Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
No fuel I just got a L100 John Deere from my neighbor for cheap. it ran when I got it but it ran ruff. Then died. No fuel to the Carb. I replaced the fuel lines and the pump. Still no fuel. I have fuel to the pump but no farther then that. I put a brake bleeder on it to try and draw the fuel threw it but it still doesn't help. What am I missing? Thanks for your time.
    President:
  • 986 Answers
There is a square block on front of engine that is your pump th diafram has went bad and it is easy to replace
Posted on Jul 29, 2009
John deere L100 won't start after sitting all winter. what can I do?
squirt some carburetor cleaner in the carb. if it starts for a few seconds there is a fuel problem. sometimes water or debris will get in the carb and stop fuel from going through. take the bowl off and see if you see any of this in it if so clean it real good and it should run fine.
Apr 22, 2017 | John Deere Garden
I have a john deere l100 when going to engage the throttle it begins and eventually dies out. when could be causing this????
Fuel issues due to ethanol gas, carb issues due to contaminants, broken carb linkage spring, needle valve, saturated float, dirty filter. You need to open it up and look around. Good luck.
Aug 24, 2015 | Garden
Why does my john deere l110 turns over but doesn't start and fuel is coming out of the exhauste
The float is stuck in the carb, remove float bowl and clean main jet and adjust float level.
Feb 24, 2015 | John Deere L100 Series
My john deere riding mower model # lt160 will not start. what could it be?
Check fuel line. It could be stopped up. Also check inline filter or in tank filter for trash.
Nov 29, 2014 | John Deere Garden
Kohler cv491
check your fuel filter. Is it dry? Mine was and found the vent in the fuel cap was plugged and it didn't allow fuel to flow through the filter to the carb
Sep 06, 2014 | John Deere L100 Series
John Deere L110 won't start.
check the solenoid on the bottom of the carb see if there is power if no power check the safety switch on the brake/clutch if there is power remove the solenoid and put power and ground to it to see if it opens if not try and clean it with carb cleaner if that works and opens remove the bowl from the carb and check the needle valve on the float make sure it moves
Sep 01, 2012 | John Deere Garden
John Deere LA 135 Fuel will not pass through carb. feul is getting to it .
yes solenoids do stick and at $130 for it try and clean it first and at that price i have cut the tip off and just added a manual fuel shut off valve in line to the carb
May 26, 2012 | John Deere Garden
I have a john deere riding mower model L100 it runs good but after 20 o 30 minutes gas stop going to the engine after it cool down it start running again does this mower have a gas pump
When it dies loosen the fuel cap and see if it will start.If it starts its because the tiny vent hole in the fuel cap is plugged.
Jun 26, 2010 | John Deere Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
477 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
