Pin 570 Pocket pc. Model:PS1022. The lcd unit was damaged to the extent that no images can be read. I've opened it up & found that the unit can actually unplug via a ribbon cable. Would it be possible to get another unit - either new or second-hand, to replace the current one? I am in NZ, so please take this into consideration when replying as i don't know if it would be worth while getting a replacement unit from too far away...
Cheers
The screen is expensive in relation to the value of the pda so a practical solution is to buy a donor pda with a different fault being offered cheaply for spares. The screen is the same as that for the Acer N35. Both PDA's are based on the same motherboard although they are not interchangeable due to slightly different fittings for example the GPS aerial connector. Screens and batteries are interchangeable.Try Ebay or Trade Me. If the ribbon is not pushed home firmly and square before locking in, it will not work and swicth on and off and on to check. You need a certain amount of good fortune when buying a dead donor as any other fault may disguise the fact that the donor's screen may also be kaput!
navman PIN 570 smartst is not working, i am trying to install it from cd but it is saying its not...
(More)
navman PIN 570 smartst is not working, i am trying to install it from cd but it is saying its not supported by the screen resolution, how do i fix this problem help please because i can't get access to maps or sat nav
I have pre-ordered a map update for my F20 and thought I would get ready by carrying out a software...
(More)
I have pre-ordered a map update for my F20 and thought I would get ready by carrying out a software update, which I have done, but can now longer get the machine to work and get the message "Bootloader 4.10.1014 built on Jan 11 2007 at 15.31.20 permission data abort......unit will reset in 5 seconds". It then closes down. Could this be because I am using Vista, and if so what can I do to rectify the problem please? The Navman suggest I send it to them for repair which will cost £70 - £80. Any cheaper otions would be welcome! Thanks.
eg Ireland Maps can be used on pcket pc but do not show up as installed on "Map" on...
(More)
eg Ireland Maps can be used on pcket pc but do not show up as installed on "Map" on SmartST Desktop whilst all other UK maps are shown to be installed on the desktop map but cannot be accessed on the Pocket unit!
