Question about JBL Eon15P-1 Main / Stereo Speaker
One cone blew and damaged amp in JBL EON15P-1
One cone blew and damaged an amp in a JBL EON15P-1 after twenty minutes of a un-amplified desk being plugged in to an xlr input on JBL from a mixing desk standard channel output. A loud blurry noise emerged. The desk is being blamed but the master and other volumes were down....why would only one channel go? trying to get to the bottom of this. The system was set up on a summers eve fifty foot from a house, in a gazebo. There was a lot of static shocks off mics that night......desk has subsequently worked perfectly.
2 Suggested Answers
SOURCE: jbl eon15p-1 my speaker it
Mine has a blown power supply transformer. There are 2 fuses on the power input board. One of the fuses on mine blows instantly because the primary on the tranformer has gone short cct. A $200 part from Jands !!!
Posted on Dec 10, 2009
I am experiencing loud popping and crackling sound at high volume after speaker is warmed up. Speaker cones move smoothly when pushed gently by hand. Sound almost seems to be coming from inside.
Sounds like it could either be the crossover circuit or a distorted speaker cone. The cone is the easy one to check. You need to check that it moves freely at all points. It sounds like you have partly done this, but you just need to make certain you went all the way around the cone checking for free movement.
However I don't think it is the cone, because of the slow way it acts up. That could be the crossover circuit. If you have a look at it and see either an IC or transistor looking parts, then I would have thought it would be one of them acting up - presumably getting hot!
If you can have the speaker outputting sound, with access to the crossover, you could spray these parts (one at a time if there is more that one) with Servisol Freezer spray. You simply wait till the fault develop then spray the suspect part. If it returns to normal you have located the faulty part. If nothing happens, wait till the coolant wears off then try the next suspect.
Places like Maplin stock the Freezer spray.
Nov 23, 2015 | JBL Eon15P-1 Main / Stereo Speaker
JBL BP600.1 protection
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Using an ohm meter to the sub will confirm whether its bad or not. Invest in a cheap test set of 6.5" speakers.
.A thumbs up would be greatly appreciated if this answer is helpful to you.
Jun 02, 2013 | JBL BP600.1 Car Audio Amplifier
I need part number off volume control for jbl eon 15p1
you want JBL Professional group if this involves the Eon product line.
1-800-852-5776
Or on the website
http://www.jblproservice.com/
Nov 16, 2010 | JBL Eon15P-1 Main / Stereo Speaker
I installed a brand new tweeter in my JBL EON 15 G2 & the new tweeter blew. What else could be the problem?
These are "powered" speakers and any little bit
of distortion can be amplified enough to "blow" it!
Also the amp could be "shorted"! Have your JBL
dealer test it!!!
Apr 20, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
JBL EON15 PA Speaker problem
check the wire terminals under the cone by the spider and make sure that they are both still connected
Apr 16, 2009 | JBL GTO Series RLC Amplifier Accessory -...
Dead JBL EON 15P-1
did you measure 60vac across total secondary or 60vac from center tap?
Feb 27, 2009 | JBL Eon15P-1 Main / Stereo Speaker
Jbl eon15p-1 my speaker it was working fine after 30 minuts wont turn on
Jan 07, 2009 | JBL Eon15P-1 Main / Stereo Speaker
Amplifier smells
Generally, when the power supply FETs blow, they burn and make a mess (they blow black soot onto the board). If the damage was limited to the FETs, the amp is salvageable. Sometimes the board burns also but that's relatively rare.
Nov 05, 2007 | JBL GTO1201.1 Car Audio Amplifier
JBL Eon15P-1 Main / Stereo Speaker Logo
149 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
