We took the cover off of the keyboard case to clean it (after 20 years), and discovered that it wasn't the keyboard that was cutting out, but the broken wire on the adaptor. After that, the fuse has blown twice..last night was the second time.
The unit uses a 9.5V AC (at 2A) 'step down' transformer, its doubtful you will be able to replace it with anything modern (as most things are DC, not AC nowadays).
However, you may be lucky and find a similar one in a junk shop or flea market type place, anything in the range 9 - 10V AC and NOT DC should be fine, as long as its at LEAST 2A (or 2000mA), not below, although something at 1.8A might work.
Just splice the leads (doesn't matter which way as its AC) onto the old plug from the damaged unit, just make sure the leads stay apart!
Any decent electrical engineer or advanced electrician should be able to do this (properly!) or fix the unit.
That's the simplest fix.
Splicing good leads for damaged is another option, both sides are AC so it doesn't matter which wire goes to what, unless you are in the UK and the unit is earthed of course.
If the unit is intact and some of the lead is OK both sides, a terminal block connected close to the first break, nearest the transformer can eliminate the broken bit. If its damaged on the actual unit, unless you have someone that can get inside and rewire it (best option), you are looking for a replacement.
http://kurzweil.com/content/migration/downloads/pub/Kurzweil/Pro_Products/Other_Pro_Products/PC88/PC88_MusiciansGuide.zip
