My washing machine wont fill up..ive checked all the plumbing cold part is on and connected...pipe not blocked...it empties but wont fill up.
  • 20 Answers
Check the screens in the hoses to see if plug and on the back of washer were the hoses hook up and the fill value might be faulty
Posted on Jun 20, 2009
I HAVE A ZANUSSI AQUACYCLE WASHING MACHINE ZWF1221W. IT WORKs THROUGH THE WASH BUT JUST BUZZES ON THE RINSE CYCLE. I CAN TURN IT TO SPIN & EMPTY AND THAT WORKS AS WELL.
clair you may have a cold water problem, it may have filled with hot water and gone through wash cycle but as it got to rince it only fills with cold water ,the buzzing may be the cold water solenoid staying open and if there is no water passing through it will make a buzzing noise,
1.check the cold water valve # is on . it's what the blue /cold hose is connected to, also in some hoses there is a filter ,it's possible it could be blocked but unlikely.
2. check the cold water hose has not bend in half from the wall valve to the washing machine,this will stop the water flowing.
3. or it's possible you could have a faulty cold water solenoid valve.**
cold water pipe on wall> water valve# > blue cold water hose > * *cold water solenoid valve on machine.
Nov 14, 2016 | Zanussi Washing Machines
AEG 73630: wont take water in, cant pump water out, when choosing a program the timer seems to have changed minutes with seconds, and when choosing af program, the only thing happening is, af few spins...
The machine knows what the water level should be at every step of the program, so if its full when it should be empty, is not filling when it should be or is taking too long to fill or empty the program will abort and count down in seconds as you describe.
First - check the drain filter for blockage!! if clear, can you hear the drain pump running on 'drain' program? a chug chug chug noise. If not pump may be jammed or seized - or the drain tube maybe be blocked at the waste connection on the sink, etc. Or maybe the water supply pipes have blocked or got turned off? Possibly the waste pipe may not have been installed correctly and the machine is syphoning empty? ie the end of the waste pipe is lower than the water level in the machine - so it syphons empty like draining petrol from a petrol tank! That would empty the machine when it should be full.
Check all the basics of filling, draining and filter before suspecting anything else.
Feb 01, 2018 | AEG Washing Machines
Wasing machine fills with water during washing and wont pump out filling the drum...
1. Empty the drum via the filter / trap at the front (there is sometimes a drain pipe near the filter - otherwise be prepared to use lots of towels to soak up the water).
2. Check / clean the filter.
3. Ensure that the drainage pipe is not blocked.
4. Check that the pipe from the pump to the waste water pipe is not kinked / blocked.
5. Check that the pipe from the drum to the pump is not blocked.
6. Does the pump sound like it's trying to work? If not, it could be that the pump is dead. Pumps can often become blocked with fluff / slime from the machine.
Jan 13, 2011 | Bosch Washing Machines
Bosch WF2001 washes only 30 degrees programmes
We had this problem and it turned out in our case that the hot water inlet filter was blocked. The pump wasn't receiving any hot water into the machine so wouldn't start on anything except a cold (30degree) wash.
We turned off the the hot water tap on the plumbing at the back, disconnected the inlet pipe from the machine, then put the end of the pipe in a bucket and turned the water back on, and saw loads of sediment spurted out.
We ran it until we'd filled the bucket, then turned the tap off, emptied the bucket down the drain, then disconnected the hose from the plumbing and cleaned the hose separately (there's a gauze at the plumbing end of the hose so make sure that's clean).
Then get some pliers and where the hose attatches to the machine there's a filter that you can pull out. Clean this out. In our case this was completely blocked with limescale sediment etc.
Reconnect everything, check it's all tightly fastened etc. then turn the tap on the plumbing back on - turn it on to a hot wash, press start ...and in our case it all worked a dream again.
All this info is in the manual if you've got one, but I thought I'd write it out in case you've got this problem and don't have the manual.
Ahhhhh... cleeean washing again! Hope this works for you. Happy go laundry!
Mar 04, 2010 | Bosch Washing Machines
Have been given Hoover HC6-110 (fitted with hot
This machine does not have a heater. You could use a Y connector or just cap off the hot and only use the cold settings.
Feb 24, 2010 | Hoover HC6 110M Front Load Washer
Beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Jul 01, 2009 | Washing Machines
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Washing machine
This is a Hot and Cold fill m/c.
You obviously have the hot water supply connected to the cold in let valve..
at the rear they are marked H and C .
Make sure the cold water is connected to C,and the hot to H.
Plz rate my solution. Thanks.
Dec 23, 2008 | Hotpoint Aquarius WD63 Front Load...
Whirlpool LHW0050PQ - Water wont empty or fill
This sounds like a plumbing problem. Lets see if we can isolate it. Turn the valves off behind the washer and remove them from the washer. Remove the washer drain hose from the stand pipe. Stuff one of the hoses into the now vacant drain line and turn the water on. Then do the other hose. Any noise? Now reconnect the fill hoses to the washer and reinstall the drain hose to its' place. Turn on the water valves at the wall, set the washer to a cold/cold cycle and start it up. Listen for noise. Now shut the machine off and set it for a hot/cold cycle and turn it on. Listen for noise. If you get no noise now, it's all good. If you're getting noise from just your hot water, your water heater is set too high and you have steam propagating in your plumbing. Your washer water valves (where the hoses connect to your machine) will only do this if you have low water pressure coming from the wall. Still, it'll be a plumbing problem.
Jul 28, 2007 | Whirlpool LHW0050PQ Front Load Washer
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
