Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Audio and video quit working
The green power light comes on but no picture or sound
  • 79 Answers
Are you sure that the power is on? and the cable is plugged? There are some TVs that do actually work MANUALLY, meaning, even the light is on, (notifying you that it's on) you still have to use the remote to turn it on. Hope this helps!
Posted on Jun 20, 2009
My hd tv power button green light comes on but no sound and no picture
check what your input is has to have an antenna of a cable hooked up to it
Nov 02, 2014 | Generic 6 northstar v1.3 hdmi m to hdmi m...
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site www.TvRepairKits.com
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
Sanyo DP46819 green ind. light comes on but no screen or audio
Not true that its def the power. Mine did the same thing. Green light, no sound or video. Replaced the power board with same results. Waiting on main board now.
Jun 07, 2012 | Sanyo DP46848 LCD TV
Sony KDF-42 WE655 TV. Replaced lamp and it now works; however sometimes when it is first turned on the audio and video quit for about a minute and the green light flashes. Then both sound and video...
You may have a bad ballast. Check to see if your lamp is lighting up through the back of your T.V. prior to the picture coming on. If it has done this since you bought it, it's probably the just the way the T.V. was designed. If it still comes on every time, it could also be a power supply issue, but nothing to stress about.
Jun 17, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a sony tv model kdf-50e2000,and it has a problem with the picture going blank,the only light that on or flashes is the green (POWER) light. when turning the set on the green light blinks as it...
You tv used lamp XL-2400 or also known as F93087500. It is very common for this bulb to fail and have the exact symptom you are experiencing. I cant count how many times I have seen it.. Replace the lamp with either the exact Sony or an OEM and you will be back in business..
Good Luck!!
Dec 28, 2010 | Sony KDF-50E2000 50" HDTV
No picture, no sound
The green steady power light is a good thing, how old is the TV?
If you are routing your audio and video through the audio receiver, make sure that the inputs are correct on the display of the receiver, ie. IF you are planning to watch your DVR and it is hooked up on Component 1 for video and Coaxial 1 for audio, make sure that the receiver is still programmed for this in the input of TV/Video 1 or whatever the input. I have ran into this on countless occasions, simple fix, but a headache until it is tracked down. Double check the connection to the TV as well.
Nov 25, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Philips60p8341
If you have any of the following problems you may want to check the site www.tvrepairkits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
(Note: The below symptoms typicaly occurs after having the expanding/shrinking screen problem above)
Symptom: No Audio or Video but power light is on
Symptom: Audio works but no Video. Power light still work
Symptom: No Video. Audio is intermittent. Power light still works
Oct 11, 2008 | Philips 60P8341 60" Rear Projection...
Xbox problems
try replacing your audio and video wires that connect from the Xbox to the TV.. if this doesn't work send the console back to Microsoft and they will repair it free of charge and ship it to you in about 3 weeks.
May 17, 2008 | Microsoft Xbox 360 Console
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
274 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
