Question about GE Refrigerators
Defrost error, high temps.
This is an ''ATAG'' side by side. The icemaker has a label inside reading GE so I guess that's the manufacturer. Model: KE711W5H/3/A01, about 6 years old.
I get a DE (defrost) error. Temperature in freezer compartment too high (30 top, 20 bottom). Fridge side 40 degrees. Ice maker not working.
Most probably the defrost heater is faulty. (Ice starts building up at back panel). Icemaker not making ice probably caused by temp being too high.
My question though: I had the fridge switched off and completely defrosted everything with hairdryer. After switching on, the fridge never reaches temps lower than 20-30 degrees. Does this make sense?
I mean, shouldn't it reach normal temps (after, say, 24-30 hours) before the frosting becomes a problem?
PS - compressor running, fans running, door seals ok...
How to disasemble water tubing from GE 7405GFW side by side icemaker?
That isn't a good model number. Look inside the refrigerator section , probably on the upper right wall for your model number.
ge refrigerator leaking water YouTube
Sep 07, 2014 | GE Refrigerators
Why does the water light stay green, ice cubes/crushed ice lights do not> This is a GE side by side refrigerator.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Oct 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side - Ice maker works, but water won't dispense from door. Had the frige turned up for a period of time, could it have frozen the water line?
NOTE: This
Leo Ponder
imufo2
Sep 19, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Have a GE Profile side by side that is about 11 years old. We have had the icemaker replaced 3 times and worked on about 4-5 times for the same problem. The ice gets smaller and smaller until cubes very...
NOTE: This
Leo Ponder
imufo2
Sep 19, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge 26.6 cu. ft. side by side refrig- TFX27R no cold water from the dispenser
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
http://www.applianceaid.com/procedures.html
I'm
Leo Ponder
imufo2
Sep 05, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
GE model # PSS26MSWCSS is not making ice & the green light inside the ice maker is blinking
NOTE: This
I'm
Leo Ponder
imufo2
Aug 23, 2011 | GE Refrigerators
Does the GE DSS25KSTB have a Defrot Timer or does the main board control defrost. Defrost heaters in door jams are on all the time.
NOTE: This
I'm
Leo Ponder
imufo2
Aug 15, 2011 | GE Adora DSS25KSTSS Stainless Steel Side...
My ge side by side fridge stopped making ice
NOTE: This
I'm
Leo Ponder
imufo2
Aug 14, 2011 | GE GSH22JFZWW Side by Side Refrirator
I have a GE Adora side-by-side refrigerator Model # DSD26DHWA-BG. About 1 year ago the ice maker stopped producing ice. The mold that forms the ice cubes is filling up with water but never pushes out...
Hello, there are three screws that hold the icemaker in place if you remove these three screws and unplug the icemaker and remove it from the unit. After you take the icemaker out take the entire unit with the cover on it and run it under hot hot water this is actually quiet common for an icemaker to freeze up well actually its the parts on the inside of the icemaker that are freezeing up. After you defrost the icemaker as I term it then you would dry the icemaker and reinstall it. when the icemaker reaches 32 degrees the icemaker will call for water once again from the water valve if at this time after the ice forms the unit still doesnt drop the icecubes then you would have no other alternative then to buy another icemaker they usually sell for around 50-90 dollars american. The icemaker is not worth replacing parts on due to if you were to replace parts on the icemaker you would end up spending about 4 times as much as the entire icemaker costs. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks again Rick
Jun 04, 2011 | GE Refrigerators
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
