Home | Dyson | DC05 Cylinder Bagless Canister Cyclonic Vac... | We have a dyson dc 07 ...
Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
Problem for Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
We have a dyson dc 07 animal the machine was
By c_eastwood on Jun 20, 2009
we have a dyson dc 07 animal the machine was working fine then switched off after returning to the machine minutes later it wouldnt switch on, i removed on off switch cover and used a short piece of wire across the brown wires flicked the wall switch and it worked, aha i thought faulty switch aquired a new one to no avail and now even the short piece of wire trick doesnt work, has the motor died do you think, it wasnt over heating or making strange noises prior to refusing to work
Best Solution
posted on Jul 07, 2009
Very Helpful)
parsonm
Rank: Guru
Rating: 96%, 47 votes
It could be the motor. I'm having to replace the brushes on my DC 05. It appears that you can only get brushes for the YDK motors in the DYSON, not the Panasonic motor. Which might be saying something about the YDK motors. What happens is that the carbon brushes wear down which is normal. However, the contact wire from the brush to its connector is set so that when the brush wears down, the wire is short enough to stop the spring etc from damaging the commutator. The end result is that you get an intermittent operation of the motor before it finally dies.
I believe all the DYSONs come with the option of both motors and you cannot really tell which motor you have until you take the thing to bits. You also cannot change motors without changing various other parts on the hoover. On my DC 05 the writing on the YDK motor tells you which one it is.
This website www. tasweb.org ,select the DC 05 option and scroll down tells you how to take the thing to bits. A search on google etc for your DC 07 may give similar results. Best of luck!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dyson DC05 Cylinder Bagless
Questions and Unsolved Problems for Dyson DC05 Cylinder Bagless
Do you recommend Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum?
Answer
Answer
Power Cord has been stretched and the appliance no go but cord is still attached by phase and... (More)
Answer
i want to clean inside the yellow cyclone section of a DC08 but tapping just wont get out the thick... (More)
Answer
I appear to have suction but, when vacuuming there is not enough suction to pick up all the dirt. I... (More)
Answer
I have cleaned filters (and replaced) Checked for blockages in the hoses. Cleaned the beater bar--It... (More)
Answer
I have a brand new Dyson and the canister is full and it will not open up. I feel like the parts... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dyson DC05 Cylinder Bagless...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
