Question about Akai PTH5498 54" Rear Projection HDTV-Ready Television
Akai pth5498 Where can I purchase a Convergence Board? Is there an online supplier? Hi first post I have the AKAI with convergence problem opted to replace with new board.Question when I removed the wire that connects the cramic block up behind the color tubes was unable to determine where it was connected.The block has one each wire running to each tube and the one for the convergence board. Does anone have digram of how the wires are connected?Bought a complete board for 88.00 dollars better than try to solder in new IC's
  • 105 Answers
The part number for the convergence board is aa95-00705a and you can order it at send me your email addy to and i will send you a wiring diagram....
Posted on Nov 03, 2007
Red and blue pic adjustments areso out of adjustment how can i get them back
Convergence board is dead.Go to Tv repair buy a new convergence board replaced the board will solved ur problems.Samsung/Akai use same convergence board.
Jan 22, 2010 | Akai PTH5498 54" Rear Projection...
Akai PTH5498
thats board i beleieve iff the unit has fuses on the amp board i beleive they are fb102b and fb101b fusables are you going to replace these.. more than likely if u still have partical convergence it may be a amp or a resistor not the fuse.. have you gone into convergence mode? does the read crosshairs move?
Dec 13, 2007 | Akai PTH5498 54" Rear Projection...
Convergence board is bad
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
You can see some examples and find a fix here...
Dec 28, 2009 | Akai PTH5498 54" Rear Projection...
Akai (PTH5498) 54" rear projection TV with red and green ghosting and large curve in the picture at the top and bottom of the screen. Unable to fix using manual convergence. Thinking it must be the...
Yes is is your convergence IC's. One has gone bad, but consider replacing both of them because if one has gone bad then the other is not far behind. They are located on the middle board of your set. They are mounted on a large heatsink, the part # should be STK-392-040. Replace these and your set will work fine again.
Nov 15, 2009 | Akai PTH5498 54" Rear Projection...
Convergence adjustment
HELLO . it sound like you need to replace the convergence board or just the IC'S ON THE BOARD. IT WOULD BE CHEPER THAN THE HOLE BOARD. "GOOD LUCK"
Jul 27, 2008 | Akai PTH5498 54" Rear Projection...
Akai replacement parts
You are not likely to find the board easily, but you should be able to replace the convergence ICs relatively easily. Look at the board. Try resoldering the pins on the STK ICs. If that fails to resolve your problem, replace the ICs. There may be some pico fuses located close by or low valued resistors that may be open. Check for those as well.
Keep us posted.
Jul 23, 2008 | Akai PT5598HD 55" Rear Projection...
PTH5498 54 in. Rear
convergence amps possible have been blown. also check fuses and resistors on that board. it more that likely blown if fuse go. As a tech that happens to me all the time
Dec 02, 2007 | Akai PTH5498 54" Rear Projection...
TV will not turn on...
Convergence board failure. $300 repair
Sep 19, 2007 | Akai PTH5498 54" Rear Projection...
Akai pth5498
contact orwww. they might be able to help you.good luck.
Apr 13, 2007 | Akai PTH5498 54" Rear Projection...
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
75 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
