Windows cannot install my fax modem
Ive been trying to install a fax modem(dynamode m56pci/s-fast) however windows could not install it and its original driver is no where to be found.
is there a way to install it? (or a place to download the driver)
regards,
omer
    Novelist:
  • 186 Answers
Well, is this a PCI device? Those usually have software to get themselves recognized by the system. If this is older ISA there are more steps to go through. I take it you've got the driver disk and manual showing any jumpers. You will have to get back to me and we'll get you up.
DaveF1953
Posted on Jun 20, 2009
Ive installed win xp on my aspire 4520, but some driver are missing like SM Bus controller,co processor, and 3 base system device. please help
Download the drivers from the Acer WEB site.Make sure you select the model of your laptop and the XP or Vista version ofthe drivers you that require and it matches the Windows version that isinstalled on your laptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Feb 03, 2011 | Conexant chipset 56K V.92 PCI Data/Fax...
DFM 562IS (DFM-562IS) Modem: SIR PLEASE SEND ME ITS ALL FEATURES.......
Product ID 3409 Brand D-LINK Vendor Code DFM-562IS Description 56K V.92/V.90 Software-based PCI Modem
The DFM-562IS is a software modem card. It plugs into a PCI expansion bus slot of a desktop PC. It supports voice, fax and data transmission/reception. It's a high-performance CONEXANT-based modem card, and can be used to connect to the Internet, and for fax and voice communication.
Key Features
High speed External Data/Fax/Voice
Plug and Play Installation
ITU-T V.92/V.90/K56flex Auto Detect
Fax Mode up to 14400bps Transmission Rate
Technical Specifications
Data ITU-T V.90/V.92
K56flex
ITU-T V.34, V.32bis, V.32, V.22bis, V.22
Bell 103 & 212A
V.44, V.42bis & MNP 5 (Data compression)
V.42bis & MNP2-4 (Error correction)
V.80 (H.324 video conferencing interface)
FAX V.17 (14400bps FAX)
V.29 (9600bps FAX)
V.27ter (4800bps FAX)
Voice With voice support via sound card application
System Requirements Requires CPU with MMX support
Operating Systems:
Windows 98,
Windows ME,
Windows 2000,
Windows NT 4.0,
Windows XP
Manufacturer D-LINK Warranty 2 Year Manufacturer's return to base Link D-LINK DFM-562IS Internal PCI 56K Voice/ Data Software Modem
May 03, 2010 | Computers & Internet
Windows 7 Fax problem
Here is a couple of links ... okay, scratch that. Here are a whole slew of links that might help you with your problem.
http://www.alltheinternet.com/texis/open/search?q=Windows+7+fax+drivers&ref=04172017232732&p=
Apr 18, 2017 | Computers & Internet
HP USB Modem does not break dial tone
If the information connected to your post is all correct (56k V90 usb), and you are using one line for both the internet and the fax, you should hang up from the internet before you try to dial out the fax.
You have not indicated your PC model, so I don't know what operating system you are using. For XP and newer versions, you have to set up and configure the fax using the wizard or configuration software. If you have not done that yet, you need to.
In xp, go to start, Programs , Accessories , Communication , Fax , and then click Fax Console.
You said your computer is new. Win 7 and Vista are much the same:
1.Click the Start button , click All Programs, and then click Windows Fax and Scan.
2.At the bottom of the left pane, click Fax, and then click New Fax on the toolbar to launch the Fax Setup wizard.
3.Click Connect to a fax modem and follow the instructions.
You also need to make sure that your fax/modem is correctly listed in the control panel. In XP, start, control panel, printers and devices. If you do not have a fax printer listed, you need to "install a local fax printer."
The installation wizard should work in both OS without much trouble. If you do have difficulty, Microsoft and adobe both have "virtual printers" you can use. Look in Microsoft office or online.
Also check control panel of 7 to make sure that your modem and fax are listed correctly. Thanks for using Fixya.
Jan 01, 2010 | HP (56K V90 USB) Modem
I have a Dynamode wireless router which i have configured however the cable which came with it does not fit into telephone connection. What other cable do i require
The nework cable that came with the wireless router has RJ45 connectors (8 wire cable) and the telephone cable has narrower connectors RJ11 (4 wire cable) or RJ12 (6 wire cable - less commonly used).
I assume the Dynamode wireless router does not have a built-in modem and therefore needs to be connected to a broadband modem.
If broadband modem is a cable or DSL type, the broadband modem is connected to the Dynamode WAN/Internet socket with a RJ45 LAN cable.
If you have a broadband DSL modem you need a RJ11 phone cable to connect the moden to the phone socket.
Sep 08, 2009 | Computers & Internet
FAX PROG. TRYING TO DOWNLOAD EVERY TIME I LOG ON AND I DO NOT HAVE A FAX.
If you have a modem installed in your computer Windows will try to set up the fax functionality. If you have your Windows installation CD, insert it and install the fax software. That is the best answer I can give you based on the limited information you gave.
Aug 13, 2009 | Microsoft Windows XP Professional SP2
MODEM RELATED
Yes you can use that modem for fax. It conforms to specs V.17, V.21, V.27, and V.29 fax profiles. Source is here.
Jul 02, 2008 | Computers & Internet
Dynamode Internal Fax Modem 56K
i had same problem trying to receive faxes until i changed phone connections.
according to a motorola manual (link below) this has something to do with being connected to a "proper analog phone line".
i had the phone line running from wall to a newer gateway (maybe 8 months) dec 07 to a maybe 2 year old compaq. kept getting that loop current error on the compaq when trying to receive a fax until i elimated the gateway connection and plugged the wall right into the compaq.
here's a link that might help: http://downloadmirror.intel.com/12655/ENG/Motorola.htm
see section 6, troubleshooting. hope this helps...
Jun 27, 2008 | Computers & Internet
Connecting my dynamode 6004 W G1 wireless router to modem
Cable modems and routers must be turned on in a specific way. First, unplug both the router and modem. Next, plug the ethernet cable from the modem, into the cable router, and unplug the cable from the modem to the computer. Next, turn on the modem, and wait for all of the lights to stay static (usually there's 4 lights, the main one we're interested in, is the status light). Next, plug in and turn on your router. You should now be able to access the router and configure it for your internet connection.
May 18, 2008 | Computers & Internet
Winfax and Act! V6
Does this place answer any of your enquiries? http://www.fixya.com/support/p148729-symantec_winfax_pro_12_00_02592_pc
Aug 30, 2007 | Symantec WinFax Pro for PC
Computers & Internet Logo
126 people viewed this question
Alun Cox
David Payne
David Payne
