No lights, no sounds, no fan , no hard drive , no nothing.Is my motherboard fried?
I know I'm a little late with this answer but before doing any or all the above, test the power cord. Hope this helps.
Remove all the cables, then take the battery out. Press down the power button for 10s. But the battery back in, connect the AC adapter and try to start.
If nothing happens, most likely HW issue.
SOURCE: Acer Aspire 5010.. Power on, but Blank screen/ hard drive light also not.
This could be a Power/Switch Problem.
Faulty Hard-Drive.
Solution:- Leave the laptop turned Of And charge the battery to Full Capacity. ( usually between 4-16 Hours ) depending on capacity.
This will also fully charge the CMOS ( memory battery )
then boot the laptop up, and see if this solves your problem.
If not i,d suggest running a scandisk or hard-drive diagnostic program, to ensure that you have no Viruses-bad sectors on the hard-drive.
If you need further assistance please don,t hesitate to ask for more help and advice.
Mike @ Compurepair.
SOURCE: acer aspire 7720 start up problems
You need to try to isolate the problem. Try connecting an external monitor to your laptop. Press function screen keys. If you have a picture on your external monitor then you have a video problem - most likely an inverter, although you may need a new screen, unlikely but possible.
If you have no picture then you have a system problem. Disconnect the battery and AC adapter. Remove the memory and reseat. Repower your laptop and see what happens.
SOURCE: How to replace Acer Aspire 5630 Hard Drive
The link below gives you the user manual. On the computer views is the base view which will show you the correct bay on the bottom of the computer. You will loosed the screws to that bay, remove the cover andl you will see the hard drive. Althought I have not removed this particular laptop hard drive, these drives usually pull up or back using a tab provided. The hard drive will probably have a cradle the actual drive is connected to. You will have to removed the old drive from this cradle and put the new drive back on the cradle exactly the way the old drive was attached,
I hope that this information helps and gives you a place to start solving your issue.
Brian
SOURCE: I have an Acer Aspire 4520, Will not turn on.
IT COULD NVIDIA DISPLAY IC PROBLEM,GET IT REPLACED.
DHARMAKKAN
SOURCE: ACER Aspire laptop power cycles on and off
Sir, form the symptoms I believe that the Battery is completely dead, the system is unable to identify the battery. If possible try checking the battery with a similar model, and the the system should be all set to go.
please encourage us,if this tip was helpful to you.
