Question about GE Refrigerators
Hello, we have a GE fridge model number PSC23MGTD, is making ice, how ever it will no longer dispense the ice However it will still dispense the water. Lights are working on the front panel that indicates water, cubes, crushed ice. Noticed when set on ice and push lever to dispense ice light goes dim. Interior components seem fine.
aborcass
  • 2651 Answers
SOURCE: Always dispenses CRUSHED ice
try removing the ice bucket, and on the back wall is a hole approx 1.5 inches square that the brass bar attached to the rear of ice container inserts into,(you may have to put hte container back in partilaly to look under and watch where it slides into) inside thatcut-out is a plunger that slides up and down activating the crushed/cubed option.you can sick you finger in the hole you should seee a plastic hoop that would catch the brasss bar.Try pushing and pulling hte hoop up and down if it does not move freely, youll need to replace the solenoid assy. if it does, then pull allthe way to the lowest positon and make sure when replacing the ice container that the bar falls with in the hoop itself
Posted on Mar 22, 2008
  • 184 Answers
SOURCE: Ice dispenser only dispenses crushed ice
THE WAY A DISPENSER CHANGES FROM CUBES TO CRUSHED ICE IS BY RAISING AN ARM THAT RUNS ALONG THE BOTTOM OF THE ICE BIN. IF IT SETS FOR A LONG TIME, IT CAN GET A BUILUP OF FROST OR ICE THAT KEEPS IT FROM MOVING. PULL THE ICE BIN OUT AND TRY TWISTING THE END OF THE ARM MANUALLY. IT SHOULD OPEN A DOOR AT THE FRONT OF THE BIN THAT WOULD ALLOW THE ICE TO BYPASS THE CUTTER ASSEMBLY.
ALSO,WITH THE ICE BIN REMOVED, PUSH THE DOOR SWITCH BUTTON CLOSED BUT KEEP THE FREEZER DOOR OPEN. WHERE THAT ARM GOES IN THROUGH THE BACK WALL, CHECK FOR MOVEMENT OF A ROD UPWARD WHEN YOU CALL FOR CUBED ICE. IF YOU HEAR A LOUD HUM BUT THE ROD DOESN'T MOVE, YOU MAY NEED TO REPLACE THE SOLENOID ASSEMBLY IN THAT MODULE.
Posted on Apr 10, 2008
  • 415 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
samrat_babui
  • 296 Answers
SOURCE: Ice maker only makes crushed ice, no cubes
hi.
I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck.
chek these sites
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23620-ice-maker-only-makes-crushed-ice-no-cubes.html
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
if satisfied plz rate this answer
all the best
regards
Posted on May 27, 2009
My GE monogram ice maker is dropping ice inside the freezer when dispensing
Reach your fingers up into the dispenser from the front and feel to see if the ice dispenser door is shutting all the way when it should be closed. Like my help? What is the model number of the fridge?
APPLIANCE 911
Apr 14, 2016 | GE Refrigerators
Have a GE Profile PFCS1RKZA - with many random issues...
The dimming light indicates a power loss in the system.
Jul 10, 2015 | GE Refrigerators
GE Ice maker works makes ice! continues to eject ice when glass is pulled away
the button behind the pad is stuck,bad model number,if it's a side by side open the fridge door.look up on top and on right wall and you'll see a tag with model and serial number
Oct 12, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Fridge water dispenser working but not the ice
Yes you most likely have a defective dual water control valve. Look around the inside of the refrigerator for a model number.
Click here=> For most locationsSide-By-Side
  • Top Freezer
  • Bottom Freezer
    Once you find the model number I will be able to tell you what part number the dual dual water control valve is or if your ice maker assist you in testing ice maker. If ice Maker is empty try filling with tap water to top edges of ice maker, allow water to freeze and if the ice drops into the ice bin but does not refill with water automatically I would say that the dual water control valve will need replaced. If your ice maker has old shrinking ice from a few days ago it will point to an ice maker problem.
    Thanks, Sea Breeze
  • Feb 10, 2012 | GE Refrigerators
    GE Profile Fridge Model No. PSC25MSWA SS not making ice
    Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
    Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
    My GE fridge makes Ice but can't get any water?
    He is saying the heater in the ice tray located on the bottom that helps loosen the ice before it is dispensed to the ice pan.
    A new ice maker for your fridge can be purchase for less and you can install it yourself. Below is my site link, just put your model number in the search feature or the part number WR30X10093 of the ice maker. We also offer free help and assistance, Thanks, Sea Breeze
    http://servicepartstec.blogspot.com/
    Mar 28, 2009 | GE Profile PFS22 33" Artica French Door...
    Ge fridge makes Ice, doesn't dispense
    turn freezer side to zero for 1 minute. press water dispenser
    Jan 26, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
    GE GSS25LGM Ice maker
    one of the valves could be open circuit. ice build up where the pipe enters the cabinet or sadly if not that then the complete ice maker. hope this helps
    Feb 11, 2008 | GE GSS25LGM Side by Side Refrigerator
    Refrigerators Logo
    177 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Randy Justice
