Question about Proform Sport 1000 Folding Treadmill PFTL91205 - !
Weslo Proform 525 Walking Belt folds over
I recently found the manual and discoverred how to center the belt using the adjustment screws. However, now there is a fold on the left side. I tried to rectify it by unfolding it as it runs on the slowest speed but although it goes into the bottom of the deck straight it emerges from the top folded over.
It seems that the top of the belt has become somewhat disconnected from the backing on the left where the problem manifests itself. I hope I don't need to order a new belt.
4 Suggested Answers
SOURCE: unfolding the deck on treadmill
From the owners manual:
HOW TO LOWER THE TREADMILL FOR USE
1. Hold the upper end of the treadmill with your right hand.
Pull the latch knob to the left and hold it. It may be necessary
to push the frame forward as you pull the knob to
the left. Pivot the frame downward and release the latch
knob.
2. Hold the metal frame firmly with both hands and lower
it to the floor. CAUTION: Do not grip only the plastic
foot rails or drop the frame to the floor. Bend your legs
and keep your back straight.
Posted on Jan 11, 2009
  • 103 Answers
SOURCE: How do I unfold my Reebok 8700 i fit? I folded it
Hello there, If you stand behind the machine you should see the safety latch mechanism (round knob on the long section in the middle when the unit is raised) You will need to push up slightly on the walking belt section while pulling out the knob located on the safety rod. While pulling out the knob lower the unit about 3 inches and then release the knob. If you release the knob too soon it will catch back in the hole again. This should release the unit.
Good Luck! Tim
Posted on Feb 13, 2010
maxtreadmill
  • 832 Answers
SOURCE: how do i fold up then unfold the proform xp 620?
Before folding the treadmill, adjust the incline to the lowest position. If you do not do this, you may damage the treadmill when you fold it. Remove the key and unplug the power cord. CAUTION: You must be able to safely lift 45 lbs. (20 kg) to raise, lower, or move the treadmill.
Hold the metal frame firmly in the location shown by the arrow at the right. CAUTION: To decrease the possibility of injury, do not lift the frame by the plastic foot rails. Make sure to bend your legs and keep your back straight as you raise the frame. Raise the frame about halfway to the vertical position.
Raise the frame until the latch knob locks into the storage position. Make sure that the latch knob is locked in the storage position. To protect the floor or carpet from damage, place a mat under the treadmill. Keep the treadmill out of direct sunlight. Do not leave the treadmill in the storage position in temperatures above 85° F (30° C).
To lower follow this procedure:
Hold the upper end of the treadmill with your right hand. Pull the latch knob to the left and hold it. It may be necessary to push the frame forward as you pull the knob to the left. Pivot the frame downward and release the latch knob.
Hold the metal frame firmly with both hands and lower it to the floor. CAUTION: Do not grip only the plastic foot rails or drop the frame to the floor. Bend your legs and keep your back straight.
Posted on Jun 03, 2010
Testimonial: "Perfect!!! Thanks so much!"
Adjust incline on weslo cadence g 5.9 bought it used no manual
On the rear of walking deck you have the left and right feet. Down the deck is at 0 degree incline, fold them up and you have a 3 degree incline.. You have no incline motor on this model.
Mar 02, 2015 | Cadence Weslo 825 Treadmill Walking Belt
On my Sears ProForm 730 treadmill, I cannot make the belt move to the right (it is rubbing on the left side) by turning the left-side back belt screw clockwise (in any amount). The belt is walking back...
The belt does not need to be replaced more than likely. The problem is probably because that adjustment bolt is stripped out causing it loosen and keeping it over on that side. ProForm sells star washers that help them stay steady and not slip out. I would call them and ask for a couple of star washers and a new adjustment bolt for that left side.
Aug 16, 2010 | Proform 730 Folding Treadmill Model...
Belt is off alignment
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to over tighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered.
May 31, 2010 | Proform 730 Folding Treadmill Model...
How do you adjust a belt on a Proform 385X. It is
If the walking belt is off-center, first remove the keyand UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left bolt counterclockwise 1/2 of a turn. Be careful not to over tighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
May 17, 2010 | Proform Exercise & Fitness
Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Apr 26, 2010 | Treadmill Doctor Proform 622 Exp Treadmill...
We have a Proform Sport 1000 treadmill which when you get on it the belt slips badly and it hardly moves. The belt doesn't seem loose so is the motor failing?
There is a belt between the front roller and the motor (drive belt) that is under the motor hood. The trick is to watch the front roller when you get on the walking belt. If the front roller stops with the walking belt, then the drive belt is loose and needs to be replaced or tightened. If you have already adjusted the walking belt, and you can hear the motor, it's the drive belt. There will be 3 screw on the front of the machine, and a couple of screws under the main frame. Tip the unit over to find the screws, and take off the cover. You'll be able to see where the slip is.
Mar 06, 2010 | Proform Sport 1000 Folding Treadmill...
How to do you adjust the belt on a Pro form crosswalk 380? The belt is getting loose and I lost the manual.
To adjust the belt: Less Belt Tension: turn both adjustment bolts on back of treadmill in a counter-clockwise direction. More Belt Tension: Turn both adjustment bolts equally in a clockwise direction. Center Adjustment (moves belt center to the left): Turn left-side adjustment bolt counter-clockwise. Center Adjustment (moves belt center to the right): Turn the left-side adjustment bolt clockwise.
An over tightened walking belt can raise the amp draw of your treadmill, contribute to seam separation on the walking belt, or both, so do not over tighten the walking belt.
You should be able to lift the belt in the center on the side by approximately 2” to 3”, if you cannot lift it by 2” to 3”, the belt is too tight.
Feb 20, 2010 | Proform 730 Folding Treadmill Model...
How do I best maintain the belt on a Proform 525?
read your manual- there is a small section that states NOT to use silicone/wd-40 on your item. You can use only the lube the manufacture(ICON) reccommends. Sears Parts store or parts on Phone 1-800- FON PARTS your part # is 06-831-135855 it is called walking belt lube The retail store does NOT sell this lube, they do sell the silicone spray-but its for the OLDER treadmills I know this I work on treadmills for the company!!!! with a little work, bypass the retailer, go to the source- they charge less...
Jan 07, 2010 | Proform 525C Treadmill Walking Belt
Proform Sport 1000 Folding Treadmill PFTL91205 - ! Logo
400 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
