Question about HP Cameras
I have a HP df802 series digital picture frame. Using a 2 GB SD card or 2GB USB drive, the browse thumbnail mode only always displays 200 x 8 photos and always the same ones. I have over 2500 photos on the card. Can't access the rest? Also df802 will not display photos in the order I have arranged them on the card. Tried to re- format card with same results. Help if possble. Thanks
  • 203 Answers
SOURCE: I bought two 4 GB
pny does not supply card readers w/memory cards-sandisk on certain cards includes reader because file format is different on sdhc cards -try downloading direct from camera w/usb or get a card reader that absolutley supports sdhc type cards-not all readers do!
Posted on Jun 25, 2008
SOURCE: fuji j10 - my mac wont recognise it even using finepix
I had the same problem with my camera & mac.  I got this off the Fuji site and it worked for me:
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
Posted on Dec 08, 2008
  • 2976 Answers
SOURCE: Can't format 2 GB sd card for HP 735 camera
Make sure the SD card is unlocked. There's a tiny switch on the side. Put it into the camera. Under storage, when you select the card, also select format.
Posted on Mar 13, 2009
  • 34 Answers
SOURCE: I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Posted on Jun 07, 2009
t00nz
  • 4738 Answers
SOURCE: Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Posted on Oct 19, 2009
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
How to delete images off a sandisk extreme 3 2.0gb compact flash%3F
Pop your memory card into your card reader, wait about 15 secs and it will appear on your computer as a drive. Double click on this drive and you will see either a lot of icons corresponding to the photos on the card or a lot of thumbnail pictures of the photos. Again right click on the drive and click on select all on the popup box. When all the icons or thumbnails are highlighted left click on them and the click on delete on the next popup box. Whatever you do DON'T try to format the card with your computer. If you want to format a memory card for a camera always use the camera's format function to do so.
By the way, the photos can also be removed by using the delete function in your camera's menu display.
Make sure the record inhibit tab on the memory crd isn't activated. If it is you won't be able to delete anything.
Apr 21, 2010 | SanDisk Extreme III 2GB Secure Digital...
My children gave me a digital photo frame for Christmas. I have a Nikon digital camera. I have downloaded and deleted from my camera several pictures I would like to put into my photo frame. Am I able to...
If the "camera chip" you refer to is a removable SD Memory Card you need to put that into a SD Card Slot on your computer or use an USB Card Reader device. The computer will recognize the SD Card as a Disk Drive and you can use Windows Explorer to transfer the picture files to it.
Dec 29, 2009 | Coby DP-767 7-Inch Widescreen Digital...
I have a HP df802 series digital picture frame. Using a 2 GB SD card or 2GB USB drive, the browse thumbnail mode only always displays 200 x 8 photos and always the same ones. I have over 2500 photos on the...
I would transfer all the pictures to my computer hard drive and then use another sd card - load some pictures on there and then introduce it to HP - if that also does not work then issue is with the picture frame. If it works then hassle is with original sd card. Sometimes reformatting the sd card will restore it to proper operation. Sometimes it will restore but then revert as my card does all the time since it is a sick puppy!
Aug 26, 2017 | Sunpak (SDPF-070AW-0US) Digital Picture...
Can't get frame to read files on USB flash drive
keep the drive you use to 2g or 4g max.for some reason a lot of the cheap frames cannot handle anything bigger.
Mar 29, 2009 | Nextar N7 - 7 Digital Photo Frame with...
Nextar N7-202 digital photo frame
I had the same problem and called Nextar Support. The gal I spoke with asked how big my SD card was and informed me that the capacity for this frame is only 2 GB. Sure enough, my card was 4 GB. I transferred the pictures to a 2 GB card and it works great! (Note to Nextar: might be nice if they put this somewhere in the paperwork BEFORE people buy an SD card.)
Dec 22, 2008 | Nextar N7 - 7 Digital Photo Frame with...
Transfer pictures
Plug the frame into the usb slot on your computer. Open up the folder with your pictures on it. Then open up my computer and look for the drive that is the frame. Drag your pictures right to the frame,s drive.,
Dec 13, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
7" Trutech digital photo frame
I don't have the booklet for this darn thing and I just got it for mothers day.... I have a sandisk in it and I can see the pics just fine, but it doesn't save them??? I can only view when I have something in it??? That's crazy?? Isn't it?? Help
Dec 29, 2007 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Cameras Logo
94 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
