD-Ready LCD Television
My westinghouse lcd monitor has not bright
My monitor LCD westinghouse LVM-47w1 has this problem when i turn it on i can see the picture for less of one second and make a sound like a whistle in the top center and is gone and when i connect my dvd or computer i can see everything but too dark and the brightness adjust in the menu it's 100 and all the functions are working in the menu ok, you know what's going on? please help
  • 3 Answers
SOURCE: LVM-37w1 37inch LCD HDTV
It is worth fixing but you have to replace the power supply. It is a fairly common problem with the Westinghouse units.
Posted on Oct 24, 2007
  • 317 Answers
SOURCE: Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
Posted on Jun 03, 2008
SOURCE: Picture flashes for 1/2 second then is gone...sound continues
power supply if led ligth stays blue and then after a few minutes changes to orange is your power supply.if light color goes to a purple that is your mainboard $$$$$$$$$$$
Posted on Jan 28, 2009
westytech
  • 120 Answers
SOURCE: LVM-37w1 Westinghouse lcd has picture for 3seconds
Hello, I can assure you it is the inverter board on this unit. The T-CON board (controller) will only mess with your picture in different ways but you the way you describe the symptoms it is for sure your inverter board. The harders part wil be to find some, you should probably look in www.shopjimmy.com, or www.invertercentral.com.
Posted on Jan 26, 2010
westytech
  • 120 Answers
SOURCE: I have the westinghouse monitor ( modeL #
Hello, this model has two ribon cables that run from the t_con board to the panel, it sounds like you might have to replace one of them if not the whole t_con board. You can find parts for this at www.shopjimmy.com, I would recommend you taking this unit to a certified repair center if you are not atleast a bit technical because you have to did a bit deep in to the set for this one.
Posted on Jan 27, 2010
My 42 inch westinghouse wont turn onDTV 1080p TX-42F430S
If you are referring to that you are unable to select the the 1080p setting in the TV menu, first try changing the aspect ratio in the TV Menu.
If that does not do it, you have to change the display setting ion your device, if you can not or it does not have 1080p the problem is that resolution is unsupported by your device
Jun 07, 2012 | Westinghouse LVM-47w1 47 in. HD-Ready LCD...
NEED A MANUAL AND A REMOTE
I'm going to assume you are somewhere in the US, in which case I found the items you asked for. The original remote is no longer manufacturer/available but I found a couple still kicking around:
http://cgi.ebay.com/230553427413
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=LVM-47w1&uuid=12905581119720
If buying from remotes.com, go for the "Nearly New / Original" rather than the replacement.
Your manual can be dowloaded from here:
http://www.retrevo.com/support/Westinghouse-LVM-47w1-TVs-manual/id/278ci966/t/2/
The download page will open in a new Browser window. Scroll down a little and click on "Download the Manual". On the next page, scroll to the bottom and enter the 5-digit security code in the box then click "Download Now". You can then save the file to your PC and/or print it for future reference. You don't need to enter your email address to download the manual. If you can't open the manual you may also need to download the latest version of Adobe Reader:
http://get.adobe.com/reader/
If you have any trouble downloading the instruction manual please post back and I will be happy to assist you.
Regards,
BElectric
Nov 24, 2010 | Westinghouse LVM-47w1 47 in. HD-Ready LCD...
I need a tv bluetooth adapter for a westinghouse tv
No such thing as a Blue Tooth Adapter Your source must be Blue Tooth and there is no adapter for that situation. Blue Tooth is a format all of it's own. Output from you Blue Tooth (DVD or video console like PS3) device
those are either HDMI or Component Video. Required for increased resolution.
No other input will suffice. When you get it working properly Blue Tooth is very high res. You will be pleased with the picture.
Do you need to upgrade your TV? or? Happy to help...
Zashiban
Zashiban
Jun 28, 2010 | Westinghouse LVM-47w1 47 in. HD-Ready LCD...
Westinghouse lvm-47w1 picture goes dim
Hello, I can tell you from experience that this is an inverter issue. Both the master and the slave have several transformers and sometimes you can't tell if they are damaged or not. I would recommend testing the leads from the inverters to make sure which one of the two is the one causing the dim picture.
Apr 07, 2010 | Westinghouse LVM-47w1 47 in. HD-Ready LCD...
What is wrong with My Westing house LCD TV
It appears like the power supply is dying on your TV. There are capacitors that become defective and will need to be replace to restore the TV functionality.
Let me know if you need further assistance, I service these power supplies.
Nov 24, 2008 | Westinghouse LVM-47w1 47 in. HD-Ready LCD...
Westinghouse 47" hd lcd 1080p
It does not need to be a blown speaker to be causing the problem. The issue (unless you have a habit of running the TV at maximum volume) is more then likely in the audio circuit of the TV.
Since it is only 6 months old, I would be straight onto Westinghouse to have it repaired under warranty.
Apr 14, 2008 | Westinghouse LVM-47w1 47 in. HD-Ready LCD...
Aug 14, 2007 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Westinghouse LVM-47w1 47 in. HD-Ready LCD Television Logo
299 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
