I have EPSON LX-300 II ,I conect it to dos system and I have to change the setup manually from the buttun of the printer,all I need the way to print the guid change setup. that paper is display how to change every things by the postion of the light.
My epson lx-300+11 is print always in two page pls guid.
Posted on Aug 24, 2009
EPSON LX-300 NOT TAKING DOS COMMAND
Re-install the printer drivers. Follow the installation instructions strictly otherwise you will not be ablt to print in DOS.
Sep 14, 2011 | Epson LX-300+ II Matrix Printer
Setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
Setting of new paper size from epson lx-300 +II
your solution works fine with me, but the problem is i can't able to save the settings on the printer. so everytime i need to print on that given custom sized paper type, i need to manualy select it from advance tab on printer properties before i have a good print-out..
Anyways,Thank you very much.
Apr 13, 2009 | Epson LX-300+ II Matrix Printer
Configuration of page length
Most of these older printers use a special key to enter setup...usually upon power-up. Have paper inserted, because that is where it prints it's configuration.
It will probably use some of the feature buttons to change the paper size and tear-off options. Sorry I can't help with a manual, but I hope this helps.
B)
Apr 08, 2009 | Epson LX-300+ II Matrix Printer
Epson LX-300+II not printing in draft 10 cpi using visual studio .net
use courier font. it works just as draft font. no problem in VB-6 i hope it will also work with .Net as well.
tell if dont work.
asad khan
justasad@hotmail.com
Oct 27, 2008 | Epson LX-300 Matrix Printer
Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
Problem with the epson lx 300
Try to reinstall the printer diver
Aug 12, 2008 | Epson LX-300 Matrix Printer
Sending Reverse Line feed to Epson LX-300+II USB printer
Hi Shery,
I went through the manual of LX300 printer series.I believe that if u read that manual, you can Fix the problem as it has all instruction about the Reverse feed and pull tractor mechanism.
Download Manual
http://ftp.epson.com/pdf/lx300p/lx300ppg.pdf.Any issue contact me.
Thank you
Riz (zyrixdown3@gmail.com)
Feb 11, 2008 | Office Equipment & Supplies
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
Epson LX-300+ Matrix Printer Problem
Please change the setting print direction from bidirection to unidirection.
Nov 05, 2007 | Epson LX-300 Matrix Printer
315 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
