Question about Dayton Permanent Split Capacitor Motor Fan
DAYTON 3/4 HP MOTOR DIRECT DRIVE BLOWER
REPLACEING THE OLD MOTOR FROM THE FURNACE HOOKED IT UP THIS HAS 3 SPEEDS USEING THE LOW SPEED THE RED WIRE THE MOTOR DOES NOT DO ANYTHING WHEN THE SWITCH IS PUSHED
2 Suggested Answers
jfpogie
  • 104 Answers
SOURCE: dayton 24 inch two speed fan
yes, it will work and not damage your motor.
Posted on Jan 28, 2008
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
Replacing a waterway 56 executive spa pump 3 hp with 4 hp. how do I wire plug into 4 hp pump
The pump motor should have a label on the side of the motor showing a diagram for Common, High speed, Low speed and the right positions for the connections.
Common is always the white wire
High speed is normally red
Low speed is Black
Green wire is always green
Oct 02, 2015 | Waterway Pool & Spa
Furnace repair
what makes you think there a problem with the blower, Most newer blowers have multi-speeds so be careful to only have two wires hooked up at a time , always have the ground hooked up, usually the white wire and then try black for high speed, make sure fan is secure it may shift. to check low speed connect only the red wire to power and the white wire to gound . depending on motor, other colors would be medium and medium high is so equipped. if motor gets hot after a while check for a capacitor, they have a tendency to get weak, replace with exact same capacitor. let me know why you suspect the blower.
Dec 31, 2011 | Heating & Cooling
I have an Emerson (4 Speed) direct drive blower for my gas furnace. What is the process (wire color codes) to change speeds on the blower. (I have a red, black and yellow wires taped off in the wire...
There should be a wiring diagram on the motor itself. The colors of the wires vary depending on voltage and model. Generally you have a med/low and med/high setting, I'm not sure what you are getting to with the low/high setting unless you are trying to set up staging. Check the motor for a diagram, if that is not present post back with all of the wire colors coming from the motor and the voltage.
Sep 25, 2011 | Emerson Heating & Cooling
I just bought a dayton belt drive fan and blower motor to replace my old motor. I don't understand the how to wire the motor to get it to work.
A lot of wires can be confusing but you ain't gonna use half of them. I have not seen you motor but they are basically all the same. You are going to have a Red wire for low(heating), Blue for medium (which is not needed), and Black for high speed (cooling). A solid white wire is the common wire. Go ahead and tape the blue medium speed wire off by itself so it won't short anythang out. Their will be 2 brown wires with spade clips and the capacitor goes to them. The other wires have to do with reversing the motor and you can see how that is done by using the directions on the label. You NEVER want to connect the speeds together or that burns up the motor. If you have electric heat then it is simple just use black for high and white for common and tape the other speeds off to themselves so that they don't short out against each other or the unit.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 27, 2010 | Dayton Heating & Cooling
Changed out blower motor on elect furnace.the old motor had three wires one fed the compaster.new motor is revirsable has purple wire,red,blue,black.hooked up purple 1st phase,red for high 2nd phase. is...
hmmm . you better check on that before firing it up ... normally the colored wires are for different speeds .. only one speed can be connected at a time .. usually the high speed winding is used for air conditioning and a lower speed winding is selected by a relay for heating .. ... the way the capacitor is hooked up determines which way the motor will turn .. your old motor with just 3 wires was probably a single speed motor .. normally the black wire will be connected permanantly to one phase .. the other phase then goes to the selected speed winding (color of wire) .. one goes to the starting capacitor . the others even if not connected will be hot electrically so need wire nuts to prevent shorts ..
Jan 03, 2010 | Dayton (2C373) Fan
How to change fan speed on a goodman gmp 100-3 furnace
Usually you can find the control board on the lower part of the furnace. Turn the power off and remove the
doors. This board is usually located directly in front of the blower motor.
On the control board locate the terminals marked heat/cool/park and Park Lets say the Heat Terminal
has a red wire attached to it and you want a higher
speed.
Red is uasually low speed, remover the red wire from
heat terminal and exchange it with a wire attached to
a terminal lab eled park. Black is usually high spped
Jan 01, 2010 | Goodman GMS90703BXA Heater
What wires on the blower are power need to know what colors to hook up to run 120w
The wires to your blower are connected at the control board. To hook up a 120V to the furnace, on this model, is located on the left hand side of the burner section. There is a black and white wire in a small 2"x 3" box. The control board selects which wire to power the motor depending on what mode you are in.
Oct 03, 2009 | Goodman GMS90703BXA Heater
Wiring a retrofit soft start blower into a Ruud 5T/100k gas pack
Chances are, you've smoked the motor. You basically put 120 volts across the speed windings of the motor when you did this.
What you need to do is, with the new motor, you will have neutral, and speed 1, speed 2, speed 3, etc. Hook one of the original black wires to neutral (it would be best to trace which of the two black wires is connected to neutral, and connect this one.).
Black on the new motor is probably High speed, red is probably low, orange is medium speed. Hook the remaining black wire to one of these, and no more than one of these, or you will smoke the motor again.
Attach a wire cap and/or electrical tape to the remaining wires to insulate them from contacting anything else.
Jan 27, 2009 | Ruud Central System Air Conditioner
Dayton Permanent Split Capacitor Motor Fan Logo
441 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
