Epson stylus pro 9880 paper mis match. The 9880 always wants a roll paper. I have a 7800 that seems to be on line, but I am not sure any more. How do I resolve this problem?
SOURCE: Epson Stylus pro 4800 field repair manual
Epson is pretty cautious with their proprietary materials.
SOURCE: paper doesn't always feed, and when it does, the paper rolls through without printing
Get a Q-Tip and alcohol. Wet Q-tip with alcohol. Stand in front of the printer and look down where the paper feeds through. On the righthand side you will see a big roller that pulls the paper through and a little one right up under that. Clean both of them with the alcohol and Q-tip. Press the paper feed button and as it trys to act like it is feeding the paper, clean the roller with the Q-tip. Do this until the paper feeds through correctly.
SOURCE: loading paper into an epson stylus tx110
hi there... this is what you need.
Loading Paper
Follow these steps to load paper:
Slide the edge guide to the left.
Fan a stack of paper, then tap it on a flat surface to even the edges.
Load the paper with the printable side up, against the right side of the sheet feeder. Then slide the left edge guide against the left edge of the paper, but not too tightly.
Note:
Leave enough space in front of the printer for the paper to be fully ejected.
Always load paper into the sheet feeder short edge first, even when you are printing landscape-oriented pictures.
Make sure the paper stack fits under the arrow mark inside the left edge guide.pls vote for me
SOURCE: epson styllus pro 7800 service call error 0001002d.. help
http://www.largeformatrepairs.co.uk/technical/maintenance-error-code-0001002d.htm
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
Please rate the answer........
