Question about Microsoft Windows Vista Ultimate Edition
Boot Problem I have windows xp on C drive and then i installed windows vista on d drive..but i cant access xp now..
  • Sibananda Jun 20, 2009
    thanks i will try
  • 55 Answers
You have to download and install easyBCD...
Posted on Jun 20, 2009
Hai, I am Shreyas, Check boot.ini in command prompt hope it will run
Posted on Jun 21, 2009
How to uninstall Windows Vista
You must use a full retail or OEM version of XP (not the cd from your old computer) this makes life really easy and can usually be downloaded from the web.
You must also have a genuine XP key, which has not been used on another system.
Next you should know or find out the specifications of your system, to do this goto Manufactures website.
The most important step is to find out if your hardisk is using SATA interface (if so you will require the SATA XP drivers and a floppy disk, as this is the only way that XP can install these drivers.)
Install XP via cd rom by booting cdrom at system start (if you cannot do this then you must access your system bios at first boot by pressing F2 or Del keys(or whatever key your system uses) and change the boot option to cdrom as first drive.
If your system uses SATA press F6 when XP prompts “press F6 to install other” at very beginng of XP install and install sata drivers from floppy.
Jun 12, 2009 | Microsoft Windows Vista Home Premium SP1...
Tip
How to Install Window XP with Vista
If you wish to install Windows XP on a computer that comes with Windows Vista already installed then you will have to create a separate partition on your hard drive to install Windows XP onto. This effectively splits the hard drive into two, and keeps the different versions of Windows separate. To do this you need to open up the Computer Management screen by going to the Start menu and then right-clicking on Computer and selecting Manage.
From the Computer Management screen select Disk Management, right-click on your main hard disk where Windows Vista is installed and then select Shrink Volume. This opens up a window where you can choose how large you want the new drive partition for Windows XP to be. You need to select the size of the new partition carefully, as you will need enough space to be able to install Windows XP successfully (around 10 gigabytes) whilst leaving enough space for Windows Vista. After you have selected the appropriate amount of space click on the Shrink button to begin the process, and once that has completed you should be able to right-click on the new partition (which should be labelled “Unallocated free space”) and select New Simple Volume.
Follow the on-screen instructions to configure the partition, set a drive letter (such as E:\), give it a meaningful name such as “XP”, and then restart your computer. Whilst your computer reboots, access the BIOS and change to boot sequence to boot from your CD/DVD Drive before any other device, insert your Windows XP installation disc and then save and exit from BIOS. You will then be taken to the Windows XP installation program where you should follow the instructions until you come to the screen asking you which partition to install Windows XP to.
Make sure you select the new partition and not the one with Windows Vista installed, as this will cause problems. Once Windows XP has finished installing, you will notice that Windows XP loads up automatically, rather than giving you the choice of which operating system to use. To rectify this insert your Windows Vista installation disc and restart the computer to access the Windows Vista installation program. From the Install Now screen select Repair My Computer, and then select your Windows Vista installation and then Startup Repair. You will now be able to choose which operating system to use when your computer starts up.
on Dec 07, 2009 | Computers & Internet
I my laptop cant boot windows 7 and xp together !
Since you have installed XP after installing windows 7 & vista, you have erased the boot manager of vista. To get it back, just download & install Vista Boot Pro from http://www.softpedia.com/get/System/OS-Enhancements/VistaBootPRO.shtml
May 04, 2009 | Acer TravelMate 4320 Notebook
I have Dell inspiron 1525 laptop with windows Vista home premium
go to bios setup n change sata driver to ATA from AHCI n  also disable da flash play module
Mar 18, 2009 | Microsoft Windows XP Professional for PC
Dual Boot problem in Windows XP & VISTA
Don't try to edit the xp boot.ini or the vista bootloader. It only leads to other problems and headaches.
Try this first: Take note as to which drive has vista on it, put your vista installation cd in the drive and let it boot to the "installation window", then choose "repair", then "startup repair." Make sure you choose the drive that already has vista on it. Let that run and when it re-boots you should then be given a choice to boot to vista or "other windows".
There is also a (free) program called EasyBCD. Download that, read the directions and have at it.
If none of that works, you'll have to do a clean install. Install XP on one drive first, then Vista on the second drive in that order. The Vista bootloader will pick up the XP. However, XP is NOT forward compatible and will not recognize the Vista bootloader. Make sure that you don't have any flashdrives or media cards plugged in before doing the install.
Another approach would be to shrink the Vista volume, creat a new partition, then install Linux Ubuntu that partition. Linux will detect all of the OS's and create a boot menu. Unfortunately, you'll lose about 5 gigs to the Linux OS and it's swap partition, but then, you get to goof around with Linux :-)
Feb 25, 2009 | Microsoft Windows Vista Home Premium with...
NEED WIZ"S HELP- CANT BOOT XP OR VISTA CD FROM DVD DRIVE
I'll give a whack at this problem. I think the previous person meant blank drive NOT black drive (that doesn't make sense to me).
I would follow the previous persons in going to BIOS and making sure the first boot device is CDROM. My question to you is whether you've already done this or whether you need assistance with this process. If so, please tell me what computer model you have.
Dman
Jan 08, 2009 | Microsoft Windows Vista Ultimate Edition
I m looking for recovery cd of my notebook TX 1301.
HP TX1301 - you should have got one with your computer or at least a utility on your computer which creates recovery discs using your own blank discs.
See this for Windows XP http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph08097
Windows Vista
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=&product=81351&docname=c00810334
If you are running Vista and you cant boot your computer , insert the vista installation disc into the drive , start the computer off the install disc , click repair my computer when you get the "Install Now" option to access vistas recovery tools from the disc
Jan 07, 2009 | Computers & Internet
WindowsXP not loading after installing Windows Vista Demo Version
You need to get rid of the Vista Demo, and reload xp. You need to keep one or the other I think, you can't keep both operating systems on the same drive. What were you thinking?
Did you install the vista demo as a dual boot setup? Doesn't sound like it.
I hope someone can help you, I can't.
Nov 24, 2008 | Microsoft Windows Vista Ultimate Edition
Win vista uninstall
Put your window XP disk into the Disk drive. Start up your computer. When it asks you what Drive you want to install it on select C:\ (where Vista is) Say yes to deleting the current Operating System and follow the instructions from there.
You did say you wanted to Uninstall Vista!
If you mean Dual Boot Vista and XP, then you will need to create a Logical Partition of about 10 Gb to install XP on and when asked where to install select this partition. But note that XP will wipe the Boot sector clean of all other Operating Systems which means that if you want to Dual boot then you will have to reinstall Vista again to get Dual Boot functionality.
Apr 14, 2008 | Computers & Internet
Lost my right as administrator
You have done big mistake that's why you are getting problem.
1)Regarding installation of win XP over windows vista.
You have to install first lower version and then higher version i.e. you should install first win xp and then windows vista. But vice-versa you can't do it.
So my suggestion is that format your c drive then install win XP
after installation win XP install win vista.
2) which operation system do you want to open .
You can remove it using windows tweak utility software wich is freely available on most of the website. Also you can manually edit it.
For manually do this.( i m not sure about windows vista it is available or not)
right click on my computer->click on Advanced Tab->setup and recovery framework click on settings->click on Edit button
You will see the boot.ini file. You can remove the windows XP line from that file.
Oct 22, 2007 | Acer Aspire T690 (AST690UP820A) PC...
Microsoft Windows Vista Ultimate Edition Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
