Question about Philips 19PFL3403D/27 19 in. LCD TV
Why does my philips turn off when i use it as a monitor?
Why does my philips "19 hdtv turn off when i leave it on as a monitor? if i wiggle the mouse it turns back on. but how do i keep it from turning off?
  • 86 Answers
Probably you're using your tv as a computer monitor via vga input. just click on start,control panel, power option and select NEVER
Posted on Jun 20, 2009
  • 79 Answers
It's probably in sleep mode, like when a computer starts a screen saver. You can change this setting at the settings. You can change or type the time before it goes to sleep mode.. (e.g. 90 minutes) but there is really no other way to KEEP IT ON forever. It will still keep turning off... but I'm sure you'll lose no files.
How do i get my monitor to come back on after it goes into sleep mode?
Wiggle the mouse, tap a key on the keyboard, and if the computer still doesn't respond then press the power button on the computer (not the monitor).
Mar 06, 2011 | Acer AL1916W 19" WideScreen LCD Monitor
Monitor just won't stay on.
  • power chord may be faulty
  • check the cable that connects it to the computer correctly
  • may be an internal circuit breaker
  • check the ports on the computer
Oct 10, 2009 | Samsung 923NW 19" LCD Monitor
Philips monitor that get on & off
Unplug the Monitor Cable from the Computer Tower and Connect it back again and make sure its connected properly.
Sitll Have the Same problem then restart the computer and get in to bios by tapping F2 key and leave the computer for 30 mins and check wheather it goes off or not.
Any clarifications, Jus let me know
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 02, 2009 | Microsoft Windows XP Professional
HYBRID CONECTED TO AN HDTV AS A MONITOR
Change the power options in the control panel so it doesn't go on standby when your in the middle of something
Jan 17, 2009 | Dell Studio Hybrid Desktop Computer
My Samsung SyncMaster 215TW Monitor only flashes on for a second when I hit the standby button, and wiggle the mouse. I can't get the monitor display to stay on. Can you help?
If it is not still covered under warranty, start by opening the case. Once you remove the power board, you will probably notice several capacitors (the round, can shaped parts) that have tops that are not flat. If you see any that have bubbled tops instead of being completely flat, they need replaced. Once they are replaced, the monitor should turn right back on. Hope this helps.
Nov 28, 2008 | Samsung SyncMaster 931B 19" LCD Monitor
Can u help me?
this is system power scheme, to save power when the machine doesn't detect any action on the keyboard of the mouse for a preset time frame.
go to control panel>power options and change the hard drive shunt down time, and the monitor shunt down time to what ever you like.
Oct 23, 2008 | Philips 190B6CB/27 19" LCD
LG Monitor L194WT - Indicator Lights Flashing
sorry - i posted my response at the original thread : )
Comment by ohms, posted on Jun 19, 2008
Definitely it is not your computer. When it was given the signal to go OFF, it did but like completely off.
Comment by ohms, posted on Jun 19, 2008Oh one more thing, if the monitor still exhibits same issue after setting your Power Options as displayed above,
check your warranty with that monitor and exercise it.
Yep u got it ! warranty or new monitor
Jun 19, 2008 | Computers & Internet
Sometimes when I leave my comp on and it the screen goes black I'll wiggle the mouse and my monitor says "** signal rgb" I have to turn my computer off to get the picture back. How could i fix it without...
Dear Carthorne,
just go to the Control penal then click on Power options, then choose the monitor power and select the *****.
maybe there is time alloted to monitor so you have to select it *****.
Cheerup and Be Happy Always
Mar 10, 2008 | Computers & Internet
Monitor Turns Black - Won't turn back on when moving mouse
It is probable that the ROM system, called BIOS (Basic Input/Output System), is set to not wake your computer by moving the mouse or pressing a key on the keyboard.
I do not know which BIOS your computer is running so I can only give a general answer.
When your machine is starting up, look for a message that says "Press F2 to enter BIOS" or something like that. Your machine may have a different F key assigned to enter BIOS.
There should be a setting in there that allows you to change the values for waking the monitor. It should say something like "Use keyboard and Mouse to wake up computer", it won't say those exact words, but something like that. If the value is set to disabled, then enable it. Then save your changes and exit (Usually by pressing F10)
Be careful when in BIOS. Changing settings you do not understand can make your computer behave erratically or stop functioning altogether.
Sep 23, 2017 | Sylvania CL972B (Black) 19 in. Flat Panel...
Monitor turning off
If I understand you problem correctly, your monitor is turning off when it remains idle? Does it come back on when you use the keyboard or move the mouse? If so, then this could just be caused by the computer's power-save settings. This can be adjusted by right clicking on the the desktop and selecting propeties. Go to the screensaver tab and click on the power button. From here, you can either set the "Turn Off Monitor Time" to never, or to a greater period of time.
Oct 16, 2006 | Sylvania CL972B (Black) 19 in. Flat Panel...
Philips 19PFL3403D/27 19 in. LCD TV Logo
570 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
