Question about Tally T2250 Matrix Printer
How to rewrite data on tally7.2 - Tally T2250 Matrix Printer
  • deshdeepakti Nov 18, 2009
    how to restor tally7.2 data in new tally7.2
  • 378 Answers
At the main tally gateway press Ctrl+alt+R. it will ask for the company that u want to rewrite. Selct the comany and say yes
Posted on Jul 28, 2009
Iam not able to not possible tally 7.2 backup
Posted on Dec 23, 2009
When i am doing rewriting tally , its taking a long time and keep on processing, how long it wil take , is it working properly
Posted on Apr 06, 2012
Tally error company date details changed need to rewrite before proceeding
Type or copy and paste this link into YOU TUBE.
Hope this helps.
Tally ERP 9 ' How To REWRITE Tally Data ' 0 Rewrite Method
Apr 25, 2018 | Tally Computers & Internet
Tallyerp 9 memory access violation
If there are any user defined TDLs defined in the Tally.ini file set Default Companies to NO start Tally and check.
If the problem persists
Increase the screen resolutions to 16 bit high color small fonts, Load Tally and check.
Delete the printer drivers available in the Printer panel. Execute Tally. If this resolves the issue you can then re-install the printer drivers.
If the difficulty persists
After checking above-mentioned in case the difficulty persists please check the following.
Check for viruses in the system
Delete the Tally.sav file and check
Re-install Tally in a different folder and check
Disable the real time protection of the Anti Virus Software
Incase the problem persists please send an email to support@tallysolutions.com .
In case the problem is rectified when Default Companies is set to No in Tally.ini it indicates that the default company is corrupted. In such cases please follow the steps mentioned below
Take a backup of your company data
Execute Tally 9
From the Company Info Menu press Ctrl Alt R.
The Rewrite company screen is displayed. From the List of Companies screen select the Company in which you are facing the difficulty. The screen Rewrite Yes or No is displayed. Press Enter to re-write.
The error message indicates a data corruption. Please restore an earlier data backup which did not have this problem and proceed.
If you do not have the Backup then create a copy of the existing data and rewrite it by clicking Ctrl+Alt+R before selecting the Company.
Before rewriting ensure that the Company you wish to rewrite is not in use on any of the nodes and the command has to be applied before selecting the Company.
The data preferably should be available in the local hard disk. Ensure that you create a back up of the data in the the hard disk or a medium like CD.
Check http//www.tally9.info
http//www.tallyerp9.com
I found this howto here: https//answers.yahoo.com/question/index?qid=20100521043632AAsKkQs
Mar 31, 2014 | Computers & Internet
EXITING TALLY!! INCORRECT VERSION. DATA OF INCORRECT VER.(10) CAN ONLY RUN VERSION 11
In Tally ERP9, try the following:
Start Tally.
Press Ctrl+Alt+R. This will rewrite the data.
Now select the company. Confirm for rewrite. Take Backup.
After rewrite, you should be able to open the data and work.
Note: Please have a backup of the data before doing the above, just in case something goes wrong.
All the best.
Jun 11, 2011 | Computers & Internet
I have problem vit tally. i have multiuser tally.erp9 error massage is incorrect version data of incorrect version (6), can only run version 5
You either need to upgrade your version of Tally.ERP9 or your need to rewrite your data.
I would suggest you to rewrite your data using the following method.
Take a backup of your data.
1. Run Tally. 2. On the select Company screen press "Alt +R" 3. Select your company 4. Rewrite your data.
It would work now.
Rishabh
Dec 04, 2010 | Computers & Internet
How to Solve a Incorrect Version in Tally ERP 9, after Restoring the Data?
tally incorrect version (11) ....for gold ultimate crack users...
i have solved it ...
go to data folder of tally
rename the new data 10000 to 10000n
open tally erp 9 crack version
on select company press ctrl+alt + r
your new data will not b showing
than open tally data folder again and change the name of folder from 10000n to 10000
than press again ctrl+ alt +R
now in list you will be shown with new data
press enter
the data will be rewrite in older version
enjoy...
further clarification post here
Nov 02, 2010 | Tally T2245 Matrix Printer
Exiting tally incorrect version (10) during selecting the company after inporing the data
exiting tally incorrect version data of incorrect version 10 can only run version 9
Aug 25, 2010 | Computers & Internet
Creating a data cd
Data discs won't play in a DVD player or display on a TV.
Why would you want to "watch" a word file anyway???
Apr 09, 2010 | Teac CD-Rewritable W28E CD-RW Burner
Error message : File is damaged. Rewrite!
Step 1: Start Tally.
Step 2:
Step 3:
Tally asks to select the company to rewrite. Select the desired company to rewrite and then press Enter key.asking-tally-to-rewrite-a-company.png
Step 4:
Rewrite confirmation will be appeared on the screen, press "y" to start rewriting process.rewrite-confirmation-in-tally.png
Step 5:
After rewriting the data Tally creates Tally.rew file in Tally folder.open it in any text editor and go through it about the corrupted data.rew-file-in-tally.png
Sep 15, 2009 | Computers & Internet
I have eror c:\tally\data\30000\tran.mgr.900
i have an error D:\tally9\DATA\10005\tranmgr.900
size 19817472
position 19817472
chars 512(done0)
i can't rewrite my dat
Apr 25, 2009 | Computers & Internet
Exiting Tally File: 'C:TallyDataTr01302.500 Size: 38784 Position: 38784 Chars: 128 (done 0). plz solve my problem to sawariiya@yahoo.com plz help me...........
dear sir
i have tally 9 v so my company data is not rewrite done
on rewrite position show the massage of
EXISTING TALLY
INTERNAL ERROR CONTACT TALLY SOLUTION
SOFTWARE EXCEPTION C0000005
(MEMORY ACCESS VIOLATION)
KINDLY PLZ GIVE ME THE SOLUTION FOR THIS PROBLEM
THANKING YOU
JAYESH KHARCHE
jayeshkharche2007@rediffmail.com
Nov 20, 2008 | Tally T2250 Matrix Printer
Tally T2250 Matrix Printer Logo
1,001 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
mohamed salim shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
