Question about Friedrich D50C Dehumidifier
It does not turn on. No indication on control panel.
There is No indication on the panel controls . When I depress power on. I see Nothing coming on nor any indications turns on. I checked power in going into from the outlet. Any Help
0 characters
1 Points
We have a model AD-40A dehumidifer that I believe is approx 3 years old. When the unit is plugged in, nothing happens. Although it appears to be getting power (when you pull out the water tank, the...
You may have the humidity extraction level set to HIGH. Try lowering the humidity extraction level to 35% or if you have an analog unit, turn the control knob to maximum. Also cleaning the air intake filter may help.
Hope this helps you to solve the problem and thanks for choosing FixYa.
Aug 17, 2011 | NewAir AD-40A Dehumidifier
My Comfort-Aire BHD-501-B is running. However, none of the control panel buttons work. I cannot turn it off with the on/off button. I cannot change the humidity set point using the up or down arrows. I...
I don't think it's a thermistor problem, as previous respondents have suggested. I have one of these units. The control panel has been nothing but trouble. The Power button works, but the Fan Speed button is stuck on High. The Humidity Up/Down buttons only work sporadically. Sometimes they work if I keep punching them. There doesn't seem to be any rhyme or reason as to when they work and when they don't. I think they're just cheap parts that have failed prematurely.
May 03, 2010 | Comfort-Aire HD-651 Dehumidifier
Will not come on after resevoir was emptied
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
Apr 07, 2010 | LG LHD65EBL Dehumidifier
An automatic overflow switch and Container “Full” indicator light are provided to turn the
dehumidifier off before the container overflows. When the indicator light on the control panel
glows, the water container must be emptied. If the light remains on and the dehumidifier does
not begin to operate make sure the float is attached to the water container.
When the condensate water container is full, the indicator lights up.
1. Turn the power off before removing container. Wait 3 minutes for
any remaining water to drain into the condensate container.
2. Tilt the container forward then lift carefully by the handle.
3. Empty and gently re-insert the container.
Important:This water is not suitable for drinking.
Please rate and god bless:)
Apr 24, 2009 | Fedders A7DH45B2A Dehumidifier
M7DH45B2A Dehumidifier
The fall may have knocked out some wiring -- open the unit (remove back panel, then remove front by taking out screws inside) and see if any of the cables to the front panel or control board came out.
Jun 20, 2008 | Maytag M7DH45B2A Dehumidifier
No lights, won't turn on
I suggest checking the fuse on the circuit board.
Oct 19, 2007 | Kenmore 54701 Dehumidifier
if it is a manual control try tapping the control with a screwdriver its possible the contacts are stuck and if it is a digital board its possible the board is defective let me know if this works
Sep 12, 2007 | Kenmore 54501 Dehumidifier
Normal operation, the unit has sensed icing and is in the defrost mode (compressor off and fan on high). When the ice melts normal operation will resume.
Dec 07, 2006 | Fedders A3DH30B2A Dehumidifier
Icing damage
You need to have the r22 charged... As stated above, if its low on r22 then it will ice up... no dehumidifier should ice up.... call a repair guy or better yet, buy another one... good luck.
Dec 04, 2006 | Maytag M7DH65B2A Dehumidifier
No lights on control panel. Plug is powered.
Independent of the bucket switch, the control panel should light when the unit is plugged into a powered receptacle and the on/off switch is depressed. The problem is likely the 12 amp. fuse located inside of the unit.
Sep 19, 2006 | Haier HDN655E Dehumidifier
Friedrich D50C Dehumidifier Logo
49 people viewed this question
Top Friedrich Dehumidifiers Experts
J.D. Browning
J.D. Browning
Are you a Friedrich Dehumidifier Expert? Answer questions, earn points and help others
