SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
SOURCE: How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
SOURCE: error E50 how can i
Hi
Thanks for using FixYa. Error E50 indicates motor
fault, you’ll have to check the brushes and wiring of the motor and check if it
makes a hum sound, if it does and you can see that the motor is not working
then it is the motor that should be replaced. If everything else appears to be
working fine then it is the PCB that should be replaced. Please do accept the
solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
