Question about APC VS 500VA (VS500VA) UPS System
Beep and yellow green light problem
I have an apc vs 500a battery backup unit. It has started doing something funny. The green light is on. The on battery light blinks yellow along with the green light blinking and it makes noise when doing it. It has been happening more and more throughout the day. Do you know what the problem
  • 28 Answers
It sounds like you may need a new battery. The batteries are continuously tested by the UPS and it could be that the voltage is passing one test, and failing the next which is resulting in the light flashing. You can test the battery with a voltmeter. It should read over 11.5 volts, if not you need a new battery set. You can get batteries from http://www.batteryinternational.com/ups-batteries-apc-batteries.html
Posted on Jun 23, 2009
Apc xs900 will work off batteries not off ac
So something happened to this apc and the first thing is to replace batteries...
I'm going to guess major circuit board failure.
go to apc site, download Power Chute software and pray there are useful diagnostics.
Mar 31, 2014 | APC Back-UPS XS900 (BX900) UPS System
Apc beeping twice every 2 seconds
The battery inside the APC is "weak", and the "beep" is telling you to replace the battery inside the APC, or, maybe cheaper, to buy a new APC.
Feb 03, 2014 | APC BACKUPS ES BE550G 8Outlet 550VA 330W...
Apc xs1500 beeps 4 times
Check if the unit has a breaker on the back and reset it. The unit doesn't seem to be getting power.
Dec 03, 2012 | APC 1500VA BX1500 8 Outlet UPS UPS System
Hello, I have a APC Backup UPS 800 (5 year old) started beeping. Assumed it was a battery problem and ordered a new APC RBC32 battery. When the battery arrived, installed it to the unit only to see...
Because of the electrical burning it is likely that the battery was not the cause of the issue in the first place, it is also likely that the unit will not be able to be repaired by you personally. Often these batteries have very long warranties and coverage, so see if APC will take the unit back along with the battery, if the battery was used in a faulty machine it may have been damaged so i would return that too to make sure that the problem doesn't come back in the future.
Mar 14, 2011 | APC Back-UPS XS900 (BX900) UPS System
Alternating green and orange light with constant beeps
Verify that the usb to ups cable is pluggled in properly. Also you may not have a good ground. Disconnect the ups and plug it in another outlet to test with nothing else plugged into it, to see if it still beeps. You can also try and upgrade the ups software from apc.com
Jun 25, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
When it is switch on, the yellow light comes along with beeping. But finally the green light does not come or it is automatically switched off.
check and replace the battery: 12v/7.2ah(exide is preferable)..
there may b problem with smps dc-relay section or switching section or push-pull section, go through only if u r a professional..
else contact system admin/vendor....
Oct 29, 2009 | APC Smart-UPS 1000XLI (SUA1000XLI) UPS...
Have brand new APC 900 UPS and when plugged in, both green & yellow indicator lights flash. Non-stop. Left unit plugged in for 18 hours (off) to charge battery as info sheet suggested, but lights still...
Nope! The internal battery is not plugged-in correctly. Unplug the APC unit and open the access door to the battery (it is not dangerous to do).
Re-seat the two wire clips (red & black) to the battery. The positive post has a red mark on it.
Close it up and charge for a few hours before using.
If the symptoms continue, return unit to store.
Sep 19, 2009 | APC Back-UPS® XS 900 (BX900R) UPS System
APC VS 500VA (VS500VA) UPS System Logo
700 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
