Question about Hotpoint Aquarius WF210 Front Load Washer
Hotpoint wf210 filter location?
Hi does anyone know where the filter is located on a hotpoint wf210?
i read this on another post... filter is located between drum and pump at the rear, clean that out and that should solve the problem.
there's a small panel at the back of the washing machine, all i can see when i remove it is a gray tube on the right, and sone wires in the middle...
any help would be appritiated
  • 1 more comment
  • beardboy Jun 20, 2009
    managed to find the filter, and clean it out... but dropped the washing machine on it's face in the process... now it's dead... little red light, like when the terminator buys it... i'll call out a pro and see if he can fix it.
    thanks for the help
  • Derek O Hara May 30, 2014
    Where was the filter in the end? Cheers
    Where was the filter? I took off the pannel under the door as suggested by another poster but nothing but a metal frame!!
    Brigadier General:
  • 8,619 Answers
Hi!
Thanks for using FixYa. The filter is located under the panel of front door in the bottom of the machine. You need to pull the panel out and you will find the filter there. Before opening the filter prepare a bowl and a floor cloth to avoid flooding.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 20, 2009
  • Rylee Smith
    Rylee Smith Jun 20, 2009
    Hi!
    It is very unpleasant that you got your washer smashed head on the floor. But please do not panic. If it is totally dead then you need to first check these things:
    No power:
    Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
    Lid switch:
    If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
    Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
    If the problem still persists, only then you need to contact pro to fix it.
    Thanks
    Rylee
Hotpoint Aquarius WML540. Want to know where the filter is to clean it.
Hi, you have to pry the bottom cover off on the machine, there will be filter access underneath, please CLICK HERE to read the manual, page 12 shows the filter location and how to access it.
Hope this helps
Feb 12, 2011 | Washing Machines
Aquarius WF745 Front Load Washer.Full of water won't drain.
The filter is located at the bottom front of washer.
Remove the kickstrip at the bottom, by levering off.
Unscrew filter anti-clockwise to remove and clean..
Be careful when removing filter, as there will be water come out.Lay the drain hose down into a bowl or similar to drain off excess water.
Please rate my solution.
Thankyou
Jan 30, 2010 | Hotpoint Aquarius WF210 Front Load Washer
WHERE IS THE FILTER ON WASHING MACHINE
The filter is located at the rear of the washer.
Remove lower rear panel of washer.
Remove large black hose from bottom of drum.
Remove and clean filter inside hose
Remove hose onto pump, and check for blockage or obstruction here as well.
Thankyou.
Jan 26, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Very noisy when spinning
hi
it may be the belt making noise,,,check it,,,
thank u,,,//////please rate it
Jul 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
The water wont drain or spin wf210 hotpoint
Hi I think your problem is that the filter is blocked, filter is located between drum and pump at the rear, clean that out and that should solve the problem.
Mar 08, 2009 | Hotpoint Aquarius WF210 Front Load Washer
My washe keeps reading either F04 or F05
F04 - Pressure switch jammed on empty while F05 is a blocked filter.
Check that the pump is working o/k, if it seems o/k and it drains o/k, then you have no alternative than to call an engineer.
This really is your only option.
Plz rate my solution
Thanks.
Jan 19, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint aquarius wf325 filter problem, not accessable??
If you are certain that your washer has no filter at the front behind the lower removable panel, it is usually held on by 3 scews which you have to undo, or just held in place with plastic lugs, then you will have to remove the lower rear cover of washer. Locate large black hose at lower right of tub, remove clip and hose.
inside you will see the plastic filter,
Remove and clean filter, refit filter and plastic ball if it has one, refit hose and clip securely, and water test for leaks.
Be careful when you remove hose as there will be water run out.
Please make sure you have it unplugged before you do all this.
Plz rate my solution, and feel free to leave any comments.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WF210 Front Load Washer
How do I find and clear the filter in Hotpoint Aquarius wf210?
pull machine forward andtilt back look underneath machine at bottom ofplastic tub u will c a black pipe leading from the tub t the pump unscrew from the tub end (put a bowl down first as water will come out)pull off pipe inside u will c a white platic collecter pull that out clean and put back together hope this helps
Dec 21, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WF210 Front Load Washer Logo
602 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
