Question about kawasaki Full Suspension Mountain Bike Men
I have oil blowing out of the dip stick on a JD lx188 lawn mower with a 17 hp v-twin Kawasaki engine. Is crank case pressure normal on one of these engines? do I just need a gasket on the dip stick cover or do I have more serious problems.
Nothing serious. A new o-ring for the cover. No more problem.
Posted on Jun 21, 2009
Oil leak center case to left of oil filter gasket leaks bad after shut off is there a check valve inside
I would replace the filter. turn filter on BY HAND til the gasket seats, then 1/4 turn more ONLY (light film of new oil on gasket, dip fingertip in oil bottle and wipe onto gasket)
Oct 15, 2016 | John Deere Riding Lawn Mower. D170 54 in....
What fuel do I put into a Vantage 3.5 Tecumseh lawn mower?
If it has a place to add oil to the crank case, either a dip stick, or a filler opening at the bottom of the engine, then you just use regular gas. Be sure to verify that there is oil in the crank case before running it this way.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jun 16, 2016 | Tecumseh Garden
WHY DOES OIL BLOW OUT DIPSTICK TUBE WHEN ITS RUNNING
Make sure it has the right amount of oil in the crank case, if over filled the oil will foam and flow out any place it can, Worn piston rings can cause blowby into the crank case , causing oil to escape from the dipstick tube.
Dec 08, 2015 | Stanley Lawn Mower. 54 in. 24 HP Kawasaki...
How do you take the Dip Stick off
the dip stick twists out, and sometimes are tight, or hard to turn. be sure and replace it as tight as you can, back presure in the crankcase will blow it out if it's not tight
Jul 13, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
Wiring harness
look underneath did drive belt snap in two , rear has white plastic fan on top of it that should be rotating with engine running if not yep you broke a belt , don't know about wire could it be from front PTO they are electric so it will need a wire ,one possibility is that drive belt broke slapped front PTO and broke off wire , that musta been some snow your pushin ooh and a reminder never push a hydrostatic drive tractor without pump turning it will dammage it
Feb 08, 2014 | John Deere Starter Tractor Lx188 Kawasaki...
My lawn mower started smoking-whitish, looked like it came from the carb. It also made some shaky noises like something was loose. Then it quit running. A while later I started it again-it started fine,...
Recheck your oil level. The smoking routine you mentioned sounds like the crank case is being over-pressurized from too much oil. That results in the crank case breather dumping oil into the intake of the carb. Then you see all the white smoke and hear the engine making odd sounds because of the excess crank case presure. Just re-check the oil level. There are 2 lines on the dip stick. The oil level should NOT be above the upper line with the dip stick fitted in the run position.
If you still have the problem please respond with an engine model number. If it is a Briggs and Stratton engine the number will be on the air shroud near the spark plug wire. Honda and tecumseh the number will be not far from the lower end of oil tube or next to the dip stick on engines without an extended tube stamped on side of the engine base.
Let me know if you still need help after correcting the oil serviciing level. There is more that can be checked..... just need that engine number.
Thanks for choosing FixYa,
Kelly
Sep 09, 2011 | Garden
I have a Murray 6.0 hp 20 inch push lawn mower. How much oil do I put in when changing oil.
If there is a dip stick add some oil check the level till you get to the full mark. It should take a little more than a quart. If there is no dip stick then there is an oil fill plug down low on the engine. Fill slowly until the oil reaches the threads in the engine housing (almost overflowing). Be sure to replace the plug or you will have oil everywhere when you start it.
Don't just dump the oil in, check the level as you go!
May 20, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
I HAVE A JOHN DEERE LX188 MOWER. 17 HP. GOVENOR NEEDS ADJUSTING.
Your engine per John Deere is a Kawasaki FH500V
Here is the service manual (3.58 Mb pdf file) This should get you going again.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqwm227_hwen2002_0000000-01.pdf
Jan 23, 2010 | Garden
1979 chevy 350 modded to 383 stroker i have been
Sounds like the engine can't breath,
make sure pcv valve is good,or oil cap is vented.
your engine is building up pressure and has no where to vent,so it blows the easiest thing,the dip stick
Nov 18, 2009 | 1983 Chevrolet K1500
Craftsman riding mower 2003 DLT 3000 ,Blowing oil out of the fuel
Head gasket is blowed .Its building pressure in the crankcase seen it twice. Remove the head and check for a blowed out spot between piston and the valve side
Jul 29, 2009 | Briggs & Stratton Briggs Stratton Intek V...
kawasaki Full Suspension Mountain Bike Men Logo
535 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Marvin
Marvin
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
